Home » Modeling » EMF » Fwd: Re: RCP & EMF Compare
Fwd: Re: RCP & EMF Compare [message #632175] Mon, 11 October 2010 21:23
John Yotka is currently offline John YotkaFriend
--------------050701050201000000060301
One more question...
The approach works but it doesn't put out the titles of the 2 resources
being compared and that it is an "EMF Model" comparison in the
comparison editor (see attached jpeg). Is there a way to get those
resource identification titles to display in the comparison editor?
(I'm using the 1.1.0 version of EMF Compare)
-------- Original Message --------
Subject: Re: RCP & EMF Compare
Date: Wed, 29 Sep 2010 17:44:58 -0600
Organization: EclipseCorner
Newsgroups: eclipse.tools.emf
References: <i1329k$ii4$1@build.eclipse.org>
<i13r3a$mjc$3@build.eclipse.org> <i1558n$m6k$1@build.eclipse.org>
<i23pfr$kvn$1@build.eclipse.org> <i54or2$hcs$1@build.eclipse.org>
John Yotka wrote:
> Thanks Cédric, that example is exactly what I needed, I got it working
> the way I wanted.
> Cédric Brun wrote:
>> Hi John,
>> you can also trigger EMF compare from java code just like I did in
>> this blog post :
>> http://model-driven-blogging.blogspot.com/2010/06/forecasts- comparison-for-
>> world.html
>> this triggers comparison in the EEF sample RCP application.
>> Cédric
>> John Yotka wrote:
>>> Eike Stepper wrote:
>>>> Am 08.07.2010 01:23, schrieb John Yotka:
>>>>> How can I configure my RCP editor to use the EMF Compare capability.
>>>> What have you tried so far?
>>> Not much really, I have the EMF Compare plugins in the RCP build of my
>>> EMF editor. But how do I invoke the compare function between 2 versions
>>> of a model. The RCP editor currently just uses a menu open to select a
>>> model to edit. I would like to have something like a menu command to
>>> select the 2 versions to compare and then invoke the compare function.
Content-Type: image/jpeg;
name="compareEditor.jpeg"
filename="compareEditor.jpeg"
/9j/2wBDAAEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEB AQEBAQEBAQEB
AQEBAQEBAQEBAQEBAQEBAQH/2wBDAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEB AQEBAQEBAQEB
AQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQH/wAARCAH/Aj0DASIA AhEBAxEB/8QA
HwAAAQUBAQEBAQEAAAAAAAAAAAECAwQFBgcICQoL/8QAtRAAAgEDAwIEAwUF BAQAAAF9AQID
AAQRBRIhMUEGE1FhByJxFDKBkaEII0KxwRVS0fAkM2JyggkKFhcYGRolJico KSo0NTY3ODk6
Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1dnd4eXqDhIWGh4iJipKTlJWW l5iZmqKjpKWm
p6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW19jZ2uHi4+Tl5ufo6erx8vP0 9fb3+Pn6/8QA
HwEAAwEBAQEBAQEBAQAAAAAAAAECAwQFBgcICQoL/8QAtREAAgECBAQDBAcF BAQAAQJ3AAEC
AxEEBSExBhJBUQdhcRMiMoEIFEKRobHBCSMzUvAVYnLRChYkNOEl8RcYGRom JygpKjU2Nzg5
OkNERUZHSElKU1RVVldYWVpjZGVmZ2hpanN0dXZ3eHl6goOEhYaHiImKkpOU lZaXmJmaoqOk
paanqKmqsrO0tba3uLm6wsPExcbHyMnK0tPU1dbX2Nna4uPk5ebn6Onq8vP0 9fb3+Pn6/9oA
DAMBAAIRAxEAPwD+unW/h78L9IsUvrj4YeG/Ed7c6loulRibw/4d1bxDrWr+ IdZsNCsZL3Wv
FEkMmoajfanqUEmoavrusm4uZJLi+v72adpJHxPEHhD4a+DU0u78dfAPQPBe jatq8Ghw6/rP
hr4TXek22pXdteXVrHqDeHtd1y9sredbKZDqE9kun2rlGvrq1gLTL23xEvf7 O0XQ7vOPK+Jn
waXPT/XfF3wPB+vmY9+lfO9u+pW2ufD7SYPDV3B4e1aL4IWHifTIfhrFFo+o WGj+F/DWkCz1
6OP9glLWG00iwutU0wQXvin4YweHbOe/06Jvg5bxzaF4V+XyThDMeJMBmWJy /GxwuJwvs4YS
OJipYGrWi1VrxxThTliVH2EoqLoSTUmnytXZWKzfDZfXw1PFQqVKVVydV0pW rQg1ywlTU5Km
2pptqdrxTSd9voP/AIVL8Kv+iZ/D7/wjPDn/AMraP+FS/Cr/AKJn8Pv/AAjP Dn/ytrgrHw7q
3xF/Zbs/CWga/wD8Irrvjv4A2/h3RfFPn+Nrf/hHNW8T/DtNM07X/tPw18f/ AAo+I0H9j3l9
DqPn+APin8NfG0f2fzPCvj/wdrq2HiLTvyt8BfBf9s39hj/hVnwt8K/tO+Bf iD41/bP/AG6P
j74VsvGHx++GPin4taB8MvBOu/8ADzT9vF9fs/h58GfiX+xz8Obzx18TbPTv AD+PptA8EeEd
W8P/ABM8Q/FTTpvH/wAVPgh4d/Zn+GXwD+fjSk1OM6ipVqcnGVKXO/hUnUfM ltT5JX9270sr
tI7ue6TTbi9U77p/Dpfrf5H7H/8ACpfhV/0TP4ff+EZ4c/8AlbR/wqX4Vf8A RM/h9/4Rnhz/
AOVtfjh4H/4KVftA+P8A4Z6NZaV4a8C3H7QH7SHwL/Yp/aY/ZF8I+BvhPc+N /wDiU/tl6B+0
58Vpf2bvGHhj4jftW/s8eCviF46+BnwQ/Y3+NPi/xB+0PrP7SP7Lvgn4l/ar RPDXwU8NeLvD
ugfDP4vbvw6/4KBftT+Mk/Zy8TfEv4caF+zV8Jde+K93+zt8Wfij4i+CGs/t B6f47/aa0D9t
34l/sYX3wCt9C+BX7Ut7qv7F+u+MNU+GGj+JvC/xb8dn9rz9mHRfE3xs0j4V ap8edX8Q/DXw
xqn7SlvC1le8opqSjbnfM7wc4uMUnKalyyiuRS96Mk7JNhz+b/H5+lvM/XL/ AIVL8Kv+iZ/D
7/wjPDn/AMraP+FS/Cr/AKJn8Pv/AAjPDn/ytr8Gfgf+1d/wUS8M/shf8Eyf h94KtdC/ah+P
H7S37Glr+0ncfEbTvg5pfi3xN4c+Enwx+GP7IOiS6B8UvDXx/wD+Ckf7M1v8 Wviv4n8Y/tIW
uu+N/wBo7Tf2h/DM+pahpSWFn+yvdR+LdZ8ceAvsv9l/9tb9qH482Xx9+KV3 8BPAvif4c/Cv
/hQOi+D/AIL/ALO3xH+HnxR+Nfjrxt8c/wBkj9i79pTxBYaX8afHPxZ+Ef7K 2u+BfgvL8e/H
KWXxK8P+N7jSf2hfCepaJqPg/Tvh5efCu0/4aYJ4WrHmaqU5Ri5a+05XZVfY puMrSjzTTSur
JRcpNR95nO+8vx7Xt62P0b/4VL8Kv+iZ/D7/AMIzw5/8raP+FS/Cr/omfw+/ 8Izw5/8AK2vz
k8afto/tA6N4c/bf/aHt/CPgXwZ8HP2AfAviy/8AiP8AszeP/CVzq/7QPxP8 beHv2Evhj+2a
2nQ/tE/D744658HPg1/Zmo/G7wv8Ktf0XSPg7+0rpL3Pw48VeKvDvxK1rTvi BoVp4G4Xx3+1
F+3H4J/aL+HP7FH/AAn/AOyjqfxj8f8Ajr4L6h/w0B/wzJ8XrL4Z6T8M/i/8 B/8AgpT8SP8A
hEf+GeP+GyLvxTf+OvD3in/gnl5f/CxP+GkLLQNW0D4v/wBm/wDCr9M1HwB/ bnjaVh6rTfPF
JQ5370naKjGUn7sXfljOEny3uprl5mpKJzvu+2/X+k/u9D9Vf+FS/Cr/AKJn 8Pv/AAjPDn/y
to/4VL8Kv+iZ/D7/AMIzw5/8ra/nC+I3xo+MXxX8Wft2ftS+ILb4F6lrv7A3 /BN348WtppOu
/Dn4qza/B8YvhX8a/wDgsh+yz45+LH7JHxU8H/tDeBPiN+w9/wANBXn7K/g/ XvjBF4G1r4h/
FXWPhnZeA/hLafG+1134XeH/AIuXn6Cxftk/tT3PxF+EHjvSdI+FHin4D/Fr 9sv9tj9kTTf2
dvC/ww1kftIzah+x94D/AG7PsfiLw7+0R41/aZ8EfBTUtd+LvxD/AGK473SP C3i34L+APDPh
DQvinb+D9e+JlxJ4Muvih4gueFqR/wCXibSlz3biozjT9ryJ63bp3lzNRhpZ yT0Fzt9X5a9L
2v8Af8z9OP8AhUvwq/6Jn8Pv/CM8Of8Ayto/4VL8Kv8Aomfw+/8ACM8Of/K2 vyq/bI/4KG/t
F/BvwTfeP/hD+zf46h134BfAvxZ+1L+13+zz8SvBHwH8UeNvA/wUtdW+Itt8 M59a+NHhb9v/
AME/Dn4b/wDC1bP9n748Tad4h+CvhX9vnxZ4U0nSLDX/ABl8EdF12y8O/Dn4 p/Zf7R/7QPib
QdZ+EHwi+AHiv4UJ8W/jD+0jP+zdqXizxppWofFbwz8CPE2kfssfFj9sS8f4 hfCbwV8RPhf4
l8Q674h+GPwv0bStG8IXHxR+GeoaVp/xf8HfFiW98QeHtLtfB/jbN0aqUHzK 0udu078ippSl
KfLe0eSUZxa5lOMk4czaQ+d66vp36/8AB08nufRX/CpfhV/0TP4ff+EZ4c/+ VtH/AAqX4Vf9
Ez+H3/hGeHP/AJW1+OH/AATn+JP7THiTWvGX7O3h/wAbfAvQf+FH/HT9qT40 /tE+MNZ+B/j/
AMSf8Lw/4Xt/wVu/4KZeBtb8NfBbw/ZftGeF/wDhnD+xP+GY/GGqaVrPjnW/ 2ovM/wCFoeGr
K70qT/hWOqXfxQ90/ZF/ay/aY+MvxM/ZM1X4laj8C5Pg5+23+wv8Tf20vAHg PwN8KPH/AIY+
JnwR/wCEf1/9jO58K/DXxh8Wdf8Ajv448LfGn7J4W/asv9G8QeMdF+C3wT/t zX/Bdp4l07wr
4a07XJvCemVPDzhKpH2kX7Nu+s02lGc4te7ZOVODqJc2i92TU/dBTbtq9fN/ 1u7f8DU/Rv8A
4VL8Kv8Aomfw+/8ACM8Of/K2j/hUvwq/6Jn8Pv8AwjPDn/ytr0Giua77v72O 77v72eff8Kl+
FX/RM/h9/wCEZ4c/+VteZeDPA/ws0/4NeFPFmt/DnwbqLWXwy0LxFq9y3hDw 7eanftbeFbXU
r+dpru0Q3V/dFJZDJdXKGe4fdNOu5pB9HV89SXH2X9lGS6zj7N+z01xnpjyf huZM57fdp2q1
E4Um/azahS3f7ySahp1962nUfMopyk3yxactX8Ku5fgjY8ReBvA3g/SLjxF4 t/Zw07QPDthL
YpqetXHhj4Qajb6bFf39rpsV3cWWg+JNX1ie3iuLuEzjT9MvbhIt8i27hGrp bb4XfCG9tre8
s/h38N7uzu4Irm1urbwj4Yntrm2njWWC4t54tPeKaCaJ1kiljZo5I2V0YqQT 4X8TL/XbGXUL
zw7omp2tzfN8QLG8uNF+HYu7i8sL/wCM3j3xG9pdS2v7BfxVmurS/vns9faK QXEOq3klv4ke
58c3V8vxV8ee8fC82n/CNanHp9tbWVha/ET4vWNlZ2cMVtaWlpp/xZ8a2Nta 2tvCqQ29vbQ2
6QwQQokUMaLHGiooUfT8ScI5hw5PD4v64sVlWLgqFP2yUcdRx9KpXlWVR0qV PDywtbD+xdFJ
KtTq0a7nKcKtNUvOwGb4fMIzpRhUpYulJznyy5sPPDyjTVNwvJ1FVhU5/aX9 yUZ0+XlcJOb/
APhUvwq/6Jn8Pv8AwjPDn/yto/4VL8Kv+iZ/D7/wjPDn/wAra/FP4Cf8FE/2 vfEPhD4A+Pfi
u/7N3iLS/HPwo/4JXfHH4geH/h78H/id8PdQvvDP/BW745Xn7Nfw88B+DvEH iT9or4pW/hbX
f2W/GXhbxD8TvGnjvWvD3jbT/wBo/wAM+ING+GWh+Av2cdV8M33xQ8Vbug/8 FDf21vGXizxH
o/wj/Zv/AOF1eFvj78C/Gn7Sv7BvjD/hCPhN8GP+Ew+Cnh741/s1eBofGn/C P+Jv2/8AxxqP
xp+yfBz9qzwt8dP+Ec+Mkv8AwTO8WeI/+Fcf8KxfQfB3in4wajd/s9+E8JWT a54e6+Vt1OWN
7KTXNNRXu02qjbaXJfVuMoru5/OX4/1vp6n7H/8ACpfhV/0TP4ff+EZ4c/8A lbR/wqX4Vf8A
