Chart Error [message #631351] |
Thu, 07 October 2010 08:12 |
i have a problem.
1. Eclipse Version : 3.6
2. Birt version : 2.6.1(update site install)
can you help me.
detail log
org.eclipse.birt.chart.exception.ChartException at:
org.eclipse.birt.chart.reportitem.ui.ReportDataServiceProvid er.initialize(ReportDataServiceProvider.java:279)
org.eclipse.birt.chart.ui.swt.wizard.preview.ChartLivePrevie wThread.initDataEngine(ChartLivePreviewThread.java:237)
org.eclipse.birt.chart.ui.swt.wizard.preview.ChartLivePrevie wThread.run(ChartLivePreviewThread.java:153)
Caused By:Loader can not resolve Rhino classes
org.mozilla.javascript.Context.setApplicationClassLoader(Con text.java:2306)
org.eclipse.birt.report.engine.javascript.JavascriptEngine.s etApplicationClassLoader(JavascriptEngine.java:325)
org.eclipse.birt.core.script.ScriptContext.createEngine(Scri ptContext.java:244)
org.eclipse.birt.core.script.ScriptContext.getScriptEngine(S criptContext.java:230)
org.eclipse.birt.report.engine.adapter.ModelDteApiAdapter.<init >(ModelDteApiAdapter.java:177)
org.eclipse.birt.report.engine.data.dte.AbstractDataEngine.<init >(AbstractDataEngine.java:107)
org.eclipse.birt.report.engine.data.dte.DteDataEngine.<init >(DteDataEngine.java:85)
org.eclipse.birt.report.engine.data.DataEngineFactory.create DataEngine(DataEngineFactory.java:100)
org.eclipse.birt.report.engine.executor.ExecutionContext.ope nDataEngine(ExecutionContext.java:837)
org.eclipse.birt.report.engine.executor.ExecutionContext.get DataEngine(ExecutionContext.java:854)
org.eclipse.birt.report.engine.api.impl.EngineTask.getDataSe ssion(EngineTask.java:525)
org.eclipse.birt.chart.reportitem.ui.ReportDataServiceProvid er.initialize(ReportDataServiceProvider.java:257)
Re: Chart Error [message #631461 is a reply to message #631351] |
Thu, 07 October 2010 15:02 |
This error looks like it has to do with the
org.mozilla.javascript_1.7.2.v201005080400 plugin not being accessible.
Can you verify its in your plugins. This may be a bug with update
install. Can you log a bugzilla entry for it?
As a work around can you look at trying either the allinone download or
use the framework download to add birt to your eclipse install.
http://download.eclipse.org/birt/downloads/
Jason
On 10/7/2010 4:12 AM, hangum wrote:
> i have a problem.
> can you help me.
> detail log
> text.java:2306)
> ptContext.java:244)
FUDForum. Page generated in 0.02780 seconds
