Re: [net4j] Configuring the HTTP Acceptor [message #632857 is a reply to message #632674] |
Thu, 14 October 2010 13:47 |
My impression is that the HTTP transaport of Net4j is rarely used up to now and there's not much of a documentation for it. Please have a look at org.eclipse.net4j.http.internal.server.HTTPAcceptor to find out about the needed properties. I'll be back to business next week and maybe have the time to give more detailed advice then.
Cheers
/Eike
http://www.esc-net.de
Am 13.10.2010 22:33, schrieb dloose:
> Are there any examples for configuring the CDO server's HTTP Acceptor? I can get the TCP acceptor to work, but the project I'm working on requires all traffic go over HTTP.
> My cdo-server.xml config file looks like this:
> <cdoServer>
> <acceptor type="http" listenAddr="0.0.0.0" port="8080"/>
> <!-- <acceptor type="tcp" listenAddr="0.0.0.0" port="2036">
> <!-- <negotiator type="challenge" description="_database/repo1.users"/> -->
> <!-- </acceptor>
> <repository name="repo1">
> <!-- <property name="overrideUUID" value="1ff5d226-b1f0-40fb-aba2-0c31b38c764f"/> -->
> <property name="supportingAudits" value="true" />
> <property name="supportingBranches" value="true" />
> <!-- <userManager type="file" description="_database/repo1.users"/> -->
> <store type="db">
> I added the listenAddr and port attributes to the http acceptor element out of desperation. I get the same results without them. If I comment out the http acceptor and enable the tcp acceptor, everything works perfectly.
> Here's the output of ss:
> Framework is launched.
> id State Bundle
> 0 ACTIVE org.eclipse.osgi_3.6.0.v20100517
> Fragments=45
> 1 RESOLVED c3p0_1.0.0
> 2 <<LAZY>> org.apache.derby_10.5.1.1_201005192117
> 3 RESOLVED com.my.companys.bundle_1.0.0
> 4 ACTIVE org.eclipse.emf.ecore_2.6.0.v20100614-1136
> 5 RESOLVED org.eclipse.equinox.launcher_1.1.0.v20100507
> Fragments=44
> 6 RESOLVED javax.xml_1.3.4.v201005080400
> 7 ACTIVE org.eclipse.core.contenttype_3.4.100.v20100505-1235
> 8 ACTIVE org.eclipse.equinox.app_1.3.0.v20100512
> 9 RESOLVED org.eclipse.core.filesystem.win32.x86_1.1.200.v20100505-1235
> Master=51
> 10 ACTIVE org.eclipse.net4j.http.common_3.0.0.v20100614-1656
> 11 RESOLVED org.apache.commons.codec_1.3.0.v20100518-1140
> 12 ACTIVE org.eclipse.core.resources_3.6.0.v20100526-0737
> Fragments=38
> 13 <<LAZY>> org.eclipse.net4j.db.derby_3.0.0.v20100614-1655
> 14 ACTIVE org.eclipse.emf.ecore.xmi_2.5.0.v20100521-1846
> 15 ACTIVE org.eclipse.net4j.db_3.0.0.v20100614-1654
> Fragments=16
> 16 RESOLVED net4j-frag_1.0.0.qualifier
> Master=15
> 17 ACTIVE org.eclipse.core.jobs_3.5.0.v20100515
> 18 ACTIVE org.eclipse.equinox.preferences_3.3.0.v20100503
> 19 <<LAZY>> org.eclipse.team.core_3.5.100.I20100527-0800
> 20 <<LAZY>> org.eclipse.core.variables_3.2.400.v20100505
> 21 ACTIVE org.eclipse.equinox.common_3.6.0.v20100503
> 22 ACTIVE org.eclipse.net4j.http.server_3.0.0.v20100614-1655
> 23 ACTIVE org.eclipse.update.configurator_3.3.100.v20100512
> 24 <<LAZY>> org.eclipse.core.expressions_3.4.200.v20100505
> 25 RESOLVED jtds_1.0.0
> 26 RESOLVED org.apache.commons.httpclient_3.1.0.v201005080502
> 27 ACTIVE org.eclipse.emf.cdo_3.0.0.v20100614-1657
> 28 <<LAZY>> org.eclipse.ant.core_3.2.200.v20100427
> 29 RESOLVED org.eclipse.core.runtime.compatibility.registry_3.3.0.v20100 520
> Master=39