RM/h9/4Rnhz/AOVtfht4Q/be+PFn4s/a9/aq0741eBfjl8HP2X/+Cbug/Gn4 p/CaX9mz9ov9
mT/hY3xM+EHxr/4K0eE9d8NfDHwH8a/jd4r8U/se+OtL8U/s+aL8MvjprPxK +Gfx31/4jf8A
CvNHaw0rwTp2i+Hraz7rQf21P+CkUPj/AOGP7Pfjn4QfAvwH8Y/in8dPAXgb S/FHxZ0jwN4I
/sr4Z/EX9mf9u74pXvjC5/Zz/Z2/b0/bi8Ur/wAK18U/se2mveE/EHjD45/D rQP2of7V8efA
Lw/afAzUfAet/tF6YPCVU5L2kFyK8lKUoSVoxlNck1GV4KUXLS6UldJqaic7 7y/p26N7s/Y/
/hUvwq/6Jn8Pv/CM8Of/ACto/wCFS/Cr/omfw+/8Izw5/wDK2vjv4y/tO/Hu 08X/AA/+DXgH
4H678CPGXxh/aRvf2f8A4bfHP9ovS/hb8VvhJren+H/gb+0v+0HrHxN8JfCj 4BftRWvxP8W6
Fqvhr9mmTwnp/h74n+Kf2avE2iTfF/wn42nsvEFz4J8XfDK78o1z9rL9pjwj 428b3+r6j8C9
c+HP7O37V37F/wCw78YfCunfCjx/oPjb4x/Ez9qvSf2NodT+O/w18f3Px38Q aF8DPAvg3Xf2
1fDuo2HwJ8UfDX4/a/rGk/CLWtFuPj1Y3nxPsdf+GWao1JW9+N2uaK573Tkq cbSjzQ96o+Sz
kmpXc1GK5h877v8AH1/LX8rn6N/8Kl+FX/RM/h9/4Rnhz/5W0f8ACpfhV/0T P4ff+EZ4c/8A
lbX87/xV/aq/a9+Nf7Iv7Jvhb4u+KP2btR1X/go58KP2KPj14Zk8CfAb4neE /Afww8M+Lv26
v+CYnww+KvwI+OPgHxN+0/8AES5/al+FHxa8Hftwt4M8e6Dp/i79n/T/ABN8 OvB/jzwF4j03
XNL+MZn+Hv1d8J/jB+0Rpf7QnxE/YK+CV9+zd8KPE3w+13xC1n8Q9R+C/wAZ fGvwN0jwH+zZ
+xX/AMElYtS+H3wt/ZXtf2rvBlv8FNC8UeMv21DqXgjQvh58Y9O+HXwz8IfD J9J1T4cfEv4n
/E3xr8an1eFmoturG6dXT3+XkouCnPmteylJxsouTcW0nFptc77vp16u9l/T 6n65f8Kl+FX/
AETP4ff+EZ4c/wDlbR/wqX4Vf9Ez+H3/AIRnhz/5W18A+H/26vE3iH9gP9m3 482s3wob9pX4
8/Cj/gnDrGveCreTULvwz8L/ABN/wUU+JPws+CHhL4oav8No/F6+PtS+FHhf x9448a+IvDvh
K88ceGtQ+KGn/CnxR8O9N+LHhvWYtW8b+HvlH4AfEH9r3SP2uv2vv2XNB+Jv 7N1v8ePiP+0j
8UPjj41+PGr/ALNvxO1T4SP4Z+A37Cv/AARv8EWvgPwv+znZ/taaL4x0PXfE tt+034Sv7jx3
q37TXifT9Ln+GPiKGPwFex/ErTW+GcRw9R+05pqDp890+Z39m4c70T91RmpJ 6uWijF3bT53p
q9fN9b2++3+Z+1n/AAqX4Vf9Ez+H3/hGeHP/AJW0f8Kl+FX/AETP4ff+EZ4c /wDlbX5yeEv2
sv2mPFPxr/Z+17+0fgXY/s5/HX9uj9sH9i3/AIVX/wAKo8f3Xxr8Lf8ADKHh P9uSz/4WV/wv
7/he9v4F1v8A4T3x1+xj/wAJH/wh3/DNWkf8It4T+JH/AAhf/CVeI9Y8H/8A CfeKf1crKpCd
NpSlq03o3o1KUJRd0tYyhJO14vdNrUFJvq/v+f6nn3/CpfhV/wBEz+H3/hGe HP8A5W0f8Kl+
FX/RM/h9/wCEZ4c/+Vteg0Vnd9397Hd9397PkTzPgV8PvAHxK+IvxB8GeAbP w/4J1T4ueJvF
ms3PgXTdVXRvCXw913xJayT2ej6bot/di30jwl4Yt2OmaBpkl1qd3b3N/wDY r/XtVvrm++Rf
it+2/wDs/wDhnRfita/Cb9kPxh8T/iX8MvC/wV8V2/gbxV+y58WPg9Z+LbL4 0fGcfBvTrDRt
S174B694xk1vSLyHUNfh0yy+G2py+M7Kxv7LwA3ia68LfEhvAXI/tz+IyP2Z P2ifCC+DvHXx
CPi7xj4j+Hn/AAhvw08UeMfCHjfVx8SvjsPBTf2Dq/gHwf8AELxPNNp6+JTq t34etvAfjPTf
GGn2V54S8ReF9d8N65q2mXPjXhj9oH4wfEiz+FHwb8dfAf4q/AzQda8VeE9P 0X4h3t3+0xqH
jjwjrXwi0m/+MfhDW9R8SftT/sZeEvBfji+uta+E+maPrR8U+NfEnivxDNrE +q3Wm6+q61qF
t/ZHDXB2SvhHIsdUy7AYvM8RleV4qnhsVi8JhsPX+s4PBVcPHEYemo5nOOOx Mq+HnXo1qLqc
01h6n1ilNr8ZzniPGQzvHYKGMr4eisRjKUalLD4itUjOlWxEKjp1mpYOn9Wp qlVUKsKlrL2l
N0pK/wBXfs1/tGR/Gb4kWXgD4l/sM+EvgnHqXw48X+PLPVtY8E/FiykS68Je IvhzoMvh2ey+
Nf7If7Plhfz6hH8QGvorzwlrnit9OGg3MOs6fp8eqaTdXP3r/wAIn8IP+iY/ Db/wifC//wAr
K+N7GTxTN430fx746+NfxI+KWreHfCvivwj4ftPF2kfBrQ9L0jTvGur+CtZ8 QXMUPwu+E/w6
u73ULq58AeHYoZdXvdRt7O3iu0tbWKS8llr5G+C0Vt8f/FXjX4yfF3x18a7P 4p/Cz9pb4weA
tN+Gfgv9oT46/CD4cfD3wd8Hfi9r1n8DtH8VfAr4bfEfwh4N8af8LS+ENp8P P2gfEGofHPw5
8QdU+KWj/GmC7s71v2edV+Evw88J9VTgulVrRTyDLcDOvObo4WjOdejCjSjS dSU8TiKU6kqz
nOThSjDWnFNv3KtQnDZ9WpYdKrmuKxcqaSq4icKdKc5znU5FGjRlCEYKEYqU 9Pfvp70Iv9gf
+ET+EH/RMfht/wCET4X/APlZR/wifwg/6Jj8Nv8AwifC/wD8rK/nWv8A/gpB +1Ynw8/Z58WW
lx8AI9T/AG3fht8DPi/8E4Lj4VfEW4sf2cvD/wAU/wBqL9hv4K6x4K+K0UXx 7tbj9pXWtM8I
/tuWeoad408I3P7L9ifEXwlvLu58Ey6b8Q4dJ8Amvf8ABSD9qzR7TQtCjuPg BP4r+KfxJ8V/
CDwD4if4VfEVPD3w/wDEHwD/AOClH7NH/BOT4u+NfGPhNfj2dS+JWjfGC8+O +rfHL4beC9F8
Z/C2++CFl4dsPhX4n8bfHue9uPibF5kuHslj7S+Aj+6w9PFVP9koe7RrcnsH 8Wrre2w3Ilfl
+s0va+z5MR7H0VmeOfLbEy9+rKjH99PWpT5vaLbTk5Kt27X9jPk5ual7T+in /hE/hB/0TH4b
f+ET4X/+VlH/AAifwg/6Jj8Nv/CJ8L//ACsr8IPE/wC3P+1JA/jP4A+BrfwV 8RP2tPhr8ZNd
8MX9x4A+Attq3g74k/CLwv8ABH9nf4veMPiJpHwx+Ln7df7O+kfC8+DNa/a5 +Cfwyv7LUv2s
Pif4l8RanbX3i/w34EudA8SeILX4N+beD/8AgqR+0v8AEX4G/Fj9ojw18KPh lb+FrXV/2L/h
18Gvhtpl5q/i/wCJ+pfE79t34U/sJeLdHHiS/wDEvi74N/DzWNF+CPiL9qfX zDYP4o+HEX7Q
sN1oHhfU/GH7K0Hw/wBW+I/xRqfDeTU5ThPAJTh9Y5ksDCdp4SjUrY2lzU1O DqYSFJ+1ipPm
dSj7B1lVpuUxzXGySlHEtxl7KzeI5bxrzhTw87T5ZclaU/cdvd5antOTklb+ ij/hE/hB/wBE
x+G3/hE+F/8A5WVy+vXn7NfhXUfD2j+J9A+B3hzV/Ft6dM8KaVr2keAtH1Hx PqInsrU6f4es
dQt7e51q9FzqenWxtNNiuZxPqFlD5fmXUCyfnt+yJ+0d8a/if4K8c237Qng7 RvA3xP8Ahv8A
Eq68B6rZ6VdfDrT7zV7C58C+AviLo+teIfht8N/2g/2ptO+DusnT/iBDpEPg jW/jv458Qa7o
GkaH8WmHhjRPibofg7w/9R6Fr0GtfFjwgIP+EPf7P4O8fn4rP8S20j/hV6fs oy6j4D/4aPX4
gjXydPOkPp0fgs6H9hH9pjx0nhH/AISEj4OH4uhozfhfBZbkWKzqOXYSMcNT jUdLHUY4XVYi
FGph53puUcRKTlRoQs1VxLpwi5RmpOsFm9bFZjRwDxVeUq03BTw9T2+jpynG orSSdJJKpUld
OFJTk0nFo9mu7z9muw8VaZ4EvtA+B1n431qyk1PR/Bt3pHgK38Vatp0SahJL qGmeHprdNXv7
KOPSdVkku7WzlgRNN1BmkC2dyY49a8GfC6bxZ8N4bD4d+AoP7S8Sazo2pQQ+ EfDwtbzSpPA3
irXminsv7PNo9xFq/hzRri11Dyf7Rso4ruytLuCx1bV7a+8i8d6v8L7VfhDq nwhlW4/Z/Xxj
r48OXN9N46k+KA/aubwX42g8RN8dn+LbH4zvq4/Z4KxfCH/hKWbTF8CnXB4k H9kj9msru+Ef
Eg1j4k/DO2DlvL8Sa3PjOfu/DrxzHnr/ANNa+RzHJsLmXAvEed08vweG+pvF UoU6cYTxGGeG
lh7Rxf7qDoYtSn7T2aS5aM6E07z09anj6uEz3Lsvliq9V140pucm1SqqrGp7 1B80vaUbLlU+
tSNSNvdPpD/hUvwq/wCiZ/D7/wAIzw5/8raP+FS/Cr/omfw+/wDCM8Of/K2v QaK/m+77v72f
oN33f3s8+/4VL8Kv+iZ/D7/wjPDn/wAraP8AhUvwq/6Jn8Pv/CM8Of8Aytr0 Gii77v72F33f
3s8+/wCFS/Cr/omfw+/8Izw5/wDK2j/hUvwq/wCiZ/D7/wAIzw5/8ra9Boou +7+9hd9397PP
v+FS/Cr/AKJn8Pv/AAjPDn/yto/4VL8Kv+iZ/D7/AMIzw5/8ra9Boou+7+9h d9397PPv+FS/
Cr/omfw+/wDCM8Of/K2j/hUvwq/6Jn8Pv/CM8Of/ACtr0Gii77v72F33f3s8 +/4VL8Kv+iZ/
D7/wjPDn/wAraP8AhUvwq/6Jn8Pv/CM8Of8Aytr0Gii77v72F33f3s8+/wCF S/Cr/omfw+/8
Izw5/wDK2j/hUvwq/wCiZ/D7/wAIzw5/8ra9Boou+7+9hd9397PPv+FS/Cr/ AKJn8Pv/AAjP
Dn/yto/4VL8Kv+iZ/D7/AMIzw5/8ra9Boou+7+9hd9397PPv+FS/Cr/omfw+ /wDCM8Of/K2j
/hUvwq/6Jn8Pv/CM8Of/ACtr0Gii77v72F33f3s8+/4VL8Kv+iZ/D7/wjPDn /wAra8Y0K00j
xhBqup+Bf2HfFXjTw3pvi7x14Mg8UaVpf7J+laXq+qfDvxrr/gDxJPptj4v+ NvhnxJHYR+JP
DOr29nLq2g6XcXVvDHdrarDPEzfVFeKar+zX+zpruqalrmufAH4KazrWs395 qur6vqvwr8C6
jqmq6pqNxJd6hqWpahd6FNd31/fXc011eXl1NLcXNxLJNNI8jsx2ozoxk/bx q1I20VOqqbUr
7tyhUTVr6WWut9LNNy6St63f6oyPAeg/DHxpP430zU/2fNM+HniT4eeLoPBn ijwv4z8J/Ce7
1S01S78F+DvH9jPBfeANf8deG7ywvPDfjrQbiKW3157iK4e6tLu1tprZlbm/ jXe/B74KaL4Y
1Sb9nLUfifqXjDxdH4M0Dwd8HvhD4X8a+NdQ1RvDHijxfcT23h530qe6sLDQ vCGs3moS2Ulz
cWsMIuHtfscd3c23vHgzwB4D+HGlz6H8PPBPhHwHot1fy6rdaR4M8N6N4X0u 51Se3tbSbUp9
P0OysbSa/mtLGytZbySFriS3s7WF5DHbxKnyD8fP2TfDvxl+Mlz8Q/G/wH+G fx20X/hWfgfw
Z4etfGf7QXxh+B+qeEdU8PeKfibrniOeCH4Y/D3xhaeJLDxJaeMPDUcUurXt rcaVceHrpLa1
8vUJZZKpKjUxFpTdGg23epKUmorVRcoQb5ntzKna+vKlsOUktG2/J2v97/X5 no3wUvfg98a9
F8T6pD+zlqPww1Lwf4uk8Ga/4O+MXwh8L+CvGun6ovhjwv4vt57nw8j6rPa2 F/oXi/RrzT5b
2S2uLqGY3CWv2OS0ubn+aT/g7gtLTQP2Bfhx4U0S1t9K8NWX7X/7PuvWGh2M MdtpmnanrvwY
/bZsNXl0yziVYdNt7+Hw7pU0+n2K2+nHUUvtWW0XVdX1e8vv6iv2b/gvZfAn 4S+E/BWXuPE6
+HvBjfEDVf8AhJvFPiq11rxr4f8Ah94Q8B319pF94uup9QsvD1tpfg7R9H8N aHZ2mi6Novh/
S9N0/S9A0e3hFnH/AC+/8He//JkvgH/s6f8AZn/9VL+3rX4J9Kdxf0Z/pHcn N7P/AIgV4u8n
M7u3+oPECV+l7dj+fvpaNv6Kn0mru/8Axz54zff/AMQ64j2P6jfGvi74ReNv D8mgXHxh8KaH
nVfDmt2ur6H408Ef2pp+p+FfEmk+KdIubVdbXWtJk8vVdGszPBf6Ve289t50 LxfvA6+J/wDC
vPgN9r0m/wD+F9+F/t+gNozaFe/2V+yT9r0VvDkNnb+Hm0m5/wCFNedpzaDb 6fYQaMbN4Tpc
NjZxWPkJbQqnW/CH4Q/DvxR8O/D2u674e+3arff2t9quv7W1y2837Nrmp2cH 7iz1O3tk2W1v
DH+7hTds3vukZmb0n/hQPwk/6FP/AMrvib/5c1/Y9f8AsPhDMM2yChxnxdQq ZbmmPwOM+p8H
ZNPD1cXg60sFXq0p1uNYVZ0pvDL2bnTpydNRcqcJNxX6tSnj84w2DzCWR5RO OKwmHxFH2+eY
xVYUa9NV6cZqHD8oKcVU95RlJKV0pSVmL4T8b/B3wd4V8NeEdM+KXgm403wr 4f0bw5p9xf8A
jfwtLfz2Wh6dbaZaTXstvd2tvJdywWsb3MkFrbQvMztFBChWNX6v4y+AniDU PC+ra94q+EOt
6p4H1248UeCtS1fXPBmpah4Q8TXfhnxF4KuvEXhe8vLqa48P67c+DfF/i3wl cavpMlpqE3hn
xR4i0GS4bStb1K1uY/8AhQPwk/6FP/yu+Jv/AJc0f8KB+En/AEKf/ld8Tf8A y5r5qeH4HqTn
