Home » Archived » M2M (model-to-model transformation) » QVTo log writer gets strings instead of objects, making custom loggers useless/impossible
QVTo log writer gets strings instead of objects, making custom loggers useless/impossible [message #631110] Wed, 06 October 2010 08:06 Go to next message
Originally posted by: dhendriksREMOVE_THIS.tueREMOVE.THIS.nl
Hello all,
QVTo has a org.eclipse.m2m.qvt.oml.util.WriterLog class that implements
org.eclipse.m2m.qvt.oml.util.Log. There is a:
void log(String message, Object param);
method in the interface. If I do this in QVTo:
log("some message", someObj);
I would expect that 'param' in the log method of the Log interface,
would get the value of the object I provided (someObj in this case).
However, the doVisitLogExp method of the
org.eclipse.m2m.internal.qvt.oml.evaluator.QvtOperationalEva luationVisitorImpl
class (which calls the log method of the logger), uses the
EvaluationUtil.formatLoggedElement method to convert the object to a
string representation, before passing it along to the log method of the
logger.
This means that the log method of the logger (like the WriterLog class),
always get strings instead of the objects. This also means I can't do
anything custom to create different string representations for the
objects being logged. That is, not without changing QVTo itself.
My questions:
- Why is the object converted to string before passing it to the
logger?
- Could this behavior be changed, so that the object itself is passed
to the logger?
Dennis
Re: QVTo log writer gets strings instead of objects, making custom loggers useless/impossible [message #632819 is a reply to message #631110] Thu, 14 October 2010 11:16 Go to previous messageGo to next message
Sergey Boyko is currently offline Sergey BoykoFriend
Hi Dennis,
Looks like doVisitLogExp() performs excessive toString() conversion.
I've files this as a bug:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=327757
Sergey
Dennis Hendriks wrote:
> Hello all,
> logger.
> My questions:
> logger?
> to the logger?
> Best regards,
> Dennis
Re: QVTo log writer gets strings instead of objects, making custom loggers useless/impossible [message #632824 is a reply to message #632819] Thu, 14 October 2010 11:49 Go to previous message
OK, thanks Sergey.
Dennis
Sergey Boyko wrote:
> Hi Dennis,
> Regards,
> Sergey
>> Hello all,
>> implements org.eclipse.m2m.qvt.oml.util.Log. There is a:
>> the logger.
>> class), always get strings instead of the objects. This also means I
>> can't do anything custom to create different string representations
>> for the objects being logged. That is, not without changing QVTo itself.
>> My questions:
>> logger?
>> to the logger?
>> Best regards,
>> Dennis
Previous Topic:[ATL] a working example of a programmatic launch
Next Topic:[ATL] Query in HOT transformation
Current Time: Sat Sep 26 22:57:19 GMT 2020
Powered by FUDForum. Page generated in 0.04378 seconds
