Home » Modeling » UML2 » Retrieving applied stereotypes
Retrieving applied stereotypes [message #628598] Wed, 18 August 2010 15:03 Go to next message
Thomas is currently offline ThomasFriend
Hi there!
I'm currently facing problems when trying to read applied stereotypes from a UML model. The model itself is created and exported from 16.5 MagicDraw with the "EMF UML 2.x" export option.
When opening the model back in the UML editor the stereotyped elements are perfectly shown like "<<myStereotype>> <Class> myClass". Therefore I guess the model itself is valid (in the context of applied stereotypes).
I found a bunch of hints and guides on how to do stand alone applications (package registrations, pathmaps, ...) and tried "everything" without success. That's why I'm now here hoping to get some enlightenment. :)
Below you find the major code lines I'm using. Any comments and the slightest hints why any call to ...#getAppliedStereotypes leads to an empty list are very much appreciated!
import ...
public class SimpleTest {
String filename = "models/myModel.uml";
ResourceSet resourceSet = new ResourceSetImpl();
resourceSet.getPackageRegistry().put(EcorePackage.eNS_URI, EcorePackage.eINSTANCE);
resourceSet.getPackageRegistry().put(UMLPackage.eNS_URI, UMLPackage.eINSTANCE);
resourceSet.getPackageRegistry().put(Ecore2XMLPackage.eNS_UR I, Ecore2XMLPackage.eINSTANCE);
resourceSet.getPackageRegistry().put("http://www.eclipse.org/uml2/2.0.0/UML", UMLPackage.eINSTANCE);
resourceSet.getPackageRegistry().put("http://schema.omg.org/spec/UML/2.0", UMLPackage.eINSTANCE);
resourceSet.getPackageRegistry().put("http://schema.omg.org/spec/UML/2.1", UMLPackage.eINSTANCE);
Map<String, Object> extensionToFactoryMap = resourceSet.getResourceFactoryRegistry().getExtensionToFacto ryMap();
extensionToFactoryMap.put(UMLResource.FILE_EXTENSION, UMLResource.Factory.INSTANCE);
extensionToFactoryMap.put("ecore", new EcoreResourceFactoryImpl());
extensionToFactoryMap.put("ecore2xml", new Ecore2XMLFactoryImpl());
extensionToFactoryMap.put(UMLResource.FILE_EXTENSION, XMI2UMLResource.Factory.INSTANCE);
extensionToFactoryMap.put(Resource.Factory.Registry.DEFAULT_ EXTENSION, new XMIResourceFactoryImpl());
Map<URI, URI> uriMap = resourceSet.getURIConverter().getURIMap();
URI uri = URI.createURI(" jar:file:/ABS_PATH_TO_JAR/org.eclipse.uml2.uml.resources_3.1 .0.v201005031530.jar!/ ");
uriMap.put(URI.createURI(UMLResource.LIBRARIES_PATHMAP), uri.appendSegment("libraries").appendSegment(""));
uriMap.put(URI.createURI(UMLResource.METAMODELS_PATHMAP), uri.appendSegment("metamodels").appendSegment(""));
uriMap.put(URI.createURI(UMLResource.PROFILES_PATHMAP), uri.appendSegment("profiles").appendSegment(""));
URI uriPath = URI.createFileURI(filename);
Resource resource = resourceSet.getResource(uriPath, true);
Model myModel = (Model) EcoreUtil.getObjectByType(
resource.getContents(), UMLPackage.eINSTANCE.getModel());
// load the profile (test purpose)
URI profilePath = URI.createFileURI("models/myProfile.profile.uml");
Resource profileResource = resourceSet.getResource(profilePath, true);
Profile umlProfile = (Profile) EcoreUtil.getObjectByType(
profileResource.getContents(), UMLPackage.eINSTANCE.getProfile());
// end loading the profile
System.out.println("Model " + myModel.getName());
Iterator<Element> it = myModel.getOwnedElements().iterator();
while (it.hasNext()) {
Element e = it.next();
if(e instanceof org.eclipse.uml2.uml.Class) {
org.eclipse.uml2.uml.Class umlClass = (org.eclipse.uml2.uml.Class)e;
System.out.print("Class " + umlClass.getName());
// THIS LEADS TO EMPTY LIST
EList stereotypes = umlClass.getAppliedStereotypes();
System.out.println(" (" + stereotypes.size() + " stereotypes)");
for(Object stereotype : stereotypes) {
System.out.println("\tStereotype " + stereotype.toString());
} else if (e instanceof NamedElement)
System.out.println("Other " + e);
Re: Retrieving applied stereotypes [message #628599 is a reply to message #628598] Wed, 18 August 2010 16:12 Go to previous messageGo to next message
--------------070907070000030103040600
One suggestion is to ensure *all *your paths are absolute. I.e., use
new java.io.File("models/myModel.uml").getAbsolutePath() before creating
a file URI from it.
tomtro13@gmail.com wrote:
> Hi there!