UnxJxdKdSUpzl/qbk95Sm25t247XxNu/TU9NVs9ilFZXlCUUkl/buN0SVkv+ Sc6I8s1r4cfs
J+JPBN/8NfEXgP8AZK1/4c6r4F+Gvwv1PwBrXhf4O6r4J1H4Z/BjVtR1/wCD 3w7v/Ct9Yz6F
eeBfhRrusavrXw18I3FhJoHgXVtV1HUfC+n6VeX1zNLheC/gh/wTt+HHib4e +Nfh58If2LfA
XjH4R6FrPhf4UeLfBfgD4G+F/E3wx8M+I9Q8Y6t4h8O/D3XtD0mx1TwXoWva p8RPiBqWs6R4
butN0/VNQ8c+Mby+t57jxNrUl77h/wAKB+En/Qp/+V3xN/8ALmj/AIUD8JP+ hT/8rvib/wCX
NH1fgizX+svGFne6/wBT8os7rld1/r5rePuu/TTYfts+/wChXlH/AIfcZ/8A Q4eH+KPgh/wT
t8ceGfEXgrxr8If2LfF/g7xf8V9X+PPi3wl4o8AfA3xB4Z8UfHLxBp9xpOvf GbxFoOraTd6X
rfxX1vS7u603V/iJqVrc+L9S0+5uLO81ia3mkjb3TSPGXwE8P6h4o1bQfFXw h0TVPHGu2/ij
xrqWka54M03UPF/ia08M+HfBVr4i8UXlndQ3HiDXbbwb4Q8JeErfV9Wku9Qh 8M+F/Dugx3C6
Vomm2ttH/wAKB+En/Qp/+V3xN/8ALmj/AIUD8JP+hT/8rvib/wCXNJ4bgeSs +JOL2tdHwdlD
Wtr78edbK/ouyD2+ff8AQryj/wAPuM/+hw4nV9A/Y48QfFvwv8f9e0X9mfW/ jx4H0K48L+Cv
jZq+nfC3Uvi34Q8M3cPiK2uvDvhf4kXkM3jHw/oVzb+L/FtvcaRpOs2mnzQ+ KPEUUlu0et6k
tzhfDX4cfsJ/BjSdF0D4PeA/2SvhRoXhvx1qPxQ8O6L8NfC/wd8C6ToHxM1j wTf/AA11f4ia
Lp3hex0qz0rx1qvw51XU/AGo+LrGGDX77wTqN/4VudQl0K8uLCT1P/hQPwk/ 6FP/AMrvib/5
c0f8KB+En/Qp/wDld8Tf/Lmj6twPa3+svF9rKNv9TsotZXsrf6+WsuaVlsrv uw9vn3/Qryj/
AMPuM/8AocOJXQP2OE0/4g6Sui/szrpfxa0LXfC/xV01dO+Fo0/4meGfFHib 4j+NfE3h34g2
YhFv4z0LxF4y+MXxd8W67pHiOPUtP1fxN8U/iPr2oW9xqvjjxNdap83f8Mpf sZXP7a3/AA3f
rPxF+H2s/GPT/wDS/CcX9j/so+Gf+ES19/hN/wAKQufEH/C2PAfwh8JftO/E P7T8NL3xL4e/
4Q/40/H34n/DOy/4Sb+0NK8DafqPgb4TXXw8+x/+FA/CT/oU/wDyu+Jv/lzR /wAKB+En/Qp/
+V3xN/8ALmqjQ4IjzW4l4v8AfjKEn/qbk7bjJJSWvHj+JJJ21aVttA9tn3/Q ryjT/qe4z/6H
Dyz40/Dj9hP9pL/hGv8AhonwH+yV8fP+EM/tn/hD/wDhdPhf4O/FP/hFP+Ei /sr/AISD/hGv
+E5sdd/sL+3f7C0T+2f7L+y/2n/Y2lfbfP8A7PtPJ3fGmgfscfEfwz8QvBXx D0X9mfx74O+L
mu6N4o+K/hLxpp3wt8UeGfid4m8Oaf4O0nw94i+IWg65DfaX4013QdL+Hfw/ 03RtX8SWupah
pen+BvB1nY3EFv4Z0WOy7b/hQPwk/wChT/8AK74m/wDlzR/woH4Sf9Cn/wCV 3xN/8uan6twO
lFLiTi9KPwr/AFOyi0dVL3f+M8095KWnVJ7oPbZ9/wBCvKNd/wDhdxn/ANDh 4fbfBD/gnbZa
f8HtJs/hD+xbaaX+zxrup+KPgBptt4A+BsGn/A3xNrfiax8a6z4i+D1nFpKW /wAM9d1fxlpe
m+LdT1fwVHomoX/ibTrHXrq4l1W0t7qPyj4G/spfsZfAf9pj4wftZ+HPiL8P tV+Mfxg/4WBa
Xmtf2P8Aso/DX/hHNA+Kfj/SPiV4+8P/ANo/AH4Q/B3xT8Wf7f8AFPhfwXd/ 8Jh+0r4k+Ofx
M0n/AIRXz9B8c6XqPjf4qX/j77H/AOFA/CT/AKFP/wArvib/AOXNH/CgfhJ/ 0Kf/AJXfE3/y
5qvY8EpSj/rLxfaaalfg7J3dN8zV3x42uZtuVmua75r3YvbZ7/0K8o/8PuM/ +hw6H/hbXwq/
6KZ8Pv8Aws/Dn/yyo/4W18Kv+imfD7/ws/Dn/wAsq57/AIUD8JP+hT/8rvib /wCXNH/CgfhJ
/wBCn/5XfE3/AMuaz+p8Cf8ARRcW/wDiGZP/APR4P2+ff9CvKP8Aw+4z/wCh w6H/AIW18Kv+
imfD7/ws/Dn/AMsq8m8OeK/hP4i+BeheAvEPxJ8I6VHrnwm0vwhrkUfjDw1Y 6zpqan4Pg0bU
40jvridbPU7MTzqqXlnMtvdRhbi1kCPEe4/4UD8JP+hT/wDK74m/+XNH/Cgf hJ/0Kf8A5XfE
3/y5q4YfgenOM4cR8XRnCcakJLgzJrxnB3i1/wAZ3a6evyE62eyi4vK8ocZK zX9u43VNNNf8
k71TPCdX+HnwG8QKy698e/C+tq730rLq+lfsk6krSapquoa7qcjC9+DUwL6j reraprF85y13
qupahqFwZLu8uJpPbPBXi74ReCfD8egW/wAYfCmuY1XxHrd1q+ueNPBH9qah qfirxJq3inV7
m6XRF0XSY/M1XWbwwQWGlWVvBbeTCkX7su1r/hQPwk/6FP8A8rvib/5c0f8A CgfhJ/0Kf/ld
8Tf/AC5r1MwzPhzNaMMPmHGPGeKoU6qrQp1ODMj5Y1VGcOdcvHMWnyzmnrZ3 1V7W5aFDM8NN
1KGSZLSnKPJKUc9x13G6fK78OvS6X3HE2OgfscaXp+maTpui/sz6dpeiaF8H vC+jabY6d8Lb
TT9I8M/s8eJrnxr8APDumWdvDHb2GhfA3xle3ni34PaRaxxaf8M/E13c694K t9E1WeW6fyjU
f2aP+CY+sat8Stf1f9n/APYQ1XXfjP8Ab/8AhcOtaj8Kf2fr7Vviv/avjbRf iVqf/CytRudB
lvPHX9o/Ebw34d8f3/8AwlE2q/bPG2gaL4quPM13SrG/g+jf+FA/CT/oU/8A yu+Jv/lzR/wo
H4Sf9Cn/AOV3xN/8ua8tYfghXa4l4wTertwflCva2/8AxnvkvuXY6/b59/0K 8o/8PuM/+hw4
m20D9jiy1D4PatZ6L+zPaap+zxoWp+F/gBqVtp3wtg1D4G+Gdb8M2PgrWfDv wevIoUuPhnoW
r+DdL03wlqekeCpNE0+/8M6dY6DdW8ulWlvax4Xw1+HH7CfwY0nRdA+D3gP9 kr4UaF4b8daj
8UPDui/DXwv8HfAuk6B8TNY8E3/w11f4iaLp3hex0qz0rx1qvw51XU/AGo+L rGGDX77wTqN/
4VudQl0K8uLCT1P/AIUD8JP+hT/8rvib/wCXNH/CgfhJ/wBCn/5XfE3/AMua X1bgezX+svF9
no1/qdlFnrJ6r/XzXWUn6yk+rD2+ff8AQryj/wAPuM/+hwxviVdfsvfGfwTr Xw1+MNx8BPiv
8OfEn9nf8JF4A+JU3w88deCdf/sfVrDX9I/trwr4obVdC1X+ytd0rTNa077d YT/YdW06w1G2
8q8s7eaPhdO+HH7Cej+Nvhr8StI8B/slaV8Rvgx4FsPhf8HvH+neF/g7Y+Nv hR8M9K0nWtA0
z4d/DXxVbWMWu+BfAunaF4k8RaLYeEfC9/pWgWek6/rWnW+nx2eq30M/qf8A woH4Sf8AQp/+
V3xN/wDLmj/hQPwk/wChT/8AK74m/wDlzQsNwOk4riTi9Rd7pcHZQk7qzulx 5bVaPutGHt8+
/wChXlH/AIfcZ/8AQ4cS2gfscPp/w+0ltF/ZnbS/hLoWheF/hVprad8LTp/w z8M+F/E3w48a
+GfDvw+szCbfwZoXh3xl8HfhF4t0LSPDkem6fpHib4WfDjXtPt7fVfA/hm60 vwv9qv8AZ0/Z
C/az8B3ngLxb49+EPhC31n4r6J8Z/FWtaR8P/wBiv4q6h4y8eeH/AIdS/CjT dc8UaH+1P8C/
2h/AWo67B4Bi0Hwtb+No/Blt8RdP8M+E/DvhHSfGWn+DodR8Pan9Vf8ACgfh J/0Kf/ld8Tf/
AC5o/wCFA/CT/oU//K74m/8AlzVRocERkpR4k4vum2r8G5O93d6PjxrV6u61 eu4e3z7/AKFe
Uf8Ah9xv/wBDh5Z4P+H37FPgX4Z2nwe8P6b8BG+HNv8AAvwN+zJd+HfEGr+E /GP/AAkn7P3w
10DxB4X8DfCHxzq/jDUdd134g+BfDuheLvGFjaaH451PxDbS/wDCY+MLm7Fx eeK/EFxqPC/8
M0f8Ex/+FZ/8KW/4Z/8A2EP+FOf8J1/wtD/hU3/Cqf2fv+FZ/wDCzP7A/wCE T/4WJ/wgf9g/
8It/wnX/AAi3/FNf8Jd/ZX9v/wBgf8Sb+0P7O/0avo3/AIUD8JP+hT/8rvib /wCXNH/CgfhJ
/wBCn/5XfE3/AMuaXsOCU2/9ZuMLt8zf+p+UXbWzf/Ge6vz3D22ff9CvKO3/ ACPcZ/8AQ4fH
H/DKX7GVz+2t/wAN36z8Rfh9rPxj0/8A0vwnF/Y/7KPhn/hEtff4Tf8ACkLn xB/wtjwH8IfC
X7TvxD+0/DS98S+Hv+EP+NPx9+J/wzsv+Em/tDSvA2n6j4G+E118PPuj/hbX wq/6KZ8Pv/Cz
8Of/ACyrnv8AhQPwk/6FP/yu+Jv/AJc0f8KB+En/AEKf/ld8Tf8Ay5onh+B5 8vPxHxdLkgoR
vwZk3uwje0VbjvbVvzbberD22fL/AJleUf8Ah9xn/wBDh0P/AAtr4Vf9FM+H 3/hZ+HP/AJZU
f8La+FX/AEUz4ff+Fn4c/wDllXPf8KB+En/Qp/8Ald8Tf/Lmj/hQPwk/6FP/ AMrvib/5c1H1
PgT/AKKLi3/xDMn/APo8D2+ff9CvKP8Aw+4z/wChw/NX4mWK+MdY8WjR/FWp 6Mq/Fi78Z+HP
FPhWbQr25tNR8KfFUeN/DWr6X/bmleI/DeoWzapo2nXDR6ho+qadqFi8sbwy RzhxW8Ral8Wv
HV94Rn+JPx6+I3xD03wT4juPFuieH9Z8N/A7w/pY8QT+E/FHgxL+8uvh38H/ AAT4guVttE8Y
a2sFmdcSwa6mgubm1uHtYQv6Z/8ACgfhJ/0Kf/ld8Tf/AC5o/wCFA/CT/oU/ /K74m/8AlzX9
CZZ4yeF2Cy/h7DYzh/iLMsdw9lWT5bh8yq5Pk1OrJ5NSpxw+IhTfENX2DWIh LE06ftavsak3
apNrmf5ti+CeLMRiszr0MwyzC0czxmNxVTDQxmNnGKx05upSdT+zIOa9nP2U pcsFOKvyRvY/
N/7Rcf8APeb/AL+v/wDFV5D4u+AnwL+IHj7wx8VvHvwX+E/jb4o+Cf7F/wCE M+JPi74c+D/E
nj7wj/wjetXPiPw7/wAIx4w1nR73xDoH9geIb2817Rf7K1G0/srWru51Sx8i +nlnf9fv+FA/
CT/oU/8Ayu+Jv/lzR/woH4Sf9Cn/AOV3xN/8ua+mq/SM8P60VCtknE9WKlGa jVy3JKkVOLvG
SUs8aUovWMrXT1TPLh4Z8SU3zU8wyuEmnFuGLx8W4vRq8cAnZrRrZ9T8gdG+ AnwL8Oal4z1n
w98F/hPoOsfEfxf4d+IXxD1XRvhz4P0vUvHnj7wf4sl8e+EvHHjO+sdHguvF Hi/wv45nn8Z+
HfEuuS32taJ4sml8RaZe22sSPeHkfi7+yv8AAv41+DU8B+M/h74UPh7/AIS7 TvFt5bWHhPwe
Rqu749eAf2kPHvhnVodV8ParY33hH41/FH4b+HdX+N2jS2f/ABchhdX+s3P/ AAkIsddsf2s/
4UD8JP8AoU//ACu+Jv8A5c0f8KB+En/Qp/8Ald8Tf/LmsZ/SE8OKlGpQnw9x G6NWnUpVKX9l
ZGoTp1ZSnUg4rO0uWc5SnJdZyc37zuaR8OeKYVIVY5nlqqQnCpCf1zMOaM4J RhJN4DeMUop9
IpR20Pxp1P8AZj/Zt1r4aeHvgxrH7PfwP1b4PeEtYn8Q+FPhPqfwn8BX/wAN PDGv3MuuT3Ou
eHvAl1oEvhfRdYuJ/E/iSafU9N0q2vZZfEOuSSTs+rX5uOv0z4S/CrRfB3iH 4d6P8M/h9pPw
/wDFujweHvFfgXTPBnhyw8HeJ9AtvA+h/DG20PxD4ZtdNi0XWtHt/hr4Y8N/ D2DTNSsbmyi8
D+HtD8JxwLoGk2Gn2/6z/wDCgfhJ/wBCn/5XfE3/AMuaP+FA/CT/AKFP/wAr vib/AOXNVH6Q
/h1F80eH+I4tU40bxyrIk/ZQg6cKV1nd/ZxhJwjD4Ywbikk2iX4b8TtWeZ5a 1zudnjcwa55S
UpTs8D8bklJy3ckm3dH5YeAvA3gn4V+E9K8BfDDwd4W+HHgbQft39h+DPAXh /SfB/hPRv7U1
K81nU/7K8O+HrTTtH07+0dY1HUNVvvsdnD9r1K+vL648y6uZ5X0dW8PaBr97 o+pa7oej61qP
h26N94fv9W0yy1G90O9MtrObzR7q8gmn0y6M9jZTG4spIJTLZ2sm/fbxFP0+ /wCFA/CT/oU/
/K74m/8AlzR/woH4Sf8AQp/+V3xN/wDLmql9Irw9lRjh5ZFxLKhFU1GhLK8k dGKpOMqSjTed
8iVKUISppR9xxi42cVaV4a8SqbqLMcrVSTk3UWLx6m3NNTbn9Q5m5qUlK795 Np3uz8wbjw9o
F3r9j4rutD0e58U6ZavY6b4luNMsptf0+ykW8SSzsdYkgbUbS1dNQv0e3guY 4mW+vFKEXMwf
174S65p+jfFPwJqevaxZ6TpVpqOum51DV9QgsdPtjN4K8UW0Bnu72aK2hMtx NFbxGSRfMmlj
iTLyKp+4P+FA/CT/AKFP/wArvib/AOXNH/CgfhJ/0Kf/AJXfE3/y5rweJ/HD w/4i4ezrIaeX
8UZa86w9SlVxlPJslrOFWo6d8ROhHiLD+3qctKMW5VoSaUU52ikejlPAfEeW ZngcxnicqxSw
NRSjQljsdT5oJTtTjUeWVfZxvNyVqckm37t22dD/AMLa+FX/AEUz4ff+Fn4c /wDllR/wtr4V
f9FM+H3/AIWfhz/5ZVz3/CgfhJ/0Kf8A5XfE3/y5o/4UD8JP+hT/APK74m/+ XNfzr9T4E/6K
