Re: java.lang.UnsupportedOperationException: setSpecification is not supported. [message #631524 is a reply to message #631504] |
Thu, 07 October 2010 20:20 |
Dave,
I believe this is a nuisance error and the DTP dev team is aware of it.
The report should still run fine. Did it work for you.
Jason
On 10/7/2010 2:49 PM, Dave wrote:
> Override database connection on server side:
> task.getAppContext().put("OdaJDBCDriverPassInConnection", connection);
> I got the following exception:
> at org.eclipse.birt.report.data.oda.jdbc.Statement.setSpecifica
> tion(Statement.java:943)
> at org.eclipse.datatools.connectivity.oda.consumer.helper.OdaQu
> ery.setSpecification(OdaQuery.java:1488)
> at org.eclipse.birt.data.engine.odaconsumer.Connection.setOdaQu
> erySpec(Connection.java:318)
> at org.eclipse.birt.data.engine.odaconsumer.Connection.prepareO
> daQuery(Connection.java:288)
> at org.eclipse.birt.data.engine.odaconsumer.Connection.prepareS
> tatement(Connection.java:197)
> at org.eclipse.birt.data.engine.executor.DataSource.prepareStat
> ement(DataSource.java:300)
> at org.eclipse.birt.data.engine.executor.DataSourceQuery.prepar
> e(DataSourceQuery.java:276)
> at org.eclipse.birt.data.engine.impl.PreparedOdaDSQuery$OdaDSQu
> eryExecutor.prepareOdiQuery(PreparedOdaDSQuery.java:441)
> at org.eclipse.birt.data.engine.impl.QueryExecutor.prepareExecu
> tion(QueryExecutor.java:340)
> at org.eclipse.birt.data.engine.impl.PreparedQuery.doPrepare(Pr
> eparedQuery.java:448)
> at org.eclipse.birt.data.engine.impl.PreparedDataSourceQuery.pr
> oduceQueryResults(PreparedDataSourceQuery.java:190)
> at org.eclipse.birt.data.engine.impl.PreparedDataSourceQuery.ex
> ecute(PreparedDataSourceQuery.java:178)
> at org.eclipse.birt.data.engine.impl.PreparedOdaDSQuery.execute
> (PreparedOdaDSQuery.java:145)
> at org.eclipse.birt.report.data.adapter.impl.DataRequestSession
> Impl.execute(DataRequestSessionImpl.java:617)
> at org.eclipse.birt.report.engine.data.dte.DteDataEngine.doExec
> uteQuery(DteDataEngine.java:152)
> at org.eclipse.birt.report.engine.data.dte.AbstractDataEngine.e
> xecute(AbstractDataEngine.java:265)
> at org.eclipse.birt.report.engine.executor.ExtendedGenerateExec
> utor.executeQueries(ExtendedGenerateExecutor.java:205)
> utor.execute(ExtendedGenerateExecutor.java:65)
> at org.eclipse.birt.report.engine.executor.ExtendedItemExecutor
> .execute(ExtendedItemExecutor.java:62)
> at org.eclipse.birt.report.engine.internal.executor.dup.Suppres
> sDuplicateItemExecutor.execute(SuppressDuplicateItemExecutor .java:43)
> at org.eclipse.birt.report.engine.internal.executor.wrap.Wrappe
> dReportItemExecutor.execute(WrappedReportItemExecutor.java:4 6)
> at org.eclipse.birt.report.engine.internal.executor.l18n.Locali
> zedReportItemExecutor.execute(LocalizedReportItemExecutor.ja va:34)
> at org.eclipse.birt.report.engine.layout.html.HTMLBlockStacking
> LM.layoutNodes(HTMLBlockStackingLM.java:65)
> at org.eclipse.birt.report.engine.layout.html.HTMLPageLM.layout
> (HTMLPageLM.java:90)
> at org.eclipse.birt.report.engine.layout.html.HTMLReportLayoutE
> ngine.layout(HTMLReportLayoutEngine.java:99)
> at org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.doR
> un(RunAndRenderTask.java:180)
> at org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.run
> (RunAndRenderTask.java:77)
> BIRT 2.6.1
> Thanks for help.
> Dave
Re: java.lang.UnsupportedOperationException: setSpecification is not supported. [message #631749 is a reply to message #631564] |
Fri, 08 October 2010 15:26 |
Dave,
Does it work when you do not set the connection in the appcontext?
Jason
On 10/7/2010 9:39 PM, Dave wrote:
> I looked at the image directory. The chart image was not created.
> In eclipse design, I removed all report parameters related to jdbc
> connection(url, username,password), and set the connection at runtime.
> How should I debug the issue?
> Thanks
> Dave
Re: java.lang.UnsupportedOperationException: setSpecification is not supported. [message #632150 is a reply to message #631887] |
Mon, 11 October 2010 18:32 |
Have you looked at
EngineConfig.setLogRollingSize
and
EngineConfig.setLogMaxBackupIndex
Jason
On 10/9/2010 11:08 PM, Dave wrote:
> Jason,
> It is working now. It might be due to a report design error. After
> recreating the design, it worked fine.
> I set log LEVEL to warn, FINE/DEBUG level messages was logged.
> EngineConfig config = new EngineConfig( );
> config.setLogConfig(logDir, Level.WARNING);
> engine.changeLogLevel(Level.WARNING);
> Is there a way to config the logging? limit log file size and file number.
> Dave
FUDForum. Page generated in 0.02836 seconds