> 30 ACTIVE org.eclipse.net4j_3.0.0.v20100614-1655
> 31 ACTIVE org.eclipse.equinox.http.registry_1.1.0.v20100503
> 32 ACTIVE org.eclipse.emf.common_2.6.0.v20100614-1136
> 33 ACTIVE org.eclipse.core.runtime.compatibility.auth_3.2.200.v2010051 7
> 34 ACTIVE org.eclipse.emf.cdo.common_3.0.0.v20100614-1655
> 35 RESOLVED com.springsource.javax.servlet_2.5.0
> 36 RESOLVED org.eclipse.osgi.services_3.2.100.v20100503
> 37 RESOLVED org.apache.commons.logging_1.1.1.v201005080502
> 38 RESOLVED org.eclipse.core.resources.win32.x86_3.5.100.v20100505-1345
> Master=12
> 39 ACTIVE org.eclipse.equinox.registry_3.5.0.v20100503
> Fragments=29
> 40 ACTIVE org.eclipse.net4j.tcp_3.0.0.v20100614-1656
> 41 ACTIVE org.eclipse.emf.cdo.server_3.0.0.v20100614-1654
> 42 RESOLVED org.eclipse.osgi.util_3.2.100.v20100503
> 43 ACTIVE org.eclipse.net4j.http_3.0.0.v20100614-1655
> 44 RESOLVED org.eclipse.equinox.launcher.win32.win32.x86_1.1.0.v20100503
> Master=5
> 45 RESOLVED javax.transaction_1.1.1.v201006150915
> Master=0
> 46 <<LAZY>> org.eclipse.emf.ecore.change_2.5.0.v20100521-1846
> 47 ACTIVE org.eclipse.core.runtime_3.6.0.v20100505
> 48 ACTIVE org.eclipse.net4j.util_3.0.0.v20100614-1655
> 49 ACTIVE org.eclipse.emf.cdo.server.db_3.0.0.v20100614-1654
> 50 RESOLVED javax.servlet_2.5.0.v200910301333
> 51 ACTIVE org.eclipse.core.filesystem_1.3.0.v20100526-0737
> Fragments=9
> Any documentation on the HTTP acceptor would be helpful. Specifically, I'd like to know if it supports HTTPS or if it will in the future.
> Dave
Cheers
/Eike
Re: [net4j] Configuring the HTTP Acceptor [message #936977 is a reply to message #936908] |
Mon, 08 October 2012 14:34 |
Am 08.10.2012 15:15, schrieb Key Ofeka:
> Did anyone succeed to setup HTTP acceptor? It doesn't work for us.
> CDO server starts without errors, but there's nothing listening to the port 8181.
You must start the special org.eclipse.net4j.http.internal.server.Net4jTransportServlet, call its setRequestHandler()
method and pass in your HTTPAcceptor instance as the requestHandler.
There's also a convenient nested class ContainerAware that automatically looks up / creates an HTTPAcceptor in the
central managed container from the servlet's init() method. I think this acceptor would be the same one that'll picked
up by your cdo-server.xml below.
I just ran the shipped HTTPServer OSGi launch config and the test case org.eclipse.net4j.http.tests.HTTPTest.test1() to
validate basic functionality. It worked after I adjusted some of the server launches' dependencies.
Cheers
/Eike
> Any hints? Thanks.
> <cdoServer>
> <acceptor type="http" listenAddr="localhost" port="8181">
> </acceptor>
> <!-- <acceptor type="tcp" listenAddr="localhost" port="1111">
> </acceptor> -->
> <property name="supportingAudits" value="true"/>
> <property name="supportingBranches" value="false"/>
> <property name="supportingEcore" value="true"/>
> <store type="db">
> <mappingStrategy type="horizontal">
> <property name="qualifiedNames" value="false"/>
> <property name="toManyReferences" value="ONE_TABLE_PER_REFERENCE"/>
> <property name="toOneReferences" value="LIKE_ATTRIBUTES"/>
> </mappingStrategy>
> <dbAdapter name="h2"/>
> <dataSource class="org.h2.jdbcx.JdbcDataSource"
> uRL="jdbc:h2:file:repo;DB_CLOSE_ON_EXIT=FALSE;IFEXISTS=FALSE;AUTO_SERVER=TRUE"/>
> </store>
> </repository>
Cheers
/Eike
FUDForum. Page generated in 0.03630 seconds
