Home » Modeling » Epsilon » re-execute rule to duplicate object generation
re-execute rule to duplicate object generation [message #632517] Wed, 13 October 2010 05:53 Go to next message
Hi Chaps,
I need to be able to create certain elements more than once. To do this I thought it would just be necessary to write:
cProc.definesParameters := vProc.reactsTo.equivalent();
cProcPrime.definesParameters := vProc.reactsTo.equivalent();
However this shifts the ownership of the generate objects, how can I force ETL to re-run the rule and regenerate the elements?
Also is there a way of specifying using equivalent() or equivalents() a method for calling certain rules which have a particular output.
My translation requires that I distinguish between different port types by thier direction and create different target elements accordingly. How can I separate the calling of these two rules?
Many Thanks,
James
Re: re-execute rule to duplicate object generation [message #632538 is a reply to message #632517] Wed, 13 October 2010 06:33 Go to previous messageGo to next message
Hi James,
James Sharp wrote:
> Hi Chaps,
You'll need to use an operation instead of a rule in this case (rules
are executed only once per source element).
A solution to this might be to specify two rules with appropriate guards.
> Many Thanks,
> James
Dimitris
Re: re-execute rule to duplicate object generation [message #632595 is a reply to message #632538] Wed, 13 October 2010 10:24 Go to previous messageGo to next message
Hi Dimitris,
Thanks for the clarification, I will convert to an operation as suggested.
RE the calling of different rules, I already use two different rules with guards.
However they were both being called using equivalent() and as one returned a different object type then this cas causing issues.
I have found that if I make one rule lazy and one rule normal and rely on the normal rule to sort itself out this resolves the issue.
Thanks for your help,
James
Re: re-execute rule to duplicate object generation [message #632605 is a reply to message #632595] Wed, 13 October 2010 10:56 Go to previous messageGo to next message
Hi Dimitris,
Sorry but this doesn't seem to have worked - I had left a line commented out that I shouldn't have.
I have the line:
c.containsChannels.addAll(v.containsEntity.definesPort.equiv alent());
This should in theory call the lazy rule:
@lazy
rule OutputPort2Channel
transform port : vhdl!Port
to channel : csp!Channel {
guard : port.hasDirection.name.toLowerCase() == "out"
channel.name = port.name;
channel.definesParameters := new csp!ChannelParameterList;
only one element assigned to OutputPorts
var typeRef = new csp!TypeRef;
typeRef.containsType := GetDataType(port);
channel.definesParameters.parameterTypes.add(typeRef);
However it seems that the result of the equivalent() that I am using here is returning the following:
Bag {TypeRef [], TypeRef [], TypeRef [], TypeRef [], Channel [name=ready, ], Channel [name=dispense, ], Channel [name=ret, ], Channel [name=coin, ]}
This is returning the values not only from the rule specified above but also from one of the normal rules as well. How can I stop this equivalent() from running on a normal rule? Or just ensure that only the lazy rule abore is run?
Many Thanks,
James
Re: re-execute rule to duplicate object generation [message #632621 is a reply to message #632605] Wed, 13 October 2010 11:22 Go to previous messageGo to next message
Hi James,
I'm afraid you can't. You should either filter the results of
v.containsEntity.definesPort.equivalent() or replace the Port->Channel
rules with operations so that you get more fine-grained control.
Dimitris
James Sharp wrote:
> Hi Dimitris,
> I have the line:
> @lazy
> [name=coin, ]}
> Many Thanks,
> James
Re: re-execute rule to duplicate object generation [message #632626 is a reply to message #632621] Wed, 13 October 2010 11:53 Go to previous messageGo to next message
Hi Dimitris,
Thanks, didn't realise a restirction before a .equivalent() was possible:
c.containsChannels.addAll(v.containsEntity.definesPort.selec t(port : vhdl!Port|port.hasDirection.name.toLowerCase() == "out").equivalent());
If I have placed this restriction before the equivalent, is the guard still required within the lazy rule now (as seen below)?
@lazy
James
Re: re-execute rule to duplicate object generation [message #632630 is a reply to message #632626] Wed, 13 October 2010 12:00 Go to previous message
Hi James,
I think you'll still need the guard. To reduce duplication you could
define an operation vhdl!Port isOut() { return
self.hasDirection.name..toLowerCase() == "out";} and call it from both
places in your code.
Dimitris
James Sharp wrote:
> Hi Dimitris,
> @lazy
> Cheers,
> James
Previous Topic:Assigning rule generated target model elements to a contained reference
Next Topic:Running ETL examples
Current Time: Sun Nov 02 07:45:40 EST 2025
Powered by FUDForum. Page generated in 0.24235 seconds
