Re: problem installing the 64 bit (3.6.1) [message #630903 is a reply to message #630808] |
Tue, 05 October 2010 14:32 |
On 2010.10.05 0:45, za wrote:
> When starting eclipse, it did not find Java. I manually added
> C:\Windows\SysWOW64 to the path. Now the program started but returned
> these messages (below). I have a 64 bit Windows 7 home premium. (the 32
> bit version works fine both on this computer and on a 32 bit machine.)
> Any ideas?
> Java was started but returned exit code=13
> C:\Windows\SysWOW64\java.exe
> -Xms40m
> -Xmx384m
> -XX:MaxPermSize=256m
> -jar C:\eclipse\plugins/org.eclipse.equinox.launcher_1.1.0.v20100 507.jar
> -os win32
> -ws win32
> -arch x86_64
> -showsplash
> -launcher C:\eclipse\eclipsec.exe
> -name Eclipsec
> --launcher.library
> C:\eclipse\plugins/org.eclipse.equinox.launcher.win32.win32.
> x86_64_1.1.1.R36x_v20100810\eclipse_1309.dll
> -startup C:\eclipse\plugins/org.eclipse.equinox.launcher_1.1.0.v20100
> 507.jar
> -exitdata 1238_50
> -vm C:\Windows\SysWOW64\java.exe
> -vmargs
> -Xms40m
> -Xmx384m
1) Don't attempt to run Eclipse off anything but a Sun JDK you've
freshly downloaded when you set up Eclipse. You can, but it's not in my
opinion "best practice". Right now, that means downloading, whether
32-bit or 64-bit, jdk1.6.0_21 from the Sun Java site. I even suggest
downloading and not actually installing the JDK, but keeping it as a
private copy for use only by Eclipse. This frees you from anything going
on in the rest of your computer host.
2) Remember: Ensure that your Eclipse and your JDK are of identical
bittedness.
3) I assume that the lack of a newline in your -mv argument above is an
artifact of copying and pasting. There should be one. See
http://wiki.eclipse.org/Eclipse.ini
I hope this helps.
Re: problem installing the 64 bit (3.6.1) [message #631791 is a reply to message #631705] |
Fri, 08 October 2010 18:38 |
za Messages: 2 Registered: October 2010 |
I followed Russell Bateman advice and it worked. I loaded the 64 bit JDK as I should have. The Eclipse is and was the 64 bit all the time.
the problem in -vm line is not due to any error of mine, this is what the unzip/installation had, but I did not have to touch that at all.
Thank you all
ZA
[Updated on: Fri, 08 October 2010 18:39] Report message to a moderator
FUDForum. Page generated in 0.08943 seconds
