Home » Modeling » EMF » Teneo und Deep Objektgraphs
Teneo und Deep Objektgraphs [message #632342] Tue, 12 October 2010 14:59 Go to next message
Thomas Schindl is currently offline Thomas SchindlFriend
I'm not sure this is really a problem of Teneo or more general a problem
of Hibernate itself.
Suppose you have the following Containment-Structure (ie a bidirectional
relation).
Company
Country
Region
Store
Department
When you now issue a HQL-Query "FROM Department" you'll notice that
Hibernate is executing after the first fetch an SQL-Statement which
JOINS Store, Region, Country, Company to follow up the the parent path.
Now imaging the Object-Graph is getting 10-times deeper and you'll get a
SQL-Statement with a lot, a lot of JOINS (in my case it even goes beyond
the limit of the database).
Anybody an idea how this could be solved?
Tom
Re: Teneo und Deep Objektgraphs [message #632359 is a reply to message #632342] Tue, 12 October 2010 16:17 Go to previous messageGo to next message
Martin Taal is currently offline Martin TaalFriend
Hi Tom,
Yes the parent econtainer relations are mapped using a hibernate custom type, apparently these are eagerly fetched. I
need to check if they support lazy loading. Can you enter a bugzilla for this? If you have a focused test model that
would be great, I can also create one myself (sounds pretty reproducable...).
gr. Martin
On 10/12/2010 04:59 PM, Tom Schindl wrote:
> relation).
> Company
> Country
> Region
> Store
> Department
> Tom
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: Teneo und Deep Objektgraphs [message #632424 is a reply to message #632359] Tue, 12 October 2010 20:22 Go to previous messageGo to next message
Hi Martin,
So modeling them as bi-directional and not as containment this would not
happen?
I'm not sure that this is a teneo specific problem because when i read
the Hibernate-Docs correct hibernate has to fetch resolve bi-directional
references.
I'll file a bugzilla with a model that should reproduce the problem.
Tom
Am 12.10.10 18:17, schrieb Martin Taal:
> Hi Tom,
> type, apparently these are eagerly fetched. I need to check if they
> focused test model that would be great, I can also create one myself
> gr. Martin
>> Hi,
>> relation).
>> Company
>> Country
>> Region
>> Store
>> Department
>> Tom
Re: Teneo und Deep Objektgraphs [message #632507 is a reply to message #632424] Wed, 13 October 2010 08:52 Go to previous message
Hi Tom,
Yes guess so, the problem is that the custom user type used for econtainer associations does eager fetching, for normal
associations this eager fetching can be controlled by annotations.
I will react in the bugzilla.
gr. Martin
On 10/12/2010 10:22 PM, Tom Schindl wrote:
> Hi Martin,
> happen?
> references.
> Tom
>> Hi Tom,
>> gr. Martin
>>> Hi,
>>> relation).
>>> Company
>>> Country
>>> Region
>>> Store
>>> Department
>>> Tom
The Netherlands
Previous Topic:[CDO] Timeout when connecting to server
Next Topic:[TENEO] where is teneo 1.2
Current Time: Sat Mar 28 18:42:36 GMT 2020
Powered by FUDForum. Page generated in 0.01951 seconds
