Home » Eclipse Projects » DTP » Open SQL-File ignores BOM
Open SQL-File ignores BOM [message #631185] Wed, 06 October 2010 14:03 Go to next message
Tomka Kuje is currently offline Tomka KujeFriend
I have several SQL-Files that are encoded with UTF-16 (LE). The BOM is set correctly.
If I doubleclick one of this files in the Navigator, the SQL-Editor opens and displayes the file corrupted. If I rightclick on the file and select "properties", the encoding is set to "Default (inherited from container: Cp1252)". If I change the encoding manually to UTF-16 the file is displayed fine in SQL-Editor.
If I rename the same files (with the UTF-16-(LE)-BOM) to "x.txt", Eclipse interprets them as textfiles and reads the BOM correctly. The Properties-Dialog displays now "Byte Order Mark is UTF-16 Little-Endian (BOM)".
The files are distributed over several folders of my projects, so setting the file type to UTF-16 manually is no solution.
Is this a Bug in the DTP or the SQL-Editor and I should report a bug or is there any other solution?
Re: Open SQL-File ignores BOM [message #631218 is a reply to message #631185] Wed, 06 October 2010 15:12 Go to previous message
Brian Fitzpatrick is currently offline Brian FitzpatrickFriend
Hi there...
Please go ahead and report this as a bug against SQL tools for now with
repro steps and a sample SQL file with the troublesome encoding. We'll
see what we can do.
--Fitz
Tomka Kuje wrote:
> Hello,
> set correctly.
> (BOM)".
Previous Topic:How change default value in DSE?
Next Topic:'Can not issue data manipulation statements with executeQuery()' on Execution Plan window
Current Time: Tue Mar 02 05:45:06 GMT 2021
Powered by FUDForum. Page generated in 0.01574 seconds