Li3/AMQzJ/8A6PD9M9vn3/Qryj/w+4z/AOhw6H/hbXwq/wCimfD7/wALPw5/ 8sqP+FtfCr/o
pnw+/wDCz8Of/LKue/4UD8JP+hT/APK74m/+XNH/AAoH4Sf9Cn/5XfE3/wAu aPqfAn/RRcW/
+IZk/wD9Hge3z7/oV5R/4fcZ/wDQ4dD/AMLa+FX/AEUz4ff+Fn4c/wDllR/w tr4Vf9FM+H3/
AIWfhz/5ZVz3/CgfhJ/0Kf8A5XfE3/y5o/4UD8JP+hT/APK74m/+XNH1PgT/ AKKLi3/xDMn/
APo8D2+ff9CvKP8Aw+4z/wChw6H/AIW18Kv+imfD7/ws/Dn/AMsqP+FtfCr/ AKKZ8Pv/AAs/
Dn/yyrnv+FA/CT/oU/8Ayu+Jv/lzR/woH4Sf9Cn/AOV3xN/8uaPqfAn/AEUX Fv8A4hmT/wD0
eB7fPv8AoV5R/wCH3Gf/AEOHQ/8AC2vhV/0Uz4ff+Fn4c/8AllR/wtr4Vf8A RTPh9/4Wfhz/
AOWVc9/woH4Sf9Cn/wCV3xN/8uaP+FA/CT/oU/8Ayu+Jv/lzR9T4E/6KLi3/ AMQzJ/8A6PA9
vn3/AEK8o/8AD7jP/ocOh/4W18Kv+imfD7/ws/Dn/wAsqP8AhbXwq/6KZ8Pv /Cz8Of8Ayyrn
v+FA/CT/AKFP/wArvib/AOXNH/CgfhJ/0Kf/AJXfE3/y5o+p8Cf9FFxb/wCI Zk//ANHge3z7
/oV5R/4fcZ/9Dh0P/C2vhV/0Uz4ff+Fn4c/+WVH/AAtr4Vf9FM+H3/hZ+HP/ AJZVz3/CgfhJ
/wBCn/5XfE3/AMuaP+FA/CT/AKFP/wArvib/AOXNH1PgT/oouLf/ABDMn/8A o8D2+ff9CvKP
/D7jP/ocOh/4W18Kv+imfD7/AMLPw5/8sqP+FtfCr/opnw+/8LPw5/8ALKue /wCFA/CT/oU/
/K74m/8AlzR/woH4Sf8AQp/+V3xN/wDLmj6nwJ/0UXFv/iGZP/8AR4Ht8+/6 FeUf+H3Gf/Q4
dD/wtr4Vf9FM+H3/AIWfhz/5ZUf8La+FX/RTPh9/4Wfhz/5ZVz3/AAoH4Sf9 Cn/5XfE3/wAu
aP8AhQPwk/6FP/yu+Jv/AJc0fU+BP+ii4t/8QzJ//o8D2+ff9CvKP/D7jP8A 6HDof+FtfCr/
AKKZ8Pv/AAs/Dn/yyo/4W18Kv+imfD7/AMLPw5/8sq57/hQPwk/6FP8A8rvi b/5c1xNx4C+A
cPiY+D4PBnirWNfTzRcW3hnw98YfFlpYPBp9jqk8Oqax4ZtNW0bSrmDT9V0a 6mtdS1C1uIot
e8P+ZEra/owvtaWW8FV5ONHPOMq0lFycaXBOU1JKKaTk1DjptRTkk29LtLqi J4vO6aTqZdks
E2opzz/FxTk72inLh1Xbs7Ja6M9X/wCFtfCr/opnw+/8LPw5/wDLKj/hbXwq /wCimfD7/wAL
Pw5/8sq8ot/AXwDm8TDwfP4M8VaPr7+ULe28TeHvjD4TtL959PvtUgh0vWPE 1ppOjarcz6fp
Ws3UNrpuoXVxLFoPiDy4mbQNZFj23/CgfhJ/0Kf/AJXfE3/y5oq5bwVQko1s 84yoycVJRq8E
5TTk4ttKSU+Ok3FuLSa0umujCGLzuom6eXZLNJuLcM/xckpK14tx4ddmrq6e uqOh/wCFtfCr
/opnw+/8LPw5/wDLKv5L/wDg7c8ReH/E37DXgW/8N67o/iCxi/av/ZqtJbzR NTstVtIruP4Q
ft3zPayXFhPcQpcJDPBK8LOJFjmicqFkQn+q/wD4UD8JP+hT/wDK74m/+XNf x9f8HQ2n2mk/
sKy6Vp8P2ew039v34KafZQeZLL5NpZ/B79t62tofNmeSaTy4Y0TzJpJJX27p HZyWP4P9KvJO
Hqv0TPpP5nkudZzi6uV+Bficq2GzTh7A5XTqU8dwPxFQjKliMJxLnEnOnKPM 4Tw8Yyi9KiZ/
P/0sMfmMPow/SQwmNwGCoRxf0e/G7kq4XM6+LlGWH8NuIqjU6VXKcCrSTspK q2n9ln9gvwC/
5JL4T/7j3/qTazXsVeO/AL/kkvhP/uPf+pNrNexV+5ce/wDJdcaf9lZxH/6u MYf0Fw9/yIMj
/wCxPln/AKhUQooor5M9gKKKKACiiigAooooAKKKKACiiigAooooAKKKKACi iigAooooAKKK
KACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAoooo AKKKKACiiigA
ooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACvg3xJ4s8RaB8X/iJd +BtaltPH6/FS
88EeG9Bj0jQtV/4SeLxX+z98AfHGt2MU/ifx18NvDmjXen6X8MJdbj1DXfGO m2M1np1/pVrD
qGu6lotjcfeVeF+M/wBm74Q+PfFDeM/EOieIk8SPdQahJqPhv4kfEzwSsmqW 2ht4Yi1p7HwX
4v8AD+nPrv8AwjTDw5JrrWh1efQEh0ae9k02CG2T6ThnMsryzF42tm1HG16N XLa9DDwwM/ZV
frjrYarR9pWjicLVoUJKjOnWrYeo68IzvThJ7eZmmFxWLpYeGEnRpzhi6VWp KuuaPsVCpCpy
QdOrCdWPPGdOFSKpylG02lo/nbwf451fxf8AFn4fal4u16XUfHKfF4/DvxPo smi6Lo//AAi8
vgL4F/tD+JrHTJZfDnjj4jeHtZu7qD4ivqsmp6D4v1TTltLyx0+VLLWdP1e0 i+4PFFv4mu/D
PiK18FavoXh/xjc6Fq9v4S17xR4d1Dxf4Z0TxNNp9xHoOr+IvCWk+KPA+qeK NC03VGtbzV/D
um+NfCGoa3p8Nxptn4o8P3FzHq1p+fvhT9lr4pfDPxJB4h+G3gT4Eadc+GNU +Olx4EbXfjT+
1Frun2EMfgCHwL+zHqWpeFtZ1HWPDZ1RdAn1HwZ8Y7eK0uE0DwrFpcvwy1Ke S1j0i3/Qjw82
vvoGhv4rh0i38UNpGmt4kt/D1ze3mgQa+1lCdYh0O81K1sdRutIi1E3Cabc3 9jZ3s9ksMt1a
287SQp38YVMpxFbLMVlGJVWlDLMNQxNKrVlVxEcasRjqld2qYjG1JYeKdNQl iMVUr8s6aqc+
s3zZLHGUoYqljKLhOWLq1aUoRSpOg6eHjC9qVCKqt87lGnRhTupOCirRXxd+ wnf/APBRnWfB
PjvV/wDgo3p37KPhbx1/wnWs6B8OPBf7K+i/Ej+yYPBPhbVtY0ZfH/ivxj8Q fiV4z/tn/haf
kWPijwR4V07w74W1bwZ4J/sq48ezf8J14p134e/Cz+Yz/g6X/wCTJdU/7SE/ B7/1Uv7cVf2t
1/FJ/wAHS/8AyZLqn/aQn4Pf+ql/bir8G+kfPn+h99L6fLCF/Anjz3YLlhH/ AIxHiRWirvT1
bb3bbPwL6YH/ACjV9ID/ALR88d//AF2PEB/Ux+z3aftK+OvBepwfCuD4GxeF fBfie98JiT4g
X/j6z8QXOoz6VovjK8mMfhzTNT057JR4vht7aQSW85NvKktt8i3Fx7t/wrb9 t30/ZW/8HXxb
/wDmZq7/AME9f+SZfFD/ALLRf/8AqrvhVX3xX9b8c5blMeMuJ3LK8NUnPPMy rVKk6+YqU6tf
FVK1WbUMdCCcqlSUrQhGKvaMUkkftPDU8VUyDJ5fXK0UsBh4RjGlguWMKVNU 4RTlhJSfLCEV
eUpSdrybbbPz6/4Vt+276fsrf+Dr4t//ADM0f8K2/bd9P2Vv/B18W/8A5ma/ QWvIfjl4h1zw
z8Pvtvh3V7jQNT1Lx18I/CX9t2VrpV7f6Vp3jv4teCPBGtX2m2+u6fq2jNql toviHUJNMfVN
K1Owhv1t57rT7yGN7eT5mllWU1qtOlHKcGpVakKacsRmvKnOSinLlx8nZN3d ot22Teh7FWeI
o0qlWWNxTjSpzqNRpZfzNQi5NR5sJFczSsrySvu0tT5NtvAf7a91NfwRR/sw q+m3aWVw1zd/
GqzhkmksbLUVewuLvwjBb6raC3v4I3v9LlvLGO+jvdLkuV1PTdRtLW3/AMK2 /bd9P2Vv/B18
W/8A5ma8Y8B/td+C/FHjHSdM+GPxC/bauPE2sfED4WyeItO/aF/YK+Jv7NXg LxLpPiT4m/DT
4V+IGvvHfxW/Yo+AllrniyDwzr9pDoWjaD47fxg9ro8GoQ6XfeGPC+spafqX pXifTdZmhgtL
bxDC89ob1G1Xwj4r0KFYRY6BqJSa41vRdPt7a7+z+JdOjFhcSxXzX1tr+lrb HU/Cnim00Z1M
qyaEIVI5fl1aM6lWkpUq+cxtOkqUpRar4ulK/JWpu8U4ttq900KnUxVSU4PE Y2lKEKc2qlLL
HeNR1IqSdLD1Y25qU1ZtNW2s7n5UfDD4m/Gv4z+JPEnhH4ZfEH9kLxVr/hWK W61Cyt73462E
WoaXBqMmkT6/4T1HV/A+n6Z478L2+prFZT+KvBF54h8OQT32lLLqiDWNKN57 n/wrb9t30/ZW
/wDB18W//mZr87dT0nw5/wAE4fFn7TXxK+CHwX8b6+nhn4neE/gX4b+KHjDU 9G8T/Br4DfCv
xp8MPhH8ZNY8M6n4d0rxv4S+JOrSXfjDVNC8LWGt+KhbaHa6f/wrLT5vioNZ std0Xxd+y/7L
Pxc8S/Hf4A/Db4teL/B0/gXX/GWk315d6FNb39pDcW9jrmq6PpfinSbTU1/t C18OeO9K06x8
c+F7a7nv5rfw54i0uFtW1jYNVvPGwVPL3WeX5jk2XQzOFD65OGErZ1PCrC1a 04YdqvVxyi6r
goOrT5uZSbaildR+cyTO8zxGJnk+c4r2GfUcPUxtahgcPSlglg1iFQpzhiK+ BtKo3ODspSjU
jK8eWpTxNDDfPX/Ctv23fT9lb/wdfFv/AOZmj/hW37bvp+yt/wCDr4t//MzX o3iP46fFPRP2
+vg3+zR/wi3w/T4JfE39kD9pb46f8Jr/AG34ivfinP8AFP4GfGj9k7wB/wAI t/wjn9kab4S8
M/D+08JftEf2t/bf9veM/EXjjxHe/YP7I+GWmfD37Z8W+g8bftOweHfj7of7 Ongj4L/GD41+
Nk8P/Dbxz8WNU+HE/wAGtG8K/s+fDP4veNPHPgX4c/En4nX3xk+MHwn1fxL4 f8S6v8J/jHcL
ofwG0P40/ELSNO+FfiCbX/BOk3PiP4aWnjz1P7Oyj/oUYT/wfmf/AM8D6i2J /wCg7Ef+CsB/
8xnjP/Ctv23fT9lb/wAHXxb/APmZo/4Vt+276fsrf+Dr4t//ADM18zfsMf8A BTTW/Gf7F/wF
8dftVfC34weBfjJqP/BODRP20Lnxj8R9W/ZH8HeFf2rPCvwq+FPwj1j9oj4v /DHxD4L+PzfC
n4OeH7bxT8XPhnqjWX7UV3+ybp2mad8XvD99Ho+h+G/BvxVl+GXQfC//AILJ fB39oD/hA9I/
Zk/Z6/aA/ae+IHi3/hff/CR/D74F/EH9hPxb/wAKv/4Z3/4ZluvGv/CU/GK8 /bS0X9mXxr/a
Gi/tgfAHW9E/4UN8dPjH9k/4S3V/C3jH/hEviB4D8f8Ag/wyf2dlH/Qown/g /M//AJ4BbE/9
B2I/8FYD/wCYz3n/AIVt+276fsrf+Dr4t/8AzM0f8K2/bd9P2Vv/AAdfFv8A +ZmuFH/BVn4J
+IP+EG8U/CL4SftAfHP4C+L/AIgfsf8Awt1n9pnwBpPwi8N/Cz4b+O/25P8A hn3UfgFoXjXw
f8avjL8Jf2jb3+1fBn7Vv7Ovj/xHqfw7+BHj3R/DXh34o2el3uoN468I/Efw d4M+YLL/AILv
fs1fHjwX8UPD37ImreH/ABH8dtU8P+AbL9lr/hM/GvwQ+Ifw9+IniD48/H34 N/snfBn4ofFT
wb+z3+0B49+OPwE+D/h744/tL/s/ax8XvAP7Sfg79nT9p+L4Z+KvFcXw/wDg 34n+JPw1+Jng
rwOf2dlH/Qown/g/M/8A54BbE/8AQdiP/BWA/wDmM+2f+Fbftu+n7K3/AIOv i3/8zNH/AArb
9t30/ZW/8HXxb/8AmZqbw7+0vY+Ofi78Rf2Cfhxq37QHxE+JvwO+H/hHwB+0 V+194dv/ANja
w1j9nz4i/ET4Jz+Pfhz41+Ivw28X694X8Qan8QPiB4fl8P8Ajfwj4j+GP7En xE/ZY1bx34in
8IrZxWXw7+M3gX4ac/4M/bN8VXX7Gfwr+N/xDh8P6F8Vl/af+EP7GXxtTwZ4 F1HxZ8PZ/j7Z
/wDBQHwp/wAE8/j3N8K/D+ufFfwX4ktfg/4j+McHji4+EPjrxb4vvPGngv4Z 6p4U+JnjP4Ue
PfFOhav8DvEZ/Z2Uf9CjCf8Ag/M//ngFsT/0HYj/AMFYD/5jNr/hW37bvp+y t/4Ovi3/APMz
R/wrb9t30/ZW/wDB18W//mZqb9kX/goR4O/a2/4VXs+BH7QH7P8A/wANAfAB f2o/2dv+F6J8
Cbv/AIXj8CbT/hVn/CTeOfC3/Cg/jr8dv+EO/wCEO/4Xt8Ef7b8M/GX/AIVf 4xv/APhaGkf8
Il4f8Tf8Iz8R/wDhCfH9W/4K5fCXw9P8Q7vxD+zx+0/ovgn4a+IP2sJ9a+JN zY/s8XnhXUPg
h+wX8ZdX+A/7bX7UOjaTpH7RepfESb4P/s1/ES38KWPiXwjqHgXTP2lfiXp3 xH8J6p+z5+z9
8YrbTfiEfAx/Z2Uf9CjCf+D8z/8AngFsT/0HYj/wVgP/AJjPWv8AhW37bvp+ yt/4Ovi3/wDM
zR/wrb9t30/ZW/8AB18W/wD5maxfE/8AwVA+AXgHUfGGufEjwh8YPAH7Pnhf xB+0n4G0v9rH
WdA8F618GvHfxM/Y+8K/Gnxl+0r8NvCfgrwN8QPF37Udp4g+Fuh/szftMTXO ueOP2dPBnw98
Yz/AvxLb/Djxt4yk8a/Bf/haHyB42/4K8v8As8fH39oe6/a3+E3xg/Zu+Hej fB/9hTRvgb8B
PjX44/YM8H+KvFvxl+NfjT/go/q/xB8Waf8AG2x/asv/ANm7wj4f8SfC79mK ye1tvj9+1L8O
YP7R+Cuq+G/A3ho/ET4keCtD+LR/Z2Uf9CjCf+D8z/8AngFsT/0HYj/wVgP/ AJjPtn/hW37b
