Home » Archived » Buckminster » Buckminster cvs materializing, uses a proxy, how is this configured?
Re: Buckminster cvs materializing, uses a proxy, how is this configured? [message #629308 is a reply to message #629303] |
Mon, 27 September 2010 18:16 |
Yes, I am also surprised. Afaics I don't use a workspace template (how is this specified in buckminster?).
I launch buckminster like this:
<macrodef name="buckminster">
<attribute name="command" />
<attribute name="workspace" />
<element name="globargs" optional="true" />
<element name="cmdargs" optional="true" />
<sequential>
<eclipse.launch app="buckminster">
<args>
<jvmarg value="-Xmx1024m" />
<jvmarg value="-Dbugfix.288796=true" />
<arg value="-data" />
<arg value="@{workspace}" />
<arg value="--loglevel" />
<arg value="${buckminster.loglevel}" />
<arg value="--displaystacktrace" />
<arg value="@{command}" />
<globargs />
<arg value="-P" />
<arg value="${properties.tmp}" />
<cmdargs />
</args>
</eclipse.launch>
</sequential>
</macrodef>
After creating the workspace directory, one of the first things I do is this:
<echo message="Setting jre to ${env.JAVA_HOME}"/>
<buckminster command="installJRE" workspace="${workspacePath}">
<cmdargs>
<arg value="--location" />
<arg value="${env.JAVA_HOME}" />
</cmdargs>
</buckminster>
so I don't understand either where this proxy thing comes from...
gr. Martin
On 09/27/2010 07:16 PM, Thomas Hallgren wrote:
> On 09/23/2010 11:02 PM, Martin Taal wrote:
>> Hi,
>> When building texo/teneo job on hudson.eclipse.org buckminster tries to
>> connect to the cvs server (dev.eclipse.org) using a proxy server it
>> seems.
>> When I check the .settings/org.eclipse.core.net.prefs in the build
>> workspace (created by buckminster) I can see this in the workspace
>> settings:
>> proxyData/HTTP/hasAuth=false
>> proxyData/HTTP/host=proxy.eclipse.org
>> org.eclipse.core.net.hasMigrated=true
>> eclipse.preferences.version=1
>> proxyData/HTTP/port=9898
>> These settings are in this file:
>> https://hudson.eclipse.org/hudson/job/emft-texo-nightly/ws/b uild/build/workspace/.metadata/.plugins/org.eclipse.core.run time/.settings/org.eclipse.core.net.prefs/*view*/
>> Where do these proxy settings come from?
> I'm puzzled. I haven't seen this before. AFAIK, Buckminster has no code
> that fiddles with proxy settings and I cannot find any preference
> settings for org.eclipse.core.net in any of my workspaces. Are you using
> a workspace template?
> - thomas
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: Buckminster cvs materializing, uses a proxy, how is this configured? [message #629505 is a reply to message #629330] |
Tue, 28 September 2010 13:27 |
Hi Henrik,
This is a build run on hudson.eclipse.org, afaics I am not reusing an earlier workspace.
The strange thing is when I do the build locally it does not contain this setting. The local build is the same as the
hudson build afaics....
Is there something in buckminster which makes it run differently when run on hudson.eclipse.org?
gr. Martin
> Other ways for these preferences to end up in the workspace could be:
> - If reusing a workspace that was used earlier with the IDE
> - Something is installed in headless buckminster that sets or modifies
> the proxy preferences.
> Do you see the preferences with a "vanilla" buckminster and a freshly
> created workspace?
> - henrik
The Netherlands
Re: Buckminster cvs materializing, uses a proxy, how is this configured? [message #629541 is a reply to message #629505] |
Tue, 28 September 2010 15:48 |
If you mean that we have special code inserted to trap the fact that
it's running on specific servers or in a specific environment, the
answer is no.
What I could suspect is that the Eclipse proxy support performs some
kind of discovery on the network and auto-configures the proxy settings
depending on it's environment. Then again, that's just a wild guess.
- thomas
Re: Buckminster cvs materializing, uses a proxy, how is this configured? [message #629542 is a reply to message #629541] |
Tue, 28 September 2010 15:59 |
Hi Thomas,
Yes this auto proxy setting maybe the cause, see an old post from a year back, you answered it :-)
http://dev.eclipse.org/mhonarc/lists/p2-dev/msg01955.html
I will research it further.
gr. Martin
The Netherlands
Re: Buckminster cvs materializing, uses a proxy, how is this configured? [message #630405 is a reply to message #629542] |
Fri, 01 October 2010 22:30 |
This was solved!
To finish this thread. Michael Wenz pointed me to a change made in the cdo build (to solve this issue), a snippet from
his email to me:
But I saw that the CDO build is green again and they still do an Ant call from Hudson that again triggers Buckminster.
Previously that build failed with the same exception as ours did or do.
Not sure what these guys changed, but I saw that they added something in their build.xml that seems to fix this. I found
2 snippets that appear to be in connection with this:
<condition property="no.proxy" value="${env.no_proxy}, dev.eclipse.org" else="dev.eclipse.org">
<isset property="env.no_proxy" />
</condition>
<!-- Launch the eclipse application -->
<java fork="true" jar="${@{app}.launcher}" dir="${@{app}.deploy.dir}" failonerror="true">
<env key="no_proxy" value="${no.proxy}" />
<properties />
<!-- Uncomment to debug <jvmarg value=" -agentlib:jdwp=transport=dt_socket,address=8000,server=y,sus pend=y "/> -->
<args />
</java>
gr. Martin
On 09/28/2010 05:59 PM, Martin Taal wrote:
> Hi Thomas,
> gr. Martin
The Netherlands
Current Time: Fri Apr 19 09:29:06 GMT 2024
Powered by FUDForum. Page generated in 0.02643 seconds
