Home » Modeling » Epsilon » [EuGENia] GMF compartment nodes behaving badly
[EuGENia] GMF compartment nodes behaving badly [message #631207] Wed, 06 October 2010 10:56 Go to next message
Hello guys,
I'am a total newbie on GMF and Eugenia and having a problem with compartment features.
If I have following - very simple model defined - compartments wont work correctly. If I create two Box elements on the canvas and then drag one of them into another, there will be "shadow" Box element created as well. It is not a new Box object in the model but it just will be shown in the diagram...
Am I missing something or is this a bug? I could not find anything about this from previous posts...
@gmf.diagram(foo="bar")
class Diagram {
val Box[*] elements;
@gmf.node(label="name")
class Box{
attr String name;
@gmf.compartment(foo="bar")
val Box[*] boxes;
Thanks in advance,
Jan
Re: [EuGENia] GMF compartment nodes behaving badly [message #631352 is a reply to message #631207] Thu, 07 October 2010 04:12 Go to previous messageGo to next message
Hi Jan,
Unfortunately, I can't seem to be able to reproduce this. Which version
of Eclipse/GMF are you using? I've tried this with Galileo Modeling SR2
and it works as expected (no shadow boxes).
Dimitris
On 06/10/2010 16:56, Jan Landen wrote:
> Hello guys,
> in the diagram...
> class Diagram {
> val Box[*] elements; }
> class Box{
> attr String name;
> val Box[*] boxes;
> Thanks in advance,
> Jan
Re: [EuGENia] GMF compartment nodes behaving badly [message #631358 is a reply to message #631352] Thu, 07 October 2010 04:45 Go to previous messageGo to next message
Hello Dimitris,
Thank you for your reply!
I have Eclipse Helios as my IDE running on 64bit windows 7 with Eugenia version 0.8.9 and GMF SDK 2.3.0.
I had the same odd behavior with the Filesystem example as well...
I'll try this with other setup and let you know the result.
//Jan
Re: [EuGENia] GMF compartment nodes behaving badly [message #631386 is a reply to message #631207] Thu, 07 October 2010 07:15 Go to previous messageGo to next message
Hello again,
I tried this again with Helios SR1 (64bit Windows 7) with following details.
The issue still remains - will produce "shadow" objects.
I'll try this with previous versions of Eclipse...
org.eclipse.gmf (1.4.1.v20100909-1300-7d9A78FYnmMD7VBZOqOghp2tsgXc) "Graphical Modeling Framework"
org.eclipse.gmf.doc (1.4.0.v20100518-2359-35-8s733L3H7L17395) "Graphical Modeling Framework Documentation"
org.eclipse.gmf.examples.runtime.ui.pde (1.4.0.v20100511-1355-2307w3121183101141) "Graphical Modeling Framework (GMF) Runtime Examples Plug-in"
org.eclipse.gmf.runtime.notation (1.4.1.v20100909-1000-37708s73533F5C1479I) "GMF Notation Model Support"
org.eclipse.gmf.runtime.sdk (1.4.1.v20100909-1300-67G29E9QYAZrXowmYt08ti7x8V1i) "Graphical Modeling Framework Runtime SDK"
org.eclipse.gmf.sdk (2.3.0.v20100508-1742-7779-95sDcLbJSsdu7Xz-x9w7ogv) "Graphical Modeling Framework SDK"
org.eclipse.gmf.tooling (2.3.0.v20100421-2359-7c7MFO-FLWUl0ilw5sQPVD1) "Graphical Modeling Framework Tooling"
org.eclipse.epsilon.eugenia (0.8.9.201004151115) "Eugenia Plug-in (Incubation)"
org.eclipse.epsilon.eugenia.runtime (0.8.9.201004151115) "Eugenia Runtime Plug-in (Incubation)"
//Jan
Re: [EuGENia] GMF compartment nodes behaving badly [message #631395 is a reply to message #631386] Thu, 07 October 2010 07:42 Go to previous messageGo to next message
Many thanks for the update. Please keep the newsgroup posted with your
findings!
Dimitris
On 07/10/2010 13:15, Jan Landen wrote:
> Hello again,
> details.
> (Incubation)"
> //Jan
Re: [EuGENia] GMF compartment nodes behaving badly [message #631427 is a reply to message #631207] Thu, 07 October 2010 10:14 Go to previous messageGo to next message
I installed galileo modelling package (sr2) and now it works fine.
Many thanks!
//jan
Re: [EuGENia] GMF compartment nodes behaving badly [message #631540 is a reply to message #631427] Thu, 07 October 2010 17:18 Go to previous message
Hi Jan,
Thanks for letting us know! I'll have a look at the new Helios distro to
figure out what's going wrong there and get back to you.
Dimitris
Jan Landen <jan.m.landen@gmail.com> wrote:
> Hello,
> Many thanks!
> //jan
Previous Topic:need help in ETL transformation rules
Next Topic:EOL .add alternative required
Current Time: Sat Nov 08 19:25:10 EST 2025
Powered by FUDForum. Page generated in 0.03770 seconds
