Re: Implement ToBeBuiltComputer [message #629779 is a reply to message #629755] |
Wed, 29 September 2010 14:17 |
Sven Efftinge Messages: 1823 Registered: July 2009 |
Am 9/29/10 3:29 PM, schrieb Roland S.:
> I am using Version 1.0.0.v201006170321.
> The problem is, that we introduced libraries (zip-archives) as discribed
> in a former post. The linking to files inside the libraries works well,
> but the archive files may not reside inside the workspace. So there are
> no changes found during the build, when I remove the library again. The
> links are kept but this behaviour is unintended.
> Roland
Ah, I see. So the JdtToBeBuiltComputer works as expected, but you want
to tell the builder to index additional zip files.
Are you going to host several different Xtext languages in one
workbench? There's a way to reconfigure the shared.ui bundle once, but
this affects all languages, so you need to be very careful and really
shouldn't publish that stuff to users who might use your DSL in a
Eclipse/Xtext workbench with other Xtext languages involved.
See org.eclipse.xtext.ui.shared.overridingGuiceModule which is an
extension point where you can override the default guice module, hence
be able to exchange certain implementations. But you really should
reconsider your requirements and try to stick with the default behavior.
Sven
Need professional support for Xtext or other Eclipse Modeling technologies?
Go to: http://xtext.itemis.com
Twitter : @svenefftinge
Blog : http://blog.efftinge.de
FUDForum. Page generated in 0.02616 seconds
