Home » Modeling » EMF » [EMF] FeatureMap with EOpposites
Re: [EMF] FeatureMap with EOpposites [message #629788 is a reply to message #629751] |
Wed, 29 September 2010 14:44 |
Ed Merks Messages: 33140 Registered: July 2009 |
Mario,
Comments below.
Mario wrote:
> Hi everybody,
> is it possible to model a FeatureMap based on references with
> opposites? I annotated the model like proposed in the EMF book, but
> the generated code always contains errors, because it generates a
> normal Elist instead of a FeatureMap
> In the class "Container" i have list of "Node" in the *.ecore:
> <eStructuralFeatures xsi:type="ecore:EReference" name="nodes"
> upperBound="-1"
> eType="#//Node" containment="true" eOpposite="#//Node/parent">
> <eAnnotations
> source="http:///org/eclipse/emf/ecore/util/ExtendedMetaData">
> <details key="kind" value="group"/>
Doesn't a group need to be a feature map?
> </eAnnotations>
> </eStructuralFeatures>
> Then i have a "IFDiagram" and "IGDiagram" Classes that extend the
> "Container" Class containing this:
> <eStructuralFeatures xsi:type="ecore:EReference" name="node"
> upperBound="-1" eType="#//Node"
> changeable="false" volatile="true" transient="true"
> derived="true" containment="true">
> <eAnnotations
> <details key="group" value="#nodes"/>
> </eAnnotations>
> and a "Node" class with a reference to the parent "Container" like this:
> <eStructuralFeatures xsi:type="ecore:EReference" name="parent"
> eType="#//Container"
> eOpposite="#//Container/nodes"/>
> The getNode() methods of IFDiagram and IGDiagram are correctly
> generated, but the getNodes() Method in "Container" has the returntype
> EList<Node>, because the reference isn't mapped to a featuremap :/
> I know that one could model a multi-value Attribute with
> FeatureMapEntry type, but attributes don't support eopposites, i guess?
No, but the features that delegate into the map can.
> So what did i made wrong?
It looks wrong to me.
> Or is this simply not possible?
Feature maps themselves can't have opposites. The features that
delegate to them can. Try to write your model as a schema...
> Greets, Mario
Ed Merks
Re: [EMF] FeatureMap with EOpposites [message #629845 is a reply to message #629788] |
Wed, 29 September 2010 17:49 |
Mario Charest Messages: 42 Registered: July 2009 |
Member |
Hi Ed,
thanks for your answer.
The EMF-Book suggests a Multi-Value Attribute (which works perfectly)
but mentiones (in a little sidenote, though), that this should also work
with a reference.
I just found an online doc
( http://www.eclipse.org/modeling/emf/docs/overviews/FeatureMa p.pdf)
which says:
"[..] (Note: I think that we should change the importer to alternatively
allow the orders feature to be defined in UML as a
third reference to PurchaseOrder as in the previous diagram. I think
that providing the kind=group annotation
would be sufficient information to indicate that it maps to a FeatureMap
implementation) [..]"
My initial question was merely if this feature (annotating reference
with kind=group) realy exists and if yes, why it doesn't work for me :)
> Feature maps themselves can't have opposites. The features that delegate
Would this help? The model is not that small and i'm not the only one
working with it. So i really would like to avoid this step.
Am 09/29/10 16:44, schrieb Ed Merks:
> Mario,
> Comments below.
> Mario wrote:
>> Hi everybody,
>> upperBound="-1"
>> <eAnnotations
>> </eAnnotations>
>> changeable="false" volatile="true" transient="true" derived="true"
>> containment="true">
>> <eAnnotations
>> </eAnnotations>
>> Greets, Mario
Re: [EMF] FeatureMap with EOpposites [message #629854 is a reply to message #629845] |
Wed, 29 September 2010 18:28 |
Mario,
I only suggest a schema because that's the best way to ensure you have a
consistent set of extended meta data annotations...
Taking a step back and trying to figure out what you're hoping to
accomplish, I'm not at all sure your goal. What exactly is the point of
trying to define both a "node" and a "nodes" references?
Mario wrote:
> Hi Ed,
> work with a reference.
> which says:
> alternatively allow the orders feature to be defined in UML as a
> FeatureMap implementation) [..]"
> delegate
>> Mario,
>> Comments below.
>> Mario wrote:
>>> Hi everybody,
>>> upperBound="-1"
>>> <eAnnotations
>>> </eAnnotations>
>>> containment="true">
>>> <eAnnotations
>>> </eAnnotations>
>>> this:
>>> Greets, Mario
Ed Merks
Current Time: Thu Apr 25 00:17:56 GMT 2024
Powered by FUDForum. Page generated in 0.03002 seconds
