Re: Problems with serialization/deserialization [message #632673 is a reply to message #632629] |
Wed, 13 October 2010 20:15 |
Ed Merks Messages: 33137 Registered: July 2009 |
--------------070903000609020407060305
Sorin,
I think it's a losing battle to take the approach you've taken. This
bugzilla takes a cleaner approach.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=245014
Even then, you're likely better off to put things in a wrapper that's
specialized to use a resource to serialize and deserialize.
Sorin Fagateanu wrote:
> Hello,
> I'm trying to make a serialization/deserialization of an UML model
> using java Serializable interface.
> My scope is to create an object, make a serialization (so I can
> save it in a database) and a deserialization (when I retrieve it from
> database).
> In the serialization/deserialization process, problems appeared :
> java.io.NotSerializableException was thrown when trying to serialize
> the object with writeObject method. My solution was to take EMF
> sources and rewrite the classes with problems, adding "implements
> java.io.Serializable" so they can accept serialization.
> Some modified classes : - org.eclipse.emf.common.notify.Notifier
> - org.eclipse.emf.common.util.URI;
> - org.eclipse.emf.ecore.resource.URIHandler;
> - org.eclipse.emf.ecore.resource.URIConverter;
> - org.eclipse.emf.ecore.util.ExtendedMetaData; etc.
> After these changes, the object was successfully serialized.
> The big problem was with deserialization. I encountered this error
> when trying to deserialize with readObject method :
> at org.eclipse.emf.ecore.util.EcoreEMap.newEntry(EcoreEMap.java :182)
> at org.eclipse.emf.common.util.BasicEMap.put(BasicEMap.java:593 )
> at
> org.eclipse.emf.common.util.BasicEMap.readObject(BasicEMap.j ava:1557)
> at java.io.ObjectStreamClass.invokeReadObject(Unknown Source)
> at java.io.ObjectInputStream.readSerialData(Unknown Source)
> at java.io.ObjectInputStream.readOrdinaryObject(Unknown Source)
> at java.io.ObjectInputStream.readObject0(Unknown Source)
> at java.io.ObjectInputStream.defaultReadFields(Unknown Source)
> at java.io.ObjectInputStream.readObject(Unknown Source)
> at
> org.eclipse.emf.common.util.BasicEList.readObject(BasicEList .java:775)
> at
> at
> at
> teste.BootstrapListener.deserialize(BootstrapListener.java:1 56)
> After making some investigations, I discovered that the problem is
> in org.eclipse.emf.common.util.BasicEMap : some fields (like
> delegateEList) are "transient" by default and they are deserialized as
> null.
> Does anybody else has encountered this type of error? If yes can
> you please guide me?
> Thank you in advance for your help,
> Sorin.
Content-Type: text/html; charset=UTF-8
<html>
<head>
<meta content="text/html;charset=UTF-8" http-equiv="Content-Type">
</head>
Sorin,<br>
<br>
bugzilla takes a cleaner approach.<br>
<blockquote><a
href="https://bugs.eclipse.org/bugs/show_bug.cgi?id=245014">https://bugs.eclipse.org/bugs/show_bug.cgi?id=245014</a><br>
</blockquote>
specialized to use a resource to serialize and deserialize.<br>
<br>
<br>
<blockquote cite="mid:i94lgl$k17$1@news.eclipse.org" type="cite">Hello,
<br>
<br>
<br>
database).
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
at
<br>
<br>
at
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
at
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
at
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
at
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
at
teste.BootstrapListener.deserialize(BootstrapListener.java:1 56) <br>
null.
<br>
<br>
<br>
<br>
<br>
Sorin.
<br>
<br>
</blockquote>
</body>
</html>
--------------070903000609020407060305--
Ed Merks
FUDForum. Page generated in 0.04870 seconds
