Problem with Charts - BIRT crashes [message #629999] |
Thu, 30 September 2010 09:58 |
Michael Messages: 1 Registered: September 2010 |
I have a problem with BIRT concerning Charts.
I cannot use Reports including any kind of charts.
Everytime i click via the index.jsp on a report that includes charts, nothing happens in my browser window. The page is loading and loading ....
After a click on a report with a chart, i cannot view any kind of reports any more, even reports with only data in it. It seems like BIRT crashes everytime i request a report with a chart in it. The only way to fix this, is restarting my JBoss Server (Version 5.1).
I have checked the log files, but there is no explanation why charts are not working.
Here is the log file entry (i already set the log level to the lowest):
FEIN: ReportEngine.openReportDocument: systemId=/ebsvolumes/applserver/lineski/server/lineski/deplo y/dwh.war/Chart.rptdesign, file=/ebsvolumes/applserver/skiline/server/skiline/deploy/dw h.war/documents/BIRTDOC5484961F8098B13A1A201A4E03A074FA.skil inenode1/20100930_114455_026/Chart.rptdocument, options={resourceFolder=/ebsvolumes/applserver/lineski/serve r/lineski/deploy/dwh.war, semanticCheck=false}
Sep 30, 2010 11:44:55 AM org.eclipse.birt.report.engine.api.impl.ReportEngine openReportDesign
FEIN: ReportEngine.openReportDesign: name=file:/ebsvolumes/applserver/skiline/server/skiline/depl oy/dwh.war/Chart.rptdesign, designStream=java.io.FileInputStream@105f6e8b, options={3}
It is also very confusing that this problem only happens on my remote server JBoss 5.1 installation. If i install JBoss 5.1 on my local machine i have no problems with chart-reports.
Do you need any more info regarding my problem?
I hope someone can help me ... BIRT without charts is very boring
Thanks in advance,
regards
Michael
Re: Problem with Charts - BIRT crashes [message #630096 is a reply to message #629999] |
Thu, 30 September 2010 15:47 |
Michael,
What OS and Java versions are you using?
Also what BIRT version?
Jason
On 9/30/2010 5:58 AM, Michael wrote:
> Hello,
> not working.
> r/lineski/deploy/dwh.war, semanticCheck=false} Sep 30, 2010 11:44:55 AM
> designStream=mailto:java.io.FileInputStream@105f6e8b, options={3}
> I hope someone can help me ... BIRT without charts is very boring ;)
> Thanks in advance,
> regards
> Michael
Re: Problem with Charts - BIRT crashes [message #676080 is a reply to message #676073] |
Thu, 02 June 2011 18:09 |
Are you deploying the WebViewerExample to JBoss AS on redhat? What
url are you using? Can you try /preview instead of /frameset?
Also what version of BIRT are you using?
Jason
On 6/2/2011 1:39 PM, B Boose wrote:
> bump for same issue.
> I can run the same jboss instance on a windows 7 box with a sun jvm and
> reports with charts work. I can run a stripped down jboss on another
> redhat server and charts work. I've tried isolating the proxy server and
> directly tagging the AS, using the WebViewerExample with the reports
> included n the war. Nothing. I have one entry in the birt logs:
> FINE: ReportEngine.openReportDesign:
> name=file:/home/jboss/birt/deploy/reports/tqi_contact_time_domain.rptdesign,
> designStream=java.io.FileInputStream@b41d22b, options={3}
> and nothing after that
Re: Problem with Charts - BIRT crashes [message #676269 is a reply to message #676103] |
Fri, 03 June 2011 13:02 |
It would be good if you could log a bug for this.
Jason
On 6/2/2011 4:31 PM, B Boose wrote:
> figured it out, I think this might be bug worthy.
> As I said above, I'm running birt 2.6.1 and jboss 5.1
> also:
> redhat 5.3 kernel 2.6.18-128.1.16.el5 64bit
> jRockit jvm jrmc-3.1.2-1.6.0
> java 1.6.0_14-b08
> I made many configuration changes, nothing worked until I changed out my
> jvm. I changed jboss's run.conf JAVA_HOME variable to sun's jvm with
> jdk1.6.0_24. That fixed the problem. It could be that the problem is the
> java version and not the jvm, but until we can get an updated jRockit
> jvm installed I won't know.
> Jason Weathersby wrote on Thu, 02 June 2011 14:09
>> Are you deploying the WebViewerExample to JBoss AS on redhat? What url
>> Jason
FUDForum. Page generated in 0.03694 seconds