> stereotypes).
> import ...
> public static void main(String[] args) {
> URI uri =
> URI profilePath =
> stereotypes)");
Content-Type: text/html; charset=UTF-8
<html>
<head>
<meta content="text/html;charset=UTF-8" http-equiv="Content-Type">
</head>
One suggestion is to ensure <b>all </b>your paths are absolute.
I.e., use new java.io.File("models/myModel.uml").getAbsolutePath()
before creating a file URI from it.<br>
<br>
<br>
<a class="moz-txt-link-abbreviated" href="mailto:tomtro13@gmail.com">tomtro13@gmail.com</a> wrote:
<blockquote cite="mid:i4gsne$acm$1@build.eclipse.org" type="cite">Hi
there!
<br>
<br>
<br>
<br>
are perfectly shown like "&lt;&lt;myStereotype&gt;&gt; &lt;Class&gt;
<br>
<br>
some enlightenment.  :) <br>
<br>
<br>
<br>
import ...
<br>
<br>
<br>
<br>
<br>
<br>
<br>
        <br>
<br>
<br>
<br>
        <br>
resourceSet.getPackageRegistry().put(<a class="moz-txt-link-rfc2396E" href="http://www.eclipse.org/uml2/2.0.0/UML">"http://www.eclipse.org/uml2/2.0.0/UML"</a>,
<br>
resourceSet.getPackageRegistry().put(<a class="moz-txt-link-rfc2396E" href="http://schema.omg.org/spec/UML/2.0">"http://schema.omg.org/spec/UML/2.0"</a>,
<br>
resourceSet.getPackageRegistry().put(<a class="moz-txt-link-rfc2396E" href="http://schema.omg.org/spec/UML/2.1">"http://schema.omg.org/spec/UML/2.1"</a>,
<br>
        <br>
        Map&lt;String, Object&gt; extensionToFactoryMap =
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
        <br>
        Map&lt;URI, URI&gt; uriMap =
<br>
        <br>
        URI uri =
URI.createURI(<a class="moz-txt-link-rfc2396E" href=" jar:file:/ABS_PATH_TO_JAR/org.eclipse.uml2.uml.resources_3.1 .0.v201005031530.jar!/ ">" jar:file:/ABS_PATH_TO_JAR/org.eclipse.uml2.uml.resources_3.1 .0.v201005031530.jar!/ "</a>);
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
        <br>
<br>
        URI profilePath =
<br>
true);
<br>
<br>
<br>
<br>
<br>
<br>
        <br>
        Iterator&lt;Element&gt; it =
<br>
<br>
<br>
<br>
<br>
                <br>
<br>
                <br>
// THIS LEADS TO EMPTY LIST                <br>
<br>
stereotypes)");
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
</blockquote>
</body>
</html>
--------------070907070000030103040600--
Ed Merks
Re: Retrieving applied stereotypes [message #628606 is a reply to message #628598] Thu, 19 August 2010 08:40 Go to previous messageGo to next message
Many thanks, that did the trick for me!
Re: Retrieving applied stereotypes [message #1278387 is a reply to message #628598] Thu, 27 March 2014 09:01 Go to previous messageGo to next message
Denis Nikiforov is currently offline Denis NikiforovFriend
I have a same problem. Here is a test project:
https://github.com/AresEkb/XMILoadTest
with a two model variants: Test.uml and Test.xmi
If you'll use the first one as an input, everithing works as expected and the output is
Loading file:/C:/Work/workspace/XMILoadTest/model/Test.uml
Loading file:/C:/Work/workspace/XMILoadTest/model/TestProfile.profile.uml
Root: class org.eclipse.uml2.uml.internal.impl.ModelImpl
Count: 3
Loading pathmap://UML_PROFILES/Standard.profile.uml
Loading file:/C:/Work/workspace/XMILoadTest/model/Default.profile.uml
Loading file:/C:/Work/workspace/XMILoadTest/model/Deployment.profile.uml
Loading file:/C:/Work/workspace/XMILoadTest/model/ProfileBase.profile.uml
org.eclipse.uml2.uml.internal.impl.ProfileImpl@d3f2d04 (eProxyURI: pathmap://UML_PROFILES/Standard.profile.uml#_0)
org.eclipse.uml2.uml.internal.impl.ProfileImpl@5fc81d2c (name: Default, visibility: <unset>) (URI: null)
org.eclipse.uml2.uml.internal.impl.ProfileImpl@1c7769f7 (name: Deployment, visibility: <unset>) (URI: null)
org.eclipse.uml2.uml.internal.impl.ProfileImpl@3d2cd949 (name: TestProfile, visibility: <unset>) (URI: null)
org.eclipse.uml2.uml.internal.impl.StereotypeImpl@5324c30d (name: ModelStereotype, visibility: <unset>) (isLeaf: false, isAbstract: false, isFinalSpecialization: false) (isActive: false)
But If you'll try to load and XMI-version of the model, stereotypes will not be loaded:
Loading file:/C:/Work/workspace/XMILoadTest/model/Test.xmi
Loading file:/C:/Work/workspace/XMILoadTest/model/TestProfile.profile.xmi
Loading file:/C:/Work/workspace/XMILoadTest/model/ProfileBase.profile.xmi
Loading http://schema.omg.org/spec/UML/2.1.1/StandardProfileL2.xmi
Loading file:/C:/Work/workspace/XMILoadTest/model/Default.profile.xmi
Loading file:/C:/Work/workspace/XMILoadTest/model/Deployment.profile.xmi
Count: 3
org.eclipse.uml2.uml.internal.impl.ProfileImpl@64a21666 (eProxyURI: http://schema.omg.org/spec/UML/2.1.1/StandardProfileL2.xmi#_0)
org.eclipse.uml2.uml.internal.impl.ProfileImpl@38d1099c (name: Default, visibility: <unset>) (URI: null)
org.eclipse.uml2.uml.internal.impl.ProfileImpl@67dbb4ce (name: Deployment, visibility: <unset>) (URI: null)
org.eclipse.uml2.uml.internal.impl.ProfileImpl@6e81f88f (name: TestProfile, visibility: <unset>) (URI: null)
What's wrong with my code?
