Define for extensions if they should be used depending on their environment (stand-alone / Eclipse) [message #629969] |
Thu, 30 September 2010 07:26 |
No real name Messages: 5 Registered: June 2010 |
Hello everybody,
I have the following problem: Currently I develop a standalone RCP applikation which I also want to include into the Eclipse IDE. This is not the problem, if I copy my plug-ins to the Eclipse Plug-in folder everything works fine. The problem is, that I don't want to have every extension I made in the stand-alone application also in the Eclipse IDE (e.g. menu).
I don't want to have an additional project only for the Eclipse plug-in because then I have two places to maintain. So what I need is the following: I want to declare for extensions if they should be used only for the stand-alone application, only for the Eclipse plug-in or for both. Is there any possibility to declare for extensions that they e.g. only should be used when they are used within the Eclipse IDE?
I hope someone can help me. If you don't understand the problem correct, feel free to ask.
Greetings
[Updated on: Thu, 30 September 2010 07:27] Report message to a moderator
Re: Define for extensions if they should be used depending on their environment (stand-alone / Eclip [message #630311 is a reply to message #629969] |
Fri, 01 October 2010 14:31 |
Thanks for your reply.
You are correct. I don't want to have the overhead of splitting my current bundle into two.
I tried the thing with the menu contribution. This is exactly what I want. I want to define if menu entries are available depending on Eclipse IDE or my stand-alone app.
It makes me sad that it is not possible for other things like views or toolbars. But I understand your point that this is not intended. So as I understand you correct I have no other choice than split my current plug-in into two.
Thanks again for your answer. It helped a lot.
Greetings
[Updated on: Fri, 01 October 2010 14:33] Report message to a moderator
FUDForum. Page generated in 0.03137 seconds
