Re: PlatformGraphicsAlgorithm update and IGraphicsAlgorithmRenderer refresh [message #629053 is a reply to message #629046] |
Sun, 26 September 2010 19:45 |
Romain Raugi Messages: 15 Registered: July 2009 |
In fact there are two things:
1- The refresh following a change in the bounds of GraphicsAlgorithm
figures is not handled in
PictogramElementDelegate.refreshFigureForGraphicsAlgorithm, in fact
there is no issue at this level.
But I don't understand that with standard GraphicsAlgorithms
(RoundedRectangle, Ellipe...) and corresponding GFShapes, the refresh is
perfect, and not with custom IFigures. Mainly when you start moving
several shapes and do undo/redo, although with simple drawings like
rectangles or ellipses. Do you have any idea? Did you notice such issue?
2- More a limitation: the IProperty collection is a way to store
graphical data in the PlatformGraphicsAlgorithm to be used by the
renderer. By this way, there is no need to extend the notational
metamodel for this purpose. But an update in these properties is not
handled and does not trigger any refresh of the renderer. Do you plan to
support this?
Romain
Le 26/09/2010 20:42, Romain Raugi a écrit :
> I've started to use PlatformGraphicsAlgorithms that I render through
> IGraphicsAlgorithmRenderers with Draw2D IFigures. I can't use the
> provided graphics algorithms, I have some specific needs. The rendering
> is fine, but there is an issue with the refresh.
> When the PlatformGraphicsAlgorithm is updated (following a change in its
> bounds or in its IProperties), the corresponding IFigure is not
> invalidated/repainted.
> I think there is an issue in
> PictogramElementDelegate.refreshFigureForGraphicsAlgorithm. The
> PlatformGraphicsAlgorithm case is not handled.
> Best regards,
> Romain
Re: PlatformGraphicsAlgorithm update and IGraphicsAlgorithmRenderer refresh [message #630199 is a reply to message #629053] |
Fri, 01 October 2010 04:27 |
Here are the bug reports, with the tutorial modified to add the usage of
GraphicsAlgorithmRenderers:
1- Refresh issues with IGraphicsAlgorithmRenderer (clearly a bug)
https://bugs.eclipse.org/bugs/show_bug.cgi?id=326730
2- GraphicsAlgorithm properties update and IGraphicsAlgorithmRenderer
repaint (enhancement)
https://bugs.eclipse.org/bugs/show_bug.cgi?id=326733
I've also reported a regression about the management of domain model
updates outside the editor: Exception when undoing a domain model update
done through EMF.Edit
https://bugs.eclipse.org/bugs/show_bug.cgi?id=326731
Romain
> support this?
> Best regards,
> Romain
>> Hi,
>> Best regards,
>> Romain
FUDForum. Page generated in 0.03034 seconds