vp+yt/4Ovi3/APMzR/wrb9t30/ZW/wDB18W//mZrhf2J/wBunR/21/2hPi7r nwo8Z/8ACQfs
5RfsgfsifEXwJoHl+BNT/wCEZ+LviX9pj/gpV8Dv2hIP+E78B33inw/48+ye IP2YfCvgb/hI
vA3xJ+JHwT1//hX/APwm3wS8XeKPBnjNfG/jD9P6P7Oyj/oUYT/wfmf/AM8A tif+g7Ef+CsB
/wDMZ+fX/Ctv23fT9lb/AMHXxb/+Zmj/AIVt+276fsrf+Dr4t/8AzM1+gtFH 9nZR/wBCjCf+
D8z/APngFsT/ANB2I/8ABWA/+Yz8+v8AhW37bvp+yt/4Ovi3/wDMzR/wrb9t 30/ZW/8AB18W
/wD5ma/QWij+zso/6FGE/wDB+Z//ADwC2J/6DsR/4KwH/wAxn59f8K2/bd9P 2Vv/AAdfFv8A
+Zmj/hW37bvp+yt/4Ovi3/8AMzX6C0Uf2dlH/Qown/g/M/8A54BbE/8AQdiP /BWA/wDmM/Pr
/hW37bvp+yt/4Ovi3/8AMzR/wrb9t30/ZW/8HXxb/wDmZr9BaKP7Oyj/AKFG E/8AB+Z//PAL
Yn/oOxH/AIKwH/zGfn1/wrb9t30/ZW/8HXxb/wDmZo/4Vt+276fsrf8Ag6+L f/zM1+gtFH9n
ZR/0KMJ/4PzP/wCeAWxP/QdiP/BWA/8AmM/Pr/hW37bvp+yt/wCDr4t//MzR /wAK2/bd9P2V
v/B18W//AJma/QWij+zso/6FGE/8H5n/APPALYn/AKDsR/4KwH/zGfn1/wAK 2/bd9P2Vv/B1
8W//AJmaP+Fbftu+n7K3/g6+Lf8A8zNfoLRR/Z2Uf9CjCf8Ag/M//ngFsT/0 HYj/AMFYD/5j
Pz6/4Vt+276fsrf+Dr4t/wDzM0f8K2/bd9P2Vv8AwdfFv/5ma/QWij+zso/6 FGE/8H5n/wDP
ALYn/oOxH/grAf8AzGfn1/wrb9t30/ZW/wDB18W//mZo/wCFbftu+n7K3/g6 +Lf/AMzNfoLR
R/Z2Uf8AQown/g/M/wD54BbE/wDQdiP/AAVgP/mM/Pr/AIVt+276fsrf+Dr4 t/8AzM0f8K2/
bd9P2Vv/AAdfFv8A+Zmv0Foo/s7KP+hRhP8Awfmf/wA8Atif+g7Ef+CsB/8A MZ+fX/Ctv23f
T9lb/wAHXxb/APmZo/4Vt+276fsrf+Dr4t//ADM1+gtFH9nZR/0KMJ/4PzP/ AOeAWxP/AEHY
j/wVgP8A5jPz6/4Vt+276fsrf+Dr4t//ADM0f8K2/bd9P2Vv/B18W/8A5ma/ QWij+zso/wCh
RhP/AAfmf/zwC2J/6DsR/wCCsB/8xn59f8K2/bd9P2Vv/B18W/8A5maP+Fbf tu+n7K3/AIOv
i3/8zNfoLRR/Z2Uf9CjCf+D8z/8AngFsT/0HYj/wVgP/AJjPz6/4Vt+276fs rf8Ag6+Lf/zM
0f8ACtv23fT9lb/wdfFv/wCZmv0Foo/s7KP+hRhP/B+Z/wDzwC2J/wCg7Ef+ CsB/8xn59f8A
Ctv23fT9lb/wdfFv/wCZmj/hW37bvp+yt/4Ovi3/APMzX6C0Uf2dlH/Qown/ AIPzP/54BbE/
9B2I/wDBWA/+Yz8+v+Fbftu+n7K3/g6+Lf8A8zNH/Ctv23fT9lb/AMHXxb/+ Zmv0Foo/s7KP
+hRhP/B+Z/8AzwC2J/6DsR/4KwH/AMxn59f8K2/bd9P2Vv8AwdfFv/5maP8A hW37bvp+yt/4
Ovi3/wDMzX6C0Uf2dlH/AEKMJ/4PzP8A+eAWxP8A0HYj/wAFYD/5jPz6/wCF bftu+n7K3/g6
+Lf/AMzNH/Ctv23fT9lb/wAHXxb/APmZr9BaKP7Oyj/oUYT/AMH5n/8APALY n/oOxH/grAf/
ADGfn1/wrb9t30/ZW/8AB18W/wD5maP+Fbftu+n7K3/g6+Lf/wAzNfoLRR/Z 2Uf9CjCf+D8z
/wDngFsT/wBB2I/8FYD/AOYz8+v+Fbftu+n7K3/g6+Lf/wAzNH/Ctv23fT9l b/wdfFv/AOZm
v0Foo/s7KP8AoUYT/wAH5n/88Atif+g7Ef8AgrAf/MZ+fX/Ctv23fT9lb/wd fFv/AOZmj/hW
37bvp+yt/wCDr4t//MzX6C0Uf2dlH/Qown/g/M//AJ4BbE/9B2I/8FYD/wCY z8+v+Fbftu+n
7K3/AIOvi3/8zNH/AArb9t30/ZW/8HXxb/8AmZr9BaKP7Oyj/oUYT/wfmf8A 88Atif8AoOxH
/grAf/MZ+fX/AArb9t30/ZW/8HXxb/8AmZo/4Vt+276fsrf+Dr4t/wDzM1+g tFH9nZR/0KMJ
/wCD8z/+eAWxP/QdiP8AwVgP/mM/PWb4e/tsW6CSU/srKhlhhB/tn4vNmS4m jt4Vwnhhj880
qJnGF3bmKqCRzV1YftTWMjxXvjD9iy0ljJV47rx38RbeRCCQQ6S6KjKQQQQQ CCCDX6Oat/x6
xf8AYT0X/wBPNhX8/H7Sv7bGueCNc0T4SfA3wFqPx4+ONv4ftPGvjPwVoL3D W/gj4baJaWes
65eeIb6wjupLXxZ4l0Zk0rwLoKQ3V8+pa5oWqXGnanNqngzwl8QPq+FeC8l4 hq42NTL6FCnh
Pql3TrZk5N4l4rV82PkrJYfRJXd3rpY8fOMzxWWRoSjiq03W9t8VPBJL2Xst FbB3u/afgfeG
naV+1drDSpo/if8AY11h7d7RLiPSPGfxM1OSBr+6jsrPz47HQbh4VuLqWOCN 5FVGkbG7gkfx
y/8AByn4iu/GH/BOXwz4tv4Le2vvFP7bH7O/iK8t7QSC0t7vW/gV+2pqdxBa iaSWYW8U1y8c
IlllkEaqHkdssf6tv2SPjx4L+Omi6d8Tfh3rJ1LS9Uvvhtpl3b3Ajt9b8Pal cfHD4Q2useGv
EenxzTjTdasIdQQXMCzT2t5aXNnq2lXmpaJqWmale/yU/wDBxP8A8ou/hn/2 dx+y9/6zz+2X
X4x9NLhTLOGfof8A0uqWApQS/wCIIcZxjWjPEylONbgbiivUjJVsTXg4qXs+ ScYQlpJO5/Nf
0os0xGY/Rs8fpVqk5KX0dvH+bhKOHSTp+HGeUoNexo0pJ2c+ZSlJaq2qP7bP +Cev/JMvih/2
Wi//APVXfCqvvivgf/gnr/yTL4of9lov/wD1V3wqr74r9x47/wCSy4l/7HGN /wDTsj+keFv+
Seyj/sCpfqFcJ8Svh9pPxR8G6l4K1q/1jSrLULzQdSi1Xw/cWdrrWmap4Y8Q 6V4p0PUdOm1C
w1SwFxY63oun3Sx32nXtpOsTQXNrNDI6Hu6K+VjKUJRnF2lCSlF2TtKLunZp p6rZpp9Ue7OM
ZxlCSvGcXGS1V4yTTV1Z6pvZ3PjTRP2KPBuleJPDniTUPir8a/FLeGfEug+K 7TRvEeueBZNG
u9W8NazZeINHa/TR/h3o2pPBbavp1leNDaalZ+cbcQzM9s8sMn2XRRQ5XioR hRpQUpSVPD0K
OHp881FTm6dCnTg5yUIRlNxcnGEIttRiko04wblepOUlFOdWrVrTcY8zjHnr TnJRi5Sainyp
yk0rybf5RftP/C/9tHb8eLn4CeKPDmhad8S/2hfA3iLSfA1hqq+Bvi58UfDu k/s5fCrwzrv/
AAgXxdi+Knhuy8Nmz8ReAb29v/Bk+l+CPFOo+HvAPizUYviA3h7WLXQNa+3f 2WdD+NHhv4A/
DbRf2hdXg1r4u2Ok3w8UXcOoprM1tbT65qtz4W0XVtcjQJr/AIj8OeD5tA8P eKPEKz6iNf8A
Eel6prA1rXftv9s33x18Uf29Pg18MvFL6X8b/wBvH9hn9lrX7TxV8Rrnwn8M vjt4m07wj44v
/CXg74j/ABK+DOn+LL611z9qT4XP4w8PeIbzwZ4iuLWZ/Bo8O22v2U9tZrda 54Th1OD7P+FX
xl0nxL4FTW/G3inwTpmt2Wu/EPR9Slgu4vDOn3dj4F8b/Erwzb+JYNF1zXdV 1DRdP1vRPhj4
j8Ti0vNX1RdPtNH8RD+1L220DULyKK+XKjjK2YTxnNVjSo5bVwsK1b2FF0/a SjJ0Z0oUniOa
lUhOtSqVE0klpK78XC4KjLOJ5tCrmiqYrL3Rhh6uIhPLpUI16NX29LDRlOdO tecOV1HBRjVr
clKFSrXc/FPjZ8PvhF4O/as+CH7ZXxY/a1174Lz/AAz+FPxZ+BHhP4T+KPFv 7O/g34H+OtB+
MGreC/FvxHl1y88e/DGf4u6h4pv9d+FnwY1+N/B/xk8OWejt8JPDNvY6Pa6N 4m+KWn/EPTX4
SfDr43/GDQP2tPgB+0/4x8LahcaT8P8A4c/FS++AGvfAH4i/Dj9of4f/AAV8 beN/G/gT4V/E
u6+I3ws+NE/h3SfCGs/Fv4w2s+qfATxJ8F/iPqFh8Vteg8SeM9TuvDvwzu/A n56/tb/Bz4Sf
Fr4x6zrN/wCANc+OHxL8LeItT0rxdrmp6pq99Z6D4Y8zxDL4U+Fklm37S37O vhDw7pOjWutW
GuaZoPw8t18Up/Zul+MviZPf6n8SL3xD4/8Ahz/gnp418U/CX/gpZ4Z+Fvhb w9Z/DTw58XYP
FXhH4p/CzQfiAvxJ8LadfeDvgx4q+IUdxba/b3uopf3Phvx34XlsPDcus6lr vibwLoPivXPA
er+ItV1e617UNU/IMq8X8pzfiunw1hsI37XFzwca0a7qYmFanB8zrYanQlh4 UoVoulUnHHTl
FpyhTqU4uouriTDcZcJ4rJ8Zm+T5PLhnPc5w2SYLF4HNsXUzehVx1GpVwGNx uX4vK8FQhhcT
7JxdOji62IpqaqKNSnHmn+zl7/wS/wDgFefDP9lf4ZDxf8YLW2/Y1/Zg0X9m L4E+KrbX/BZ8
VaFB4L+IX7G/xd+GHxo1kXXw/ufC3iT4wfC74rfsKfAfx74ag1bwvP8ABrXd RtvFmg/En4P+
PPBPiNvCtn0H7Pv/AAT38HfAj47a7+0vq/x3/aA+PPxt8Vf8Lp/4Snxr8Yn+ BOnf29/wu/wd
+w14A1v7V4c+BfwK+CnhKx/4Rbwl/wAE+vgXpPg/+xNB0ry/7R+IN/4p/wCE q1PX9IvPDnsH
7a37Ruo/sg/sj/tG/tS6X8KvEHxsuf2fvg/44+LUvwy8NeJPCvg/UfEeneB9 Eute1iS58UeM
b+z0jQvD+haRZ33iTxZqVpa+JfFVt4V0fWX8C+A/iN42Hh7wF4k9f+KXxS8C fBfwJrvxJ+JO
u/8ACP8AhLw//ZkFzcwaZrHiDWNV1jxBrGn+GvCfhHwj4T8M6frHi3x38QPH fi3WND8E/Dr4
deCdD8QeO/iL478QeHfA3gbw74g8W+ING0a+/YD0z8YdR/4JPfEz4f8Air9m v4Kfs0/FXxB8
P/2L/h54g/YD+JXxyTxZ8WPh74n8VfGD4mf8E+dR+AGnfD7V/EvwZvv2HNU8 U6l4g8b/AAp/
Y6/Zp+GOs+L/AIT/ALdX7Mvw98P6jpdz8Sf+GcfFWo6D418MfH/6fvP+CZOj 6f8AAnxH8DvB
n7TP7QEPh/wh8P8AwV4R/Ys8P+P7rwJ4k+Fn7D+sfBPxj4A+J37M3iLwV8OP h74P+D17+0V/
woP4m/Bf4D6/4cn/AGx/G/x/8d6z4d+F154E1X4ir4f+M/7Qi/Fjn7X/AIKp fCnS/wBpXxx4
C+IGk/GDwJ8CbX9mD9nL44+FviD4u/Yx/bQ8F6j4C1H4hfG/9tb4WfF3X/2q dW8VfCCx0j9l
b4P+FdI/Zx8EeKPDvjv9pLQfgh4VXwrP8RfibN438R/DaxOteE/qD4sft3fs z/AjxH8S/Dnx
l8UfED4Z/wDCqPh/4y+JfiPxb4y+AH7Qmh/CzXvDvw9+FmpfG7xrpvwn+Mt5 8LI/hL8d/iB4
c+Eug+LfH+pfCf4I+NfiF8U4/DvgH4l3ieDX/wCFZ+P08OAHn/iL9kjxF45+ Lvw6/bM+I+of
8LE/aN+B3w/8Xa9+zr+zn4i8V/Cyw/Zx/Z8+O3xE+CcHww+I1h8Ov2lPCH7H 3hf9rrU/h/8A
ECKXxB4d8Xat8TpfiJ4O1a18RQfE1v2aIvGfw7+DOg/DToPBn7EPhXTv2Vfh X+zb498ceIPF
mr+EPjB8If2m/iV8U/DWnad4J1H4vftP+Av2rvCn7cnxG+KVz4Sv28a6H4G8 P/HT9qPQte8b
+LPhn4XmXw/4O8K+NtZ+H/wyvPCGkaX4YutDLb/gop+yrP4V1nxLca/8YNF1 fRvEHhrw0Pg9
4p/ZU/au8IftP+I9R8Zad4s1nwrc+AP2RfFXwT0f9qP4meH9f0P4dfFbX9L8 WfDv4QeKPCt1
4f8Agr8d9dj1k6R8C/i7eeC+fs/+CoH7Fl/4d8OeLLf4ifED/hH9b/4TWfxH qFx+zb+05Zf8
KO0f4dfFPx/8FPGvi79rK1vPg5b3v7Gfw/8AD/xN+Evxe8NXfxF/aytvgv4E k/4U/wDF7WbT
xFceH/hZ4/1Xw6AegfBX9ir4WfAj/hkP/hEdf+IGo/8ADF37IHiX9ir4W/8A CR6r4dvP7e+F
nir/AIZg/tDX/H/9meFdH/tT4gQ/8MnfDr7Hqvh3/hFfDsf9teNfP8K3H9o6 F/wjnj/i/wD4
Jf8AwC8aeC/iB4F1Txf8YLfSPiP8H/8AgqB8FNcuNP1/wXFqNr4V/wCCsvx9 0D9ov9ovUNKm
uPh/dW0HiDwX428OWOl/BS6u7S+07w54VlurHx1pXxH1d4dcg6DRP24vDtp/ wvT4p/EGT+yv
2f8Aw5+0Bq/7K37Oen/D74a/FP4w/Hb9oD4p/Bf/AISnQv2lNc8H/C34YaX4 t+LXi3/hEvi1
4S+MXwptvhL4P+Bt94i8M+Dv2RPjF+1ZdeOvG/7P/wARdB1P4X+gfDr9pDWP EH7R0/we8U6P
/ZfhL4vfADw7+1F+yprmp+CPHfw28d+IPAmhXXhHwT+0R8Nfil8NvHUb+LfB nxA+Bni34hfA
jxlqGqeP9E+DuseINH/aj0L4T6X8I5PFv7Nnxj8c+IADx/xP/wAEv/gF4+1H xhofxI8X/GDx
/wDs+eKPEH7SfjnS/wBk7Wdf8F6L8GvAnxM/bB8K/Gnwb+0r8SfCfjXwN8P/ AAj+1Hd+IPil
of7TP7TENzofjj9ovxn8PfB0/wAdPEtx8OPBPg2TwV8F/wDhV/Pj/gmLY3/j vX/jT4w/bQ/a
