Home » Archived » BIRT » BIRT/OSGi Classloading screwing up SSL in WebSphere?!
Re: BIRT/OSGi Classloading screwing up SSL in WebSphere?! [message #628695 is a reply to message #628662] |
Thu, 23 September 2010 17:14 |
Can you open a bugzilla entry for this?
Jason
On 9/23/2010 11:15 AM, Robert Aust wrote:
> I've been working on this problems since a couple of days..
> The scenario is this:
> BIRT 2.5.2 integrated in a WebApp i.e. a InitServerlt starting up the
> Engine [referencing the runtime somewhere in the filesystem].
> So BIRT [all necessary classes/libraries] is included with the WEB-APP
> in the ear-File.
> This is then deployed to WebSphere 6.1
> First I head PARENT_LAST - but after I fixed some classpath-issues
> concerning XML und logging etc. PARENT_FIRST [standard] worked also,
> meaning BIRT starts up produces a test-report.
> BUT - in my application I also use a background-thread for some long-ops
> and in this operations HTTPS-access to a WebService fails with
> "MalformedURLException" in "java.net.URL", since it abviously cannot
> find the SSL-Implementation [of WebSphere] anymore and thererfor cannot
> handle "https"..
> I've tried several variations of Thread.setContextClassloader in the
> code, where the background-Thread is started, but no success.
> The same problem appears with the scheduler quartz, although I use a
> config-property to use the TheadContextClassloader.
> Does anyboy has an idea, what happens to the [Context-] Clasloaders when
> BIRT ist started inside a WebSphere WebApp?
> And how I possibly could get SSL to work?
> The SSL-implementation is com.ibm.websphere.ssl.protocol.SSLSocketFactory
> and the CodeSource is a OSGi-Plugin of WebSphere itself :
> ProtectionDomain
> (file:/opt/WebSphere/AppServer-6.1/plugins/com.ibm.ws.securi ty.crypto_6.1.0.jar
> <no signer certificates>)
> null
> <no principals>
> org.eclipse.osgi.framework.internal.core.BundleCombinedPermi ssions @70007000
> Is there a way to use this plugin/library also in the BIRT-OSGi, so that
> it will be availibe to the application AFTER BIRT ist started?
> Thanks a lot!
> Robert
Re: BIRT/OSGi Classloading screwing up SSL in WebSphere?! [message #628782 is a reply to message #628695] |
Fri, 24 September 2010 07:01 |
Robert Aust Messages: 17 Registered: July 2009 |
Hi Jason,
Done : https://bugs.eclipse.org/bugs/show_bug.cgi?id=326118
In the entry, I have also added a link to an IBM APAR, that describes
the same problem inside some tivoli-product using BIRT and also gives
a workaround. I will try that.
Robert-
Am 23.09.2010 19:15, schrieb Jason Weathersby:
> Jason
>> Hi,
>> in the ear-File.
>> handle "https"..
>> ProtectionDomain
>> null
>> <no principals>
>> Thanks a lot!
>> Robert
Re: BIRT/OSGi Classloading screwing up SSL in WebSphere?! [message #628900 is a reply to message #628782] |
Fri, 24 September 2010 16:34 |
Robert,
Thanks. Please post an update when you have one.
Jason
On 9/24/2010 3:01 AM, Robert Aust wrote:
> Hi Jason,
> Best regards,
> Robert-
>> Jason
>>> Hi,
>>> in the ear-File.
>>> handle "https"..
>>> ProtectionDomain
>>> null
>>> <no principals>
>>> Thanks a lot!
>>> Robert
Current Time: Thu Apr 25 15:05:41 GMT 2024
Powered by FUDForum. Page generated in 0.02783 seconds
