Re: inheritance from own defined EDataType [message #631388 is a reply to message #631387] |
Thu, 07 October 2010 11:25 |
Am 07.10.2010 12:59, schrieb Martin Jacob:
> Hi Eike,
> thanks for the hint. I defined an EClass as follows:
> <eClassifiers xsi:type="ecore:EClass" name="DefaultClient" instanceClassName="de.bahntechnik.dd.util.net.http.DefaultClient "/>
> Now I can use this EClass for inheritance but the generated code implements and not extends the EClass from above:
> public class DefaultClientImpl extends EObjectImpl implements DefaultClient {
> How can I generate the code that DefaultClientImpl extends DefaultClient?
I have no experience with EClasses who's objects are not instances of EObjectImpl ;-(
Cheers
/Eike
http://www.esc-net.de
> Martin
> Eike Stepper wrote, On 07.10.2010 11:46:
>> Hi Martin,
>> I fear it's only possible to define inheritance between EClasses.
>> Cheers
>> /Eike
>> http://thegordian.blogspot.com
>> http://twitter.com/eikestepper
>> Am 07.10.2010 10:54, schrieb Martin Jacob:
>>> Hi,
>>> I try to define a inheritance in class A from class B. Class B is a EDataType by my self.
>>> See the class B from the ecore sniped
>>> <eClassifiers xsi:type="ecore:EDataType" name="DefaultClient"
>>> serializable="false"/>
>>> <eClassifiers xsi:type="ecore:EClass" name="OtClientIf"/>
>>> Unfortunately I am not able to define a inheritance in class A from class B. I am using the ecore
>>> diagram to design my model.
>>> Is it not possible to do such kind of inheritance or what do I wrong?
>>> BR, Martin
Cheers
/Eike
Re: inheritance from own defined EDataType [message #632204 is a reply to message #631435] |
Tue, 12 October 2010 05:58 |
Martin Jacob Messages: 191 Registered: July 2009 |
Hi Ed,
sorry for late reply but I was busy with other things.
I tried as u suggested and set the EClass to abstract and as interface:
abstract="true" interface="true"/>
From this class I derived class X:
<eClassifiers xsi:type="ecore:EClass" name="X" eSuperTypes="#//DefaultClient"/>
unfortunately the generated code was not able to compile. The problem is as follow in X.java:
public interface X extends EObject, DefaultClient: but DefaultClient is not a interface it is a class
Do u have any suggestion how to extend a existing class with a class in my ecore model?
Martin
Ed Merks wrote, On 07.10.2010 15:54:
> Martin,
> You should set abstract and interface to true on that EClass.
> Martin Jacob wrote:
>> Hi Eike,
>> EClass from above:
>> Martin
>>> Hi Martin,
>>> Cheers
>>> /Eike
>>>> Hi,
>>>> BR, Martin
Re: inheritance from own defined EDataType [message #632277 is a reply to message #632204] |
Tue, 12 October 2010 12:06 |
Ed Merks Messages: 33137 Registered: July 2009 |
Martin,
EClass instances must implement the EObject/InternalEObject interfaces
which they must do by extending some derivative of BasicEObjectImpl.
Therefore you can't just extend some existing plain old class.
Martin Jacob wrote:
> Hi Ed,
> in my ecore model?
> Martin
>> Martin,
>> Martin Jacob wrote:
>>> Hi Eike,
>>> EClass from above:
>>> DefaultClient {
>>> DefaultClient?
>>> Martin
>>>> Hi Martin,
>>>> Cheers
>>>> /Eike
>>>>> Hi,
>>>>> BR, Martin
Ed Merks
FUDForum. Page generated in 0.15070 seconds