/wDH37Rsv/Cl/wDhW37Q/iKx/Y20zx38Dv8AhSOj/tVeFND/AOFdeC/A37H/ AIP+Auv/APCT
eBf21/2k/A/i7/hdPwc+LfmaP8QINV8Mf8Iv4z8IeCfFPh3oLH/gqT+yrp/i DxJ4O8eeK/EG
l+JPB3iD4qr461n4ffBP9q74ofBr4TfD34eftP8A7Rv7MFp8R/j58fbH9nDw /wDCn9n/AMP/
APCU/swfFqX4h+IPi54h8K/DP4fT+AfiFrGm/E7x38G/DGl/GrxX9v8Aj/4s fCz4Uf8ACFf8
LS+Jfw/+Gv8Awsr4geHPhP8ADr/hP/GXh3wd/wAJ98U/GP2z/hEfhp4K/wCE i1LTv+Eq+IHi
r+ztQ/4RzwboX2/xFrn2C8/szTbr7LPsAPIPgn+yt4V+CfxC8XfFa3+Ivxg+ JnxE+IPwf+EX
wh8deKvi34u07xXqPiWD4RfEz9pX4u2njOQWPh3Q7bQPEHinxt+1X8TJNS8K eELfw78GvA/h
XT/Afw7+CHwr+E3w78F6X4VH0/XzB8W/2yf2ePgxqMnh7xL4x8QeMfG1v4g1 Lw1qPwu+Anws
+LX7UPxl0TUdD8K+A/G3iC58R/Bf9mvwL8WPit4a8P8Ahrwt8WPhBrHifxZr /g7TvCvhqD4z
fBiLXdZ0+5+L3w3g8T/L/wCyd/wU0+EXxc/Z7/Zp8b/GDxD/AMI18TfiB+yB 8G/2kP2hPEng
34RfGyX9lj4A6x4z/Zn8OftKeO9H+LH7SLeG/FnwF/Z1/sLwLrMPjvTfBHx6 +OPh/wAd23w6
8UfDTX7uPU7L4keA9W8VgH6f0V+YHxT/AOClvw61H4E/tQan+zfZfECb9pr4 TfD/AOGNn8L/
AISftL/su/tT/s4f8JV8dv2sfGPiv4FfsP8AhzVvD/x/+HPwG1rVfh/8b/2m tAj+Ft/410fX
dH8HeFfsmvah438f+ANF0u/8S6d6BP8A8FQP2LLTWPF2jah8RPiBpX/CCfED 4i/DvxT4g1j9
m39pzR/Amm3XwX8d+Ivhj8d/iBH8R9U+Dlp8P9S+AH7O/wAQPDN14T/aQ/ae 0rxLffs4/s76
xrHgi2+NfxU8Cf8ACxfADeJgD7/or5g8Wftk/s8fDz4meJvhX8TfGPiD4T6v 4U8P6z4lv/HH
xe+Fnxa+E3wC1TTvDXw9ufi14ntvBn7T/wARvAvhj9m74h+IPCvwu0vxR8Q/ FfhPwF8VvEvi
rwx4L+H3xU8Sa9o2n6R8J/iVd+Ffn+2/4KX/AAp1T4+/s6/BnR/hV+0+NI/a H8P/AB9fS/FX
iz9j39tD4deKvCvjT4K+NP2RfCtjY+JvhF46/Zr0PxtoHwf8U237VcWo6z+1 B4xTwf8AAL4e
aj4EufDHiHxpPq+s3Y8MAH6P0V8AXn/BUf8AYT0fw74j8a+Kvjn/AMK/+H/h 3/hCr2D4mfFD
4ZfGL4WfCzx34O+IHxT8AfBjw78Xfgx8UPiL8PvDHw/+PfwAi+IHxY+FFn4o /aL+CXiP4gfA
nwJ4d+Kfwz8f+OfiJ4c+H/xA8I+KNY+n/Evx3+Gfgv4NW3x68Y6p4g8J/Du8 8P8AhPX7RPEv
gD4haF8Qrqfx7Po2neBfBFt8GdU8LWvxjn+MHjTxJ4j8PeBfCfwOi8BN8ZfE fxM13Rvhdo/g
S8+ImqWPhicA9gor4g1n/gop+yr4a07wnqninX/jB4TtvE/h+58Z6xF4u/ZU /au8K6j8GPh7
b+KvEvg6L4qftU6P4h+Cem6v+x18H9U1fwR49u/Dvxe/atsfg18M/E/hX4ef EXx14d8V6p4J
8AeMfEOieP8Axm/4Kxfsz/Dr4WftT+NfBo+IHjbxb+zV8P8A9r3W9N0Hxl8G /wBoT4GfCz40
fFP9jHw78VdW+LHwL+E/7S/xL+Ctj8EviL8QNK1P4L/Euz1LSPhP4j+J3iKx 8O/D34l+P9N8
La/4S+GvjK/0oA/T+ivzA+Fn/BQvwl4f8Otpf7Q/jj/hJPHWm/D/AOFfi6C0 +H37F/7cPwQ+
O3xI1j4x/FP9rrwr4d8O+D/+CePxF8AfFr9o2y/srwZ+yl408U2sHhbx/wDG Px34l8HeAfjF
8d/Ffw6+DfwF8N+EfGPjP0C1/wCCgngTxl4j/YhX4O/D74gfEL4Zftk/tAft Efs8XXxU8R6J
rHwT/wCFJeO/2bvhZ+0n4z8YeFvH/wAIfjFonhH49L8QNR8dfsyfEH4cWfhS 6+GOiaPov/CM
eNfEHjDxp4cvdO+H3hT4qgH3/RXwB4p/a3+O3gP47aR8NvFP7Jn9q+EviT/w vS1+BekfDb48
eDvGH7U/jf8A4UN4O1vxTq/xB8e/AvW/Dfgj4JfCH4AePNT0PRPAXgX4xav+ 19r/APYfxF/a
E/ZB8C/HTwf8FPFvxv8AFOifCHoP2RP2sfFX7Qvir47/AA58deCvg/o3jb4A eINC8OeMfEv7
M/x/1H9qX4BW3irVtR8b6F4h+DGpfF/WPgx8ANX8P/tP/B/V/h/d3/x5+Amq fDVNR+Fvgv4j
/AXxPfeJ9TufipLoHhQA+36K+QPHn7ev7J3wz0fx3rPjb4rf2P8A8Ku/4aEn +Jfh+PwN8SdW
8d/D3R/2WfAi/E744eLvG/w40XwdqPxA8K/D/wAK/D/UfA3izR/iLrnhqx8C fELR/jT+zfc/
DbxF4v8A+GnP2el+Jny/+0X/AMFWfgh4L/Zq/af8f/BnWPEA+OPwj/Zg/aQ+ Lvw/8E/H79nb
9pX4OeH7r4tfBX4IePPjRpPwT+IUHxT8BfCG50P4waj4J8HJ8apv2atR8S+E P2h/Ef7MFzB+
0d4Y8Ir8DtZ0X4ozgH6v0UV8QeM/+Ch37MHhHUfipFY+KvEHxE8Lfs8eH/i9 4r/ai+Knwn8H
eIPiL8Gv2YtE+A/hXxX4k+LGl/GH4reHLS68EwfGDwXc+HNL8Pa3+yz4F1jx x+1xYT+O/Bvj
G8+A0Hwpl8SfEPw2Afb9FfIHwt/bu/Zn+MHjvQvhl4T8UfEDSPHXiL+07LT/ AA78UvgB+0J8
Drq38Y6Ro+oeLrr4Ra7P8a/hZ8P7Lwv+0BL8MtMufjlpn7OniW60j47a3+zj Jp/7SejfDu/+
Aur6V8Rb3n7b/gop+yrP4V1nxLca/wDGDRdX0bxB4a8ND4PeKf2VP2rvCH7T /iPUfGWneLNZ
8K3PgD9kXxV8E9H/AGo/iZ4f1/Q/h18Vtf0vxZ8O/hB4o8K3Xh/4K/HfXY9Z OkfAv4u3ngsA
+36K/ODwB/wU2+CHifxp+1R4Y8Y+GfjB8M9I/Zr8QfDC1s/FXiX4BftK2+nf EPRPi78Av2UP
i74F8P2w1T4G6HbaB+0/4p8bftV+Hvgz4T/Yai1HxF+1x4q8Vaboz6P8KZtX 8aWPhXS/QNE/
4KN/se674q+E/wAPrf4m+INL+KPxs8QeMvCfw8+Dniz4M/HPwP8AG+88VfDz Ufg9D448NeJv
gn4z+Gug/Fb4eeIPC3hb4+fCn4y6zo3xE8H+FdRs/wBmrxLc/tTyWw/Zu8Me LfipoQB9v0V4
B8dP2nfhF+zr/wAItbfEW7+IGp+IPGv9tz+FvAfwd+Cfxs/aN+Kes6P4X/si PxX4utvhJ+zx
8Pfij8TV+H/hC98SeEdG8YfEWfwnF4E8J+I/HXw+8NeIvEWm+IPiB4L03XfH /Gf/AAUb/Y9+
Hmo/FS08afE3xB4f0j4OeH/i9r/i/wCIN78Gfjm3wa1Sf4AeFfFfjX43+CPh f8crf4azfBv4
4fGD4UeG/h98Tr7x98Dvgr46+IHxl8MT/CP4yaXqvgS21f4P/Eyx8KgH2/RX 5A/tKf8ABUrw
long74Yab+z2/wAQNC+JvxR/aA0H4Janb/GL9gv9uHxf8U/g/o+s/An9oz4+ 6F8V7r/gn/p/
gz4HftdfHH4f/ESL9mHx38JfB/irwHJ4T8CWXiNfiD49bxz4ksv2dfil4AuP X/E//BUn9lX4
YeC/GHjH4s+K/EEVt8P/ABB+0mvxBb4E/BP9q79prTvhT8Pf2c/j78afgTq3 xH+OF18LP2cL
rV/gj4f1HV/gT8RopfEHxL8PeH/hnq3ir4b/ABl0f4N/E742+CfhPrXxPvwD 9H6K+YPE37Xn
wa+Hnxltvgh8X73xB8E/EnifxB4T8MfCLxf8WNBn8K/Br4+eIPHEGjW/hbwf 8HvjeZbz4U67
8YNd8U3niXwfon7Nmu+LfDX7T+vT/Dzxl470D4Lap8Gz4V+Jnik+NPxr8VeG PjL+zZ+z78MN
P8P6j8RPjb4g8YeOfF994ltdRvdO+Hn7MHwJg8MXnxv+JNtpdvqvhW28T+IN U8bfEP4E/s6e
E9DtfGNr4g8K+Kv2jdG+PDeCfil8O/gj8TPAuqAH0/RX4g/Cb/gs14S+J/8A wwj48vPg3+0B
4X+GX7WH7IHxw+N3jXwn4c/Yz/bh+M3xT8G/F34f/wDDBGs+HNB8AW3gH4AJ 4g+JnwAg8P8A
7VXj/Tbz9pXw58JNT+CfxE8R6D4Kj8FfEnSL2W88Na99/wAH7ev7J1/478I+ A9D+K3/CWf8A
Cb/8K6g0T4m+BvA3xJ8efs42usfGLR/DviD4PeEfFX7Vng3wdrn7MvgP4gfF 7RfG/wANtS+F
Hw68c/Frw747+JVr8XvglJ4J8O65/wALs+E48YgH1/RXyB8af29f2Tv2e/Hf jj4Y/Fr4rf8A
COfED4a/ADVf2qvHfhPT/A3xJ8Y6x4Y/Zx0HR/jHrOv/ABo1O28EeDvEfl/D /Qf+FEePPD+u
6/G0lro3ju/+Fvw41I2vxA+O/wADvDXxFPjl+3d+zP8As6+O7X4W/ErxR8QL j4m3/wDwrL+y
/h18LfgB+0J8e/Hes/8AC4NH/aT8ReAP7C8I/Aj4WfEjxBrn9q+H/wBkH9o7 XdT/ALI0+9/4
RPR/hjqGp+L/AOwbLW/C0+ugH1/RX5QeMv8AgrX8ENC8VfHPQtA0XxBrPhv4 V/sQW37Y+i/F
PUfAP7SqfDOzn0nUf21dJ+Kfws/aZ1r4f/s0/FDV/wBjnxB8HtX/AGNdd8Ne MNH+L+gP8Zbz
4hat4x+EHhr4Faz8ZPhXq3w+132Cf/gqB+xZaax4u0bUPiJ8QNK/4QT4gfEX 4d+KfEGsfs2/
tOaP4E026+C/jvxF8Mfjv8QI/iPqnwctPh/qXwA/Z3+IHhm68J/tIftPaV4l vv2cf2d9Y1jw
RbfGv4qeBP8AhYvgBvEwB9/0V8weGv2yf2ePF/xlufgToPjHxBceNk8QeLPB mk65e/Cz4taN
8GvG3xC8AQazcfED4V/C/wDaL1rwLp/7PnxZ+MHw+j8KePV8ffCH4ZfE/wAW /EzwTP8ACv4y
WvijwppNz8GvinD4Q+X/ANof/goJrHwP8Y/HTxHpvw+/4Tj4C/swfED9jD9n j4sXPhzRPHfi
X4p+If2jv2y/jt8BfDWpeFvAHhPwboniPxnqn/DM/wCzl8dfhP8AG688KeDf hV8Vrr9qbxH+
0P4K+E3w08afDLx18FviXo3igA/T+ivkCD9u79meXx34R+HU3ij4gaX4g8X/ APCurJtQ8QfA
D9oTw34E+H/jH4u6P4d134Y/CL46/FLxB8LNN+GX7OX7QHjqy8a/D2Dw1+zp 8fvF3w1+O2p6
x8UfhJ4dg+HbeIPiz8ONM8UfP/xC/wCCrf7P/hW6+CeoeC/CH7QHxX+H/wAV /wBoC0+CVz8Q
vBH7K37X+uaPqOj65+zj+078fvCfxX/Zvh8Nfs6eJv8Ahtf4f+I/+GcU0qPx V+y/dePvAmne
BPH2j/Gu+8cp8P00afxUAfp/RX5wWP8AwVJ/ZV0/xB4k8HePPFfiDS/Eng7x B8VV8daz8Pvg
n+1d8UPg18Jvh78PP2n/ANo39mC0+I/x8+Ptj+zh4f8AhT+z/wCH/wDhKf2Y Pi1L8Q/EHxc8
Q+Ffhn8Pp/APxC1jTfid47+DfhjS/jV4r9A8QftzfBDXfiY37NPw1+IPiDS/ jt478QfE74Pf
CD4g+IP2W/2lfH37MF58ffh58PfiP418S+DW+OWgeGfAv7PnxI8QfC2P4V/E b/hZ3wn8MftL
eFfGln4g+F/xH+E9/rfg74k+GNdsdCAPt+iviDwn+3X8M4v2PfDX7W3xq0rx B8K7aPxBo3wj
+LXw48J+G/iF8fvFXw4/afT45237KHjz9njw1pvwj+H+s+MfjV4g8IftYDVf gVo3ij4Y+BNW
8P8AxH1HTrbxn4LN94J1nTdZl6DwB+3d+zP8UP8AhNYvA/ij4gaxqfgT4f8A iP4l6h4cl+AH
7Qmj+MfE3h3wJ9js/ilpvwq8Fa78LNM8W/G34gfBLxbqelfCn9oD4T/BzRfH fxT/AGf/AI7a
xov7P/xp8G+BPjbrGmeALsA+v6K+ILn/AIKKfsqweFdG8S2+v/GDWtX1nxB4 m8NH4PeFv2VP
2rvF/wC0/wCHNR8G6d4T1nxVc+P/ANkXwr8E9Y/aj+Gfh/QND+Ivwp1/VPFn xE+EHhfwra+H
/jV8CNdk1kaR8dPhFeeNPP8A4Zf8FNvgh4t8F/FnxP478M/GD4f6v8Kf2n/j x+y/F4V0j4Bf
tK/E/Ufi14q+D/x9/aA+EWjv+zifB3wNkuf2o/EGueCf2e/Fnxm+JXgv9mfT vi/qP7PHhWw8
Xp8Wr7SdI+H/AIh8VUAfo/RXyB8Pv29f2Tvir8U/B/wP+H/xW/4ST4weNvh/ bfFLTPhtbeBv
iTbeMdF8CN4j+MXgbXdd+IOh6h4Os734Vf8ACvPib8B/iR8GvjFpnxPi8Iax 8EvjtbeD/gT8
XtP8E/GD4o/C3wT4y9A8f/tO/CL4b/FPwV8FNbu/iBr3xN8c/wDCOT2vhr4X /BP42fGr/hDN
H8ZeI7zwn4P8XfGfWfg78PfHXh/9n/4f+LfEGj+KdP8AC/xF+Omq/DvwJ4g/ 4QL4mXWkeIry
y+GHxBufDQB7/RXwBef8FQP2LLDw74j8WXHxE+IH/CP6J/whU/hzULf9m39p y9/4Xjo/xF+K
fgD4KeCvF37JtrZ/By4vf2zPh/4g+Jvxa+EPhq0+Iv7Jtt8aPAkf/C4PhDrN 34it/D/xT8Aa
