Home » Archived » EPF » Automated publish?
Automated publish? [message #630851] Tue, 05 October 2010 06:14 Go to next message
is it possible to automate the publishing? I'd like to integrate EPF with Ant, but I did not find anything about that (what makes me assume that there is no possibility...).
Re: Automated publish? [message #633480 is a reply to message #630851] Mon, 18 October 2010 03:47 Go to previous message
Well, I found an entry in bugzilla, which points out the batch publishing feature available since 1.5.0 (https://bugs.eclipse.org/bugs/show_bug.cgi?id=148030). However, when trying the mentioned command lines, they do not work (using EPF 1.5.1).
After playing around with some combinations, I found out that calling EPF with
java -jar "C:\Program Files\epf-composer\plugins\org.eclipse.equinox.launcher_1.0.1.R33x_v20080118.jar" -libraryPath "<path to library>"
alone starts the EPF composer, but does not load the library (what would explain why nothing is published when using the complete command line incl. publishPath and config parameters).
Question: Is this the intended behaviour (i.e., is it normal that this command line leads to that result), or is it a bug (i.e., actually the library should have been loaded and be visible)?
Gerhard
Previous Topic:OpenUP Document Templates Corrupt
Next Topic:Cloud and SOA Expert Dr. Chris Harding Speaking at Business Technology Summit 2010
Current Time: Mon May 19 14:29:34 EDT 2025
Powered by FUDForum. Page generated in 0.03046 seconds
