"null argument:applicationXMI argument missing" when starting e4 RCP application [message #628879] |
Fri, 24 September 2010 15:02 |
Andre Preussner Messages: 7 Registered: April 2010 |
I try to deploy an e4 RCP application as stand-alone app, but I can't find the root of this error:
!SESSION 2010-09-24 16:35:05.151 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.6.0_06
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=de_DE
Command-line arguments: -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.equinox.app 0 0 2010-09-24 16:35:07.708
!MESSAGE Product com.sap.tm.ui.product could not be found.
!ENTRY org.eclipse.osgi 2 0 2010-09-24 16:35:07.724
!MESSAGE One or more bundles are not resolved because the following root constraints are not resolved:
!SUBENTRY 1 org.eclipse.osgi 2 0 2010-09-24 16:35:07.724
!MESSAGE Bundle initial@reference:file:plugins/com.sap.conn.jco_1.0.0/ was not resolved.
!SUBENTRY 2 com.sap.conn.jco 2 0 2010-09-24 16:35:07.724
!MESSAGE Missing host Bundle-NativeCode_0.0.0.
!ENTRY org.eclipse.osgi 2 0 2010-09-24 16:35:07.726
!MESSAGE The following is a complete list of bundles which are not resolved, see the prior log entry for the root cause if it exists:
!SUBENTRY 1 org.eclipse.osgi 2 0 2010-09-24 16:35:07.726
!MESSAGE Bundle com.sap.conn.jco_1.0.0 [3] was not resolved.
!SUBENTRY 2 com.sap.conn.jco 2 0 2010-09-24 16:35:07.726
!MESSAGE Bundle com.sap.rfc.tm_1.0.0.201009241626 [4] was not resolved.
!SUBENTRY 2 com.sap.rfc.tm 2 0 2010-09-24 16:35:07.726
!MESSAGE Missing required bundle de.vogella.sap.rfc.core_1.0.0.
!MESSAGE Missing required bundle com.sap.conn.jco_1.0.0.
!MESSAGE Bundle com.sap.tm.ui_1.0.0.201009241626 [6] was not resolved.
!SUBENTRY 2 com.sap.tm.ui 2 0 2010-09-24 16:35:07.726
!MESSAGE Missing required bundle com.sap.rfc.tm_1.0.0.
!SUBENTRY 2 com.sap.tm.ui 2 0 2010-09-24 16:35:07.727
!SUBENTRY 1 org.eclipse.osgi 2 0 2010-09-24 16:35:07.727
!MESSAGE Bundle de.vogella.sap.rfc.core_1.0.0 [7] was not resolved.
!SUBENTRY 2 de.vogella.sap.rfc.core 2 0 2010-09-24 16:35:07.727
!ENTRY org.eclipse.osgi 4 0 2010-09-24 16:35:07.731
!MESSAGE Application error
!STACK 1
org.eclipse.core.runtime.AssertionFailedException: null argument:applicationXMI argument missing
at org.eclipse.core.runtime.Assert.isNotNull(Assert.java:85)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application.loadA pplicationModel(E4Application.java:271)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application.creat eE4Workbench(E4Application.java:185)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application.start (E4Application.java:112)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:196)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:369)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 619)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:574)
at org.eclipse.equinox.launcher.Main.run(Main.java:1407)
I already checked that the Application.e4xmi is included in the plugin jar, and it is also mentioned in the plugin.xml. What else could be wrong? Is there something in the deployment process, that I could have made wrong?
Kind Regards,
André
Re: "null argument:applicationXMI argument missing" when starting e4 RCP application [message #628898 is a reply to message #628879] |
Fri, 24 September 2010 16:02 |
Thomas Schindl Messages: 6651 Registered: July 2009 |
I think your main problem is that you have a dependency problem to
(looks like your Bundle-NativeCode has problems and finding dlls probably).
Did you check if the dlls are part of your build.properties?
Tom
Am 24.09.10 17:02, schrieb Andre Preussner:
> Hello,
> !MESSAGE Bundle
> mailto:initial@reference:file:plugins/com.sap.conn.jco_1.0.0/ was not
> resolved.
> !STACK 1
> tarter.java:369)
> tarter.java:179)
> ssorImpl.java:39)
> at java.lang.reflect.Method.invoke(Method.java:597)
> made wrong?
> Kind Regards,
> André
FUDForum. Page generated in 0.02549 seconds