r4i8f8a/8FJNE8V/H39kD4K/AK88QWNt8b/EHxZvvinqHjn9jf8Aa48d/Ez4 fQfA3xp+yl4e
1r4IfEn9nzSdF+E3xW/ZC8QfFHwt+1t4N+J2h/tS/tP6VpXwa+E3w9sfBPjT xJ8OfiF4J+PP
w/8AFengH6h+I7n7FpE155M1z9kutMufs9v5P2i48jVLOXyYPtE1vb+dLs2R efcQQ72XzZok
3Ov5Zx+CE0e/u57aPULrV5tO0/QbvX7T4E/tET6lquj6FPqs+h2V7qGm/BXU GnstOuNb1m8s
LH+0by00+61rVpLN2a+upp/aPhJ+3v8ABD9oPw38GtH8KX/iDxT42+MPwk+E vxUvrz4Q/Cb9
pX4ofALwHP8AEn4WeGvjnpfhTxn+0td/ADwN8O/hr4g1D4d+IfD3jHwp4M/a Di+BPxl8ReC/
G/wr8Q6h8IfDNz8V/Auiav8AXGj/AMH/AACvdyHivF8N1sVTw9JVI46OFlU9 6jFqWGliVTd6
2GxOyr1NIKF+Z8/PaPL5WaZTTzSFL2k1H2XtYrmjUlpVVPnt7OvQ1fs4/E5W suXl97m+Ffg3
8NJNM1ySHSNNvtOtrzxH4U1WWBPhX8U/AOjW80fxj8JfEvxNrV9fePvh94G0 241DW9R0a9WS
LSW1fWtY8ReIzquoW0dnHrOr238Zv/BxP/yi7+Gf/Z3H7L3/AKzz+2XX+iJd /wDHlB/2FNH/
APTzY1/nd/8ABxP/AMou/hn/ANncfsvf+s8/tl1+MfTH4gxPEX0Nfpe4vEx5 HHwU4xhGN6cn
pwPxhTbcqdGhHWNOCS9mrWbu22z+Z/pUZZRyv6N/j1QpO6/4l0+kHqlNK3/E OM2mklUq1pX5
qk225u9+iSR/bZ/wT1/5Jl8UP+y0X/8A6q74VV98V8D/APBPX/kmXxQ/7LRf /wDqrvhVX3xX
7tx3/wAllxL/ANjjG/8Ap2R/R3C3/JPZR/2BUv1Ciiivkz3wooooA+HNd/ZX +LM2q+I28I/t
E2vhfwxrXizxt4rs/D9z8LbrWrnTpvHfi3W/GerWc2rW/wATtDhv0h1bX7+O 0mTSLFhZC3im
SaeOS5m+kPgt8NpfhH8ONE8CXGvt4pvNOv8AxTq2oa+2mjR11LU/F3i7XfGO qSw6X9v1Q2Ns
moa/cwWlvJqV9KltFEJrueXfI3qdFaTqym6rkqfNWqKrVlGlShOpUXtLSnOE Iyk/3s27uzcm
2m7NY08PSpuDhz/u6bpQUq1acYU5ODcYQnOUIr93DaKaUUlZXR+Y37U3/BOf VPjX4sl8c/BL
9pT4jfsz63rE8934t0DQYtf8T/DTXdVu7q4vdS8UWPgfSPH/AMO38N+LNeu7 mS78T3+la8NF
8Q6kZ/EV/wCHW8W6v4j8Ra5N+w//AMEzfAH7H/iPVvibr3jzVfjZ8aNS0aTw tYeONY0GDwro
ng7wnM1kbzRvBPhGPWPElxpk+rrpek2+r6zrfifxHqh0/SbPSdEuNC0m41mx 1b7V8f8AxA8V
aB4t8I+CPBXhXw14k1/xR4d8a+Kmk8X+NtT8D6LYaP4I1LwLpF8i3+keBPiB e3mqXl74/wBK
a0tDpNpa/ZLPUZptRjmjtra65b4beNPFmj+KPC3wa8X+EvBOiyJ8NtX1vw/q Hgjx7L4rjOm/
D7UPAnhe7ttZ0hfhF8JdJ8Py3n/CZaXcaVD4c019I2WWqW0Gm6La21hBN4eF 4LyHCZhLPcHk
eU4bMsTCtWni6McJRxVRQ9oq1VUIzjUc5claVSrGj7SfJKcpS+I8erlmTVc2 WZ4ijXxGY0MS
p062IqZlicPhsViKUKftaFKtUqZfhsROnVjH21GnTqXrS99TqT5sf9tb4B+K v2q/2R/2jf2Y
/B3xC8P/AAp1f9oX4P8Ajj4KXfxD8S/D7Ufilp3hbwr8T9EuvBnjrULbwPpf xD+Fdzq3iB/B
Os+IbTwndS+NrDTtA8VXGjeItY0rxXpGk33hLXD44fAPxV8ff2eNF+F3jH4h eH9N+K2heIP2
evizafErw18PtRs/h7J8ff2a/i18NP2gvAviO5+EeqfEPWfEj/B/VvjH8K/D 0/iz4VRfGiHx
pffDO81nwTo/xu0LxTcWPxM07tPjF8VW+EkOm+ItQn0R/DjaZrUF3pV7b6wm tap4il1Pwtae
F4dC1DR49aup5rh73VNFh8Jaf4L8ReIfF/iDXPDNn4fuLK8s5NK8R/C/hb/g pBqPhaCbTfjx
8GfHKXltoGra/F8QPht4H8a+F/h5qq6Bo/jzxp4o0qaz/aFsPhTqnh7WfCvg Pwadce1g1fxb
D4nia8l0a5t763l0C3+azXxM4MyPO6nD+bZt9SzGil7WNTCYuVCnKphsLi6E JV6VGpT5sTQx
SlRabhz0atKpKnVlh4V/0PLuEc/zbAPMcvwX1nDJ7qtRpzkozrU6rhGtOmpq jKknWUHKUY1Y
TScI1pUtTx5+wN8U/jV4E/bd0/41/tB/D/U/ib+23+wBoH7DHiXxd8Lf2fvE Xw98CeBv+EX1
j9uSfRvijoXw68WftDfFjxBqefD/AO2LpWman4J1D4pRfbNY+F+oa7a+LtNs viBbeHfAXyB+
0x/wQ6/4aI+IvxP8W/8AC4fgB4b/AOFhf8NnXX/C49Z/Yx/4TP8Absu/+Gw/ 2WP2oP2b/wDh
X3xH/bE/4aM8Nf8ACx/gB8B/+Gmt/wAFfg7/AMKa8Lf8Iz8HfgZ8Avgj/wAJ g/8AwgP/AAsP
Uv3+rwD4HftIeBP2gPEf7RvhrwVo/wAQNIvf2Yf2gNS/Zv8AH8nj/wAEax4D /tjx3pPws+FH
xbvNY8Fab4jjsvEGt/D+48P/ABg8OW3hzxveaNpGj+Ovsl54s8ASeKfhlq/g rx54t+9Pmj4f
/bL/AGQfiZdfGXWf27/gTqXiDxh+0H8N/D/7Ltt8EPg9o3w1+HvjrTp/FXwe g/4KA/CbxfrP
izSPiZ+1L+yL4b8feH/EHwb/AOCk3xPvbbw0v7QnwG1HwX4q+Ffhrxla+LPi lHd3HwY8R/EH
w4/4Iq+Ivil4S8NfFL9pnTP2QL749fFT/heP/C97P45fsNfCz9qLWPhl4O+L v7cX7YX7Yvhb
/hlO38f/ABj+Ifwy/Zh/aA0iy/bL8YaF8Vv+Ex1D/goJ8CZvHfgr4WaZp3/C 5/Avws1TxP8A
HX9P/wBqn/gpJ+yx+y7a+L9M1n42/ADWfib8LviB+y9onxr+Emp/H/4deEPH fwU+Fn7RX7R3
7P3wK1X46fFLw/dXmreIPA3w/wDhp4f/AGg/DXxS1DV/FmhaF4d1nR20LT7n xT4bsvFmn+Jb
X2DWf23f2L/Dnwa8J/tF+If2u/2YNC/Z88e+ILnwn4F+O2s/H34U6X8GvGni qzn8S2t54a8J
/E++8WQeCfEfiC1ufBfjG3udG0fXLzUYJ/CfiWGW2WTQtUW1APiDxV+wr8U/ GXgT42/s0WWl
/ADT/Auj/tf+Of2wP2bfjd8efg54i/aAutB/4ab1j4r/ABl+KQ8GP8Kf2nP2 S/jP8Bf2v/gb
+1P8U/jJq3wg/aC+F+veEf8AhWH7OPi34EWHgHxz46+PTfGDxb8O/f8A4Lfs 3+O/DP7R3gfx
Z4w1j4geIvh/+x/+yBpX7HvwF+JPxX8b6P41+Nn7RGsfFO6+Dnjn9pj44/Gr XNNk1L/hJvtf
/DO/7M3hrwT4l1G2+FnjvUvi7p/7Xms+MfhxrXw/8RfAbxtd/QH/AA1j+yx/ wvb/AIZc/wCG
lvgB/wANNf8ARuv/AAuT4df8L2/5E7/hYn/JIv8AhI/+Fgf8k/8A+K5/5F// AJE7/ipv+QL/
AKbXP6b+27+xfrPir4teBdH/AGu/2YNW8bfALw/488WfHbwdpvx9+FN94q+C vhX4V6jHo/xP
8S/Frw9a+LJdX+HHh/4cavLFpfjzWfGNpo2neD9RkjsfENzp1y6xEA+ILf8A 4JSeR8Ov+Cjv
gD/hfW//AIeBfAD4/wDwL/tb/hV23/hUn/C8/wBqf/gpx+0v/wAJT9g/4WKf +E9/4Rf/AIeN
/wDCFf2J9s8Gf23/AMKc/wCEj/tfSP8AhYX9g+B/0e8ffAH4NfFTxVZeMfiV 8PfD/jzV7P4P
/GT4AvaeLIZ9d8K6t8Gv2g9R+F+qfGb4e+JfAuoz3HgnxZ4f8f3Pwa+HMWsw +J/D2rzpp2hX
Oj2E9npHiLxPY6z5Bf8A7Znws8Vf8M0Rfs3+Ivh/+07/AMNSfEDXtE8CeI/h V8TfDvin4dad
8LPhX/a15+0J8dNa8a+A4vH2/wCH/wAKP7Dj+FMWr6PouqeHdR/an+Jn7P8A +z/438U/C/8A
4W6vj/wrz/xJ/b4+AXhTTvG2u/Dv4kfB/wCOWkfs+fGDwN8OP20bD4ZfGbwX 4h8afsjeFfGn
irXPhzqXxO+LPhjQ31y28HeH/hD4206TxL8eF+K2v/CXTvhj8AvAf7QHxfuP EGr6v8F2+Gvj
MA8/1r9gOf4b+Kvhp8U/2MviP4f+EHxk8BeH/jh4J17xj+034Y+Mv7bEHxU8 K/tC6j+z1rHj
3XPil4h8UftM/Cr9oP4gfGDRZP2UPgD4M+GfxJ8cftE+KNO8C/BrwnefCOPw Nq3huy+GUvwt
8A+EP/BJzxV8Jv2dPGf7GVv+0n4f1v8AZc+P37MHhT4B/tSWM3wI1Gx+Pviv xV4d/YC+Ff8A
wT5uviF8Afi2nxxuvh38EfD+o/Dv4E/CnxxB8PviJ8Af2j9R0/xpH8Qo5PiH qOh+LvDenfD7
9H/jH+098E/2e9Y0q2+OPxE+H/wh8JX/AMP/ABx8RdS+J3xS+Knwi+GvgTwx o/gjx38FvhxJ
BrrePPiB4c8Wyf294t+O/gjRtM8RaB4T1zwJo2sXWn+GvHfi7wd4t8efCXw/ 8Re/+FvxY+Fn
xx8CaF8Uvgp8S/h/8YPhl4o/tP8A4Rr4i/C3xl4d+IHgTxF/Ymsah4d1n+wv F3hPUtX8P6v/
AGR4g0jVdC1P+z9QuPsGsaZqGmXXlXtlcwRgH4Q/Dn9nP/gor+0H8fU+LP7W fw48P+FPBPxR
+MH/AATu8LfEOy0rwN8L/gf8TPAfwz/4Jw+NP22P27/A/j+18G+DP28P+Cg/ gPVfD/jr9sPx
d+yt8HtQ1TT/AIz6v8QvEPw917416RN8CPhJbeG/CX7Qmr/UHj7/AIJSf8Jx 8Ovir4A/4X1/
Zf8Aws34Af8ABav4F/2t/wAKu+2/2J/w+D/an8LftL/8JT9g/wCFi2n9pf8A DO//AAjP/CFf
2J9ssP8Ahbf23/hI/wC1/hl9m/sGf6/8O/8ABQn9gXxf4E+IvxS8J/tw/sge KPhl8H/+ER/4
W18RfDv7S3wY1vwJ8Lv+FgaxP4d8B/8ACxfF2m+Nbnw/4J/4TbxBbXOheEf+ El1DTP8AhJNY
t59M0b7bexSQL0Gpftu/sX6N4q+EvgXWP2u/2YNJ8bfH3w/4D8WfAnwdqXx9 +FNj4q+NXhX4
qajJo/ww8S/CXw9deLItX+I/h/4j6vFLpfgPWfB1prOneMNRjksfD1zqNyjR AA/OD4gf8Eef
+Ex/aYk+P/8Awln7IHibyPiB+058SP7e+OP7Bv8AwuX9pj4k/wDDSX7Pf7R/ wR/4UT+0l+0r
/wANMeCf+F4/sgfDH/hon+xfA/7PX/CqvBH2X9nv4NfBT9n3/hPIP+EL/wCF k3/r/wAAv+Cc
PxC/Z98VfB74n+Ff2jPD938RPAXiD4xeHte8IX/wq+JmqfsweE/2avjzqP7L lx49/Z5/ZA+C
Hij9p/xR42/ZM8P+Hrb9jv4RXXwW0wfHb4w/BD4MeIPFnxyXwr+z43w78YfD L4Z/BX7g1P8A
ax/ZY0Tx38UvhbrP7S3wA0j4m/A74f6h8WPjX8OtT+Mnw6sPHfwf+FmkaPoX iLVfiX8UvCN1
4ji8QfD/AOH+meH/ABR4a13UPGXizT9I8O2Wj+ItC1O51KOy1fT57g8RftY/ sseENY+HXh3x
Z+0t8APC/iD4wfEDxd8J/hLoXiL4yfDrRNY+KPxT+H/juD4W+PPhp8OtM1Lx HbXvjb4geCfi
bc23w68XeDfDUGp+IvDfju4g8I6zptl4glj09gD8oPgn/wAEPPh78D9E8K+F fBms/sweB9I+
FviD9kqD4d+Mvg7+wj8M/hX8ffiD8Pf2Wf2uP2aP2n44f2wvj7b+PvEnjb9o P4wePLb9lzwl
4V1X4hfDwfs4/DObxp46+JHxd8cfAH4kaunwp8N/Cj7/AP2hP2B/gF8Z5/G/ xG8K/Df4P/C3
9qPxV4g+BfjZP2n9N+DPgvVPiZrfir9mb4y/Bf4+/BnQ/i14k05PCnxE+KXw ft/iJ+z18IrD
x58Nh8SvCOo+Jfh74Yj8MeFfHPw81y08MeMvDHoHwV/ag8K/Ev4IfEn48eOk 8P8Awb8E/Cv4
wftlfDjxjrfizxppyeFfD3hX9jz9pX42/ADxD8TvE3i/WLHwxpHhrw/rekfB i8+JOsrqgj07
wNp2q3Ok33iDWbbQ5fEeoFr+27+xffad8FNYsf2u/wBmC80j9pTxBqvhP9nT VLX4+/Cm4074
++KtC8Vaf4F1zw18FL6HxY9t8VPEGjeNtW0vwdqujeBZdd1HTvFWpaf4eu7a HV7y3tJAD4/+
MH/BP74+/HTTvijF48/ac+D9tq/7Wn7MGn/sZftu33hH9ljxpo+neNfgF4b8 VftH3fhOb9lb
S9Z/az8TXP7NvxgtPBP7Vvxa8PeIvHXxc1j9r7wXrviqx+HXjHTfhR4Z0jw5 4l8C+OcD4/8A
/BKT/hef7LFx+zR/wvr/AIRfz/2gP+CnHx0/4TX/AIVd/bez/h438Ov+Cjvg D/hFv+Ec/wCF
i6Ru/wCFOf8ADwL+1v7b/t4f8LC/4VJ9g/sjwP8A8J79s8GfX/wG/bv/AGWP 2itY8Z+D/Afx
h+H9v8Tfh/8AtAfF/wDZo8WfB3XfiD8Oovi7o3xT+D/jv47+D7nSdQ+H2jeM Nb8Qad/wsLw/
+zd8WvjF8LbDUrWy8ReLPgn4X1P4gyaDplloniW10LoNZ/bd/Yv8OfELwn8I /EP7Xf7MGhfF
bx74gufCfgX4Y6z8ffhTpfxC8aeKrP4meJfgreeGvCfgu+8WQeJPEfiC1+Mf gvxj8JbnRtH0
281GD4meE/EvgOW2XxToWqaVagHx/wDtl/sg/Ey6+Mus/t3/AAJ1LxB4w/aD +G/h/wDZdtvg
h8HtG+Gvw98dadP4q+D0H/BQH4TeL9Z8WaR8TP2pf2RfDfj7w/4g+Df/AAUm +J97beGl/aE+
A2o+C/FXwr8NeMrXxZ8Uo7u4+DHiPgP2fv2H/wBrg/DP9g3xD8Rviv8AB/4Z fET4Dftv/tj/
ALd/xm8C3PwH1vxhP441H9r/AOIX7Xl8nw00a78MftWTeG/gb4g8K/Bv9s34 laP4ls7Dxj+1
r4V8NfGW08Jy+GPih8Yfh38PdR1T42fo/wDGD46f8K38d/AX4UeGvC3/AAnv xN+PnxAu9E0r
w7Hrf9kWvgz4WeBtHm8XfGv46eN59P0jxR4g0z4f/D/w/Fo3gbR9XtvCt54d 8QftHfF/9m/4
JeLPFPw0svjVa/EXw18P+Gv+CuXwlu/2arn9q34mfs8ftP8AwB+FOu/sweLP 2tvgbcfFix/Z
4vNR/aZ+Gfgj4Iaz+0X4h8PfB6b4SftF/FTw3pPxgT4OaNcePdE+Dnxv8RfB z4heLvCtn4y8
U+ENC13wt8G/jxrnwtAPQPh9+yf+1x4Q+Mvx88eap+1z8H9R8N/H7xB8Q21T xfof7Iut2P7X
Hgn4eyQfEK3/AGavhx4G+N/jn9qL4m/s+aZ4f/ZTj8Z2Mngnw/d/sWX3wz8b a3H8SfiN46+G
Oo/GT4+/Gj4meL+g8C/ssftHaZ4x+JPxu8d/tQfD+f8AaN+J/wDwyD8P9d8Z fB39mu6+Hfws
i/Zx/ZV+O3j34w6n8MLX4T/FL47ftDeIE+IHxq8P/HT9oT4VeMPi8vxZS18L +HfGXw+8R+A/
hvoPjP4Z6hrfxA9A+Mn7avws+CWsftG+HfEugfEDWfEH7N3wA+Cnx91XQvCu leHdR1j4q/8A
DRXjv4+/C34KfBX4JaZqHirSb3xz+0B8S/ib+z5rPw68DfDi5g0L/hMvHfxC +FHhHwnrOt+I
PFl1p+i+v/AH41+Ff2i/g18PfjV4O0/xBoWkePfD8OpXfg7xna6dpfxC+G3i qznn0fx18Jfi
p4e0vVdctvB3xg+EPjbTvEPwx+L3gOXVbzUfAHxM8J+K/BesSLq+hX0SAHxB +0H/AME9vHfx
50f9rhrn9pb/AIR/xb+2b8APjX+yX8UrmT4NaPrHgTR/2cfEHgT40eGv2ZfD Pgjwnb+NdC8W
6X8QP2bPFvxi8WfEfWPiHrPxO8QWvxy1j4u/tIeH/Evg7wx4S8Qfso6N+xXw H7WP/BKT/hqD
Qv2ltF/4X1/wg/8Aw0R+0B8ZPjp9p/4Vd/wk3/CH/wDC2/8Agjb4j/4JJf8A CLeT/wALF8P/
APCQf8I//wAJB/w0B/bfm6J/av2T/hVP9kab5/8AwsmH6/8A+HhP7Av/AAqz /hen/DcP7IH/
AApL/hYH/Cp/+Fxf8NLfBj/hVn/C0/8AhHf+Ew/4Vp/wsH/hNf8AhEv+Fgf8 Il/xVP8Awhv9
r/8ACRf8I7/xO/7N/sz/AEqug1L9t39i/RvFXwl8C6x+13+zBpPjb4++H/Af iz4E+DtS+Pvw
psfFXxq8K/FTUZNH+GHiX4S+HrrxZFq/xH8P/EfV4pdL8B6z4OtNZ07xhqMc lj4eudRuUaIA
H0/X5gfF/wD4Js/8JB8E/jz+zp8A/wBob4gfBD4C/tDfAD47/AHxL8AvFemf 8L3+Cfw3sfjJ
8IvGfw40bxj+zxo3izxFoPxN+An/AArG9v8A4eWXgv4DfD34u6b+xt4a+EXg /wAU/Dv4ffsy
fD7x14+tvjV4M9A+FP8AwUR+Cfirwl8cvG3xk1z4f/s2+EvgD8QPin4R8c+O Pil8b/hFpHgT
TtH8F/txftWfsQ+CfEWu6jrninw14t8Df8LH8W/st3uuaZP4+8DeGfAmo6x4 80/4bfC/4i/F
zxb4I+JK+FfoDTP2sf2WNb8d/C34W6N+0t8ANX+Jvxx+H+n/ABY+Cnw60z4y fDq/8d/GD4Wa
vo+u+ItK+Jfwt8I2viOXxB8QPh/qfh/wv4l13T/GXhPT9X8O3uj+Hdd1O21K Sy0jUJ7cA+P/
AIsf8E2f+Fr+N/iX4r/4aG+IHw1/4WV+1/4y/ap/tn4T6Z/wh3xT8A/8Jj/w SP1L/glf/Yfw
0+Jn/CRaj/wivxA8K/2j/wAND+Dfi1/wi1//AGH4jsNN8F/8ILdfZf8AhNX+ QPDn/BFTWPC3
/C5NV8O3n/BMDwV4g+Kf/DNKaFo3wn/4JZeO/gv8LPhTrH7OX/DWNzpnxw+G nhr4W/8ABQ3w
t8TfAf7X93e/tPQWvg39qf4dfGvwL47+FPh34dabp/hGx/4SDU9P8WeFvv8A /Z6/4Ka/sgft
NfCz4b/Gv4afFr4ft8MvG3wA8eftCeMvEutfGP8AZ/tv+GfdH+F3h34E+LPi X4D/AGgNG034
vat4g8DfED4aeH/2g/BuofFZdN0rxJ4E+EH2aW1+LHjvwTe+L/hPbfEf0DxF /wAFCf2BfCHg
T4dfFLxZ+3D+yB4X+GXxg/4S7/hUvxF8RftLfBjRPAnxR/4V/rEHh3x5/wAK 68Xal41tvD/j
b/hCfEFzbaF4u/4RrUNT/wCEb1i4g0zWfsV7LHAwB8geJf8AglJ/bnws+NX7 P+ofHr/havwS
+Nf/AAzB8UPF1n+1J8Lv+GhPin48/an/AGRvDv7Ifgr4dePPjn4/n+IvgXwl 8aPgB8TfCX7F
fwti/aZ+Amp/Cnw98Rfi94j8Y/GLWtC/aa+G2meL/DvhzwR3/wCyb/wTc0f9 mH4p/Dr4t6Zq
3wA8M3vhX4f/ALVfhHxF8L/2XP2RfAn7JnwJu9Y/aV8R/sSXsHiLwN4B8I+M PGHiDQP+EZ8P
/sUaFH4mn+KXjz45eO/HnjH4j+IdS0/4i+Avhl4R+HXwb8Lff/xS+LHws+B3 gTXfil8a/iX8
P/g/8MvC/wDZn/CS/EX4peMvDvw/8CeHf7b1jT/Dujf274u8WalpHh/SP7X8 QavpWhaZ/aGo
W/2/WNT0/TLXzb29toJOA0z9rH9ljW/Hfwt+FujftLfADV/ib8cfh/p/xY+C nw60z4yfDq/8
d/GD4Wavo+u+ItK+Jfwt8I2viOXxB8QPh/qfh/wv4l13T/GXhPT9X8O3uj+H dd1O21KSy0jU
J7cA+X9a/wCCevhX4TeKvhp8Rv8AgnppP7MH7FPjb4eeH/jh4JuPDVt+ydp3 if4BeK/Cv7RO
o/s9a78TNc1n4QfBD4q/sp6u3xgbV/2U/gdYeGviS/xKudO0/wAF6X4s8MeI PA3iq51fwhr/
AMPvAPjn/wAEnPFXxw+HvxY+AmoftJ+H9A/Z813xB+318Wfgvotl8CNRvPjL 8Pvj7/wUK+Gf
7XPw/wDij4j+KHxTn+OMXgn4v/B/wZc/tz/tB654B+FXhT4JfA/xpDBZ/BvS PEPxu12TwN42
1b4r/b/7Iv7d/wCyx+2/8LPhX8Uv2f8A4w/D/wAVf8LX+H6+P7P4dW3xB+HW ufFPwZ/Z3h34
WeIvH/gr4g+EfBXjDxZ/wjvxA+Dv/C7PhVoXxi8ORahqP/CvvEfj7wfpmtXi f8JV4cn1XoPC
f7bv7F/j34meGvgr4F/a7/Zg8afGPxp4f0bxZ4O+EvhP4+/CnxH8TPFnhXxH 8Pbb4ueHvEvh
rwHo/iy88U674f134U3lp8TtG1nS9KutO1T4e3Vt40sbmfw3PFqTAHj/AMQf 2GP+E7/bs+GX
7a3/AAtH+yv+Fdf8KM/4tp/whP27+2P+FL/B3/gqP8J/+Ry/4S6z/s//AISX /h5R/b//ACKt
9/Y//Cl/7K/4mv8AwsX+0vAn5gftd/8ABOf9rHwT8Ov2jvhX+xtff8LJ8Qf8 FGfh/wDthfA3
9oDxf41+Efw21X4WfCbwJ8dv2p/21f2jvhVdXmr61+3F+z38TfhZ/wAIde/8 FHfjT4U8f/E3
4e/CH9uvWPFnh34ZeHPGfh/9mzwl4g0aL4a/GP8Ao+rz/wCKXxY+FnwO8Ca7 8UvjX8S/h/8A
B/4ZeF/7M/4SX4i/FLxl4d+H/gTw7/besaf4d0b+3fF3izUtI8P6R/a/iDV9 K0LTP7Q1C3+3
6xqen6Za+be3ttBIAeAfFL9k3/hoDx3rt58fPi98QPG3wFb+zLTw1+yb4UuP +FXfBPWLG20f
T7fWbj9oe78J3a/E39pv/hLr3UPiH4c8afCH4heP7b9jbx18IvEnhbwV8Qf2 TfF/jrwTc/F7
xafHL4W+O/8Aho79lP8AaZ+Guhf8Jhqfwy/4Wt+z38WPCcmp6PZXX/DOP7UF 18LNZ8ZePPBF
treoeGdMu/iB8L/jb+z/APs4+MdYbV/GENr/AMM42X7SGneEPAnxN+Nuq/B7 w1Xj/wANP+Ck
3wa+Jf7Q/wC0L8JT4m+D/wAM/BP7Mfwf0X4o/Fa9+OPxgn+C/wC0r4e07WPh L8D/AI/XHxF1
/wDZI+Inw90HxT8PP2YPC3wp+PnhXTfHfx0+Lvjz4deKvA3xv0Dxv8I/FXwT 0q20CPxzqH1B
4c/ax/ZY8Y+HfAHjDwj+0t8APFXhL4r/AGz/AIVb4p8OfGT4da54d+JX9nfF PwV8C9Q/4QDW
9M8R3WmeMfsHxt+JXw6+Dt5/wjt1qP2X4p+PvBXw+n2eLfFWhaRfgHy/+y/+ wf4q/Z68Vfsv
3esfGrw/478E/sa/swfG79jL4E+HtN+Eeo+C/FVx8AvH2o/sTy/DCb4t+Mbr 4teM9I8a/GDw
BpH7H0tj488deDvAvwv8F/FLUfiNHqnh74UfCK28HNo/iv5A+AH/AAQ8+Hvw G8afATxLHrP7
MHxGufhf4f8A2Op/GfxX+Jf7CPwz8d/tcXfxC/Y1+AXwE+AnhKb9nr9orxx4 +8VaR+zj8H/G
Okfs1fDvX9a+Htx8IPi78TPB+t+Mfjhrvwp+P3gHxt40+HnjX4Pfp/8ADb9t 39i/4y6j4J0f
4Qftd/swfFbV/iX4g8c+E/hzpfw2+Pvwp8c6j4/8VfDDwrofjr4leGvBNj4Y 8Wapc+KvEHw8
8E+J/DXjHxzo2hRX+o+EvCviHQ/EOv22n6Rq1hd3Bdftrfsjw6d8a9UsP2jf g/4qtv2afEGl
eGv2kovh9440T4k6j+zrqOqeKtQ8HTXPx80f4f3XiXV/gx4f8Mavonie7+If iz4lWPhjwr8M
PCvgj4heOviNrPhbwT8PPG/iHQADz/4w/sQ+Ffjp4q/bVu/HXjjxBa+Cf22P 2IPhp+xD4x8P
eE9O07SfFXg3wr4L1H9suXxD448NeMdYbxJpFz4g8R6R+19d2OjadqngWfTv C+o+ArbVL5vF
lt4jl0fRfn/wr/wT++Puu/theAv2yv2i/wBpz4P+P/G3w+8QfBe50vwr8FP2 WPGnwP8ACt54
V+DXwM/4KZfCKx0bUD46/az/AGiNXbxBrmr/APBSLXPFt14lt7+306z074Ua V4Wh8JzXPi27
8VaF+n/hPxZ4V8e+FfDXjrwL4l8P+NPBPjTw/o3izwd4x8J6zp3iPwr4s8K+ I9OttY8PeJfD
XiHR7m80jXfD+u6ReWmqaNrOl3d1p2qaddW19Y3M9tPFK3QUAfjD4i/4JOeK pPBf7X/gXwP+
0n4f0DSP26Pg/wDtp/BT493Hiv4Eaj4w1HTvCv7RXx9/4KC/tF/BLUPhDNpH xx8C23g3xB8F
fG3/AAUN+Iel/FS68Z2nxP074/eFfAngyx8JaV+zpq82ua5fdB4+/wCCUn/C cfDr4q+AP+F9
f2X/AMLN+AH/AAWr+Bf9rf8ACrvtv9if8Pg/2p/C37S//CU/YP8AhYtp/aX/ AAzv/wAIz/wh
X9ifbLD/AIW39t/4SP8Atf4ZfZv7Bn9/0T/go9+zj4y+KfhDw/4B8f8Aw/8A GHwF1v4Aftc/
HrxH+1hZ+OrWy+BOg6P+yJ4j/ZC0jxrN4c+Il5pKfDL4mfD+Cy/aqvG8a/GD wV8R77wJ8MPG
Pwf8f/DHxHd3Hjrw74/0n4d+waz+27+xf4c+DXhP9ovxD+13+zBoX7Pnj3xB c+E/Avx21n4+
/CnS/g1408VWc/iW1vPDXhP4n33iyDwT4j8QWtz4L8Y29zo2j65eajBP4T8S wy2yyaFqi2oB
8f8AwP8A+CWHw9+B37XGtftJ6DYfswPbT/GD9oX496T4ssv2LPhna/ttat8Q v2mdb+JfiX4g
+HPih+27rXifxPq/iX4P6Jq/xn8e2PgHwx8Mvg78FPiZpPgfw58G/hv4o+M/ jTwT4V+KejfH
HoPiT+x1478X/FP9qnwnpF5/YXwy/aV+IH7Kn7c3gj4ty2+j+Lf+FXftw/sb +I/2eNN0fwb8
TfAcnifwB4g8T/ADx14f/ZT/AGRvEvh3wd4CuT4t8Sf8Iz+2Zo3i/wCPnwNv fFf7N8i/YGmf
tY/ssa347+Fvwt0b9pb4Aav8Tfjj8P8AT/ix8FPh1pnxk+HV/wCO/jB8LNX0 fXfEWlfEv4W+
EbXxHL4g+IHw/wBT8P8AhfxLrun+MvCen6v4dvdH8O67qdtqUllpGoT2+/8A BT4/fBr9ovwr
qHjH4K/ELw/490jQvEF14M8Y2mmzT2fir4bfELS9O0rVPEPwr+LXgXWINO8b fCH4weDrbXNK
i8efCH4neHvCfxM8AajeR6P408KaFq6y2KAH5wzf8Ep9H1v9rG0/aw8bXX7I HjH4geLfiB8B
fjl8ZPiHr/7A3gTxb+0dB8bPgT8Nvg/8PbK1/ZV+PnxQ+KfxH/4Zk+AHiX/h Q/gbVj8Mtc+H
fx2+Lvge68W/GjV/ht+0n4S+IHjHwD8QfhJz/wANf+CVnxC+FkGkeMvBH7QH wf8Ah58Vvhp8
YPCHxa/Z++G3wm/Zr+Jngb/gnV8GtR0H4NftHfAjxXJ4c/YP1D9sPxbc+EvE Hxa8E/tafGPW
virq
Previous Topic:Unable to Load resource from the jar
Next Topic:[CDO]LastCommitTime can not be saved
Current Time: Wed Aug 12 07:54:33 GMT 2020
Powered by FUDForum. Page generated in 0.01493 seconds