Re: Retrieving applied stereotypes [message #1278522 is a reply to message #1278387] Thu, 27 March 2014 12:55 Go to previous messageGo to next message
Christian Damus is currently offline Christian DamusFriend
Hi, Denis,
I think there are a good many more registrations needed to make XMI
loading work.
Try inserting the following between lines 22 and 23 in your sample code
(after creating the resource set):
UMLResourcesUtil.init(rs);
You can then also remove the resource factory registrations at lines 26 and 28.
HTH,
Christian
On 2014-03-27 09:01:41 +0000, Denis Nikiforov said:
> Hi
> and the output is
> Count: 3
> will not be loaded:
> Count: 3
Re: Retrieving applied stereotypes [message #1279143 is a reply to message #1278522] Fri, 28 March 2014 09:42 Go to previous messageGo to next message
Hi!
It doesn't help Sad And also after removing the lines
        rs.getResourceFactoryRegistry().getExtensionToFactoryMap().put(
                XMI2UMLResource.FILE_EXTENSION, XMI2UMLResource.Factory.INSTANCE);
the program throws an exception:
Exception in thread "main" org.eclipse.emf.ecore.resource.impl.ResourceSetImpl$1DiagnosticWrappedException: java.net.MalformedURLException: unknown protocol: platform
	at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.handleDemandLoadException(ResourceSetImpl.java:319)
	at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoadHelper(ResourceSetImpl.java:278)
	at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResource(ResourceSetImpl.java:406)
	at org.eclipse.uml2.uml.internal.resource.XMI212UMLResourceFactoryImpl.createResource(XMI212UMLResourceFactoryImpl.java:110)
	at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.createResource(ResourceSetImpl.java:434)
	at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandCreateResource(ResourceSetImpl.java:243)
	at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResource(ResourceSetImpl.java:400)
	at xmiLoadTest.Main.main(Main.java:33)
Caused by: java.net.MalformedURLException: unknown protocol: platform
	at java.net.URL.<init>(Unknown Source)
	at org.eclipse.emf.ecore.resource.impl.URIHandlerImpl.createInputStream(URIHandlerImpl.java:199)
	at org.eclipse.emf.ecore.resource.impl.ExtensibleURIConverterImpl.createInputStream(ExtensibleURIConverterImpl.java:360)
	at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1269)
	at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoad(ResourceSetImpl.java:259)
	at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoadHelper(ResourceSetImpl.java:274)
	... 6 more
Re: Retrieving applied stereotypes [message #1279246 is a reply to message #1279143] Fri, 28 March 2014 12:59 Go to previous messageGo to next message
Hi, Denis,
See some replies in-line, below.
Christian
On 2014-03-28 09:42:58 +0000, Denis Nikiforov said:
> Hi!
> It doesn't help :( And also after removing the lines
Well, these could only be removed when setting up the resource set with
the UMLResourcesUtil.init(...) API, because they are redundant with the
registrations that the latter does.
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 6 more
This should only happen if you didn't do UMLResourcesUtil.init(...), I think.
Sorry, but I don't know enough about the UML2 project's support for
OMG-standard XMI to help any further. Hopefully somebody who does will
chime in.
Re: Retrieving applied stereotypes [message #1281063 is a reply to message #1279246] Mon, 31 March 2014 09:57 Go to previous message
Hi Christian
I've added UMLResourcesUtil.init(...) into my code. But the exception is caused by UML212UMLResourceFactoryImpl.createResource(URI uri). It tries to load "platform:/plugin/..." URI:
		ecore2xmlRegistry
			.put(
				UML212UMLResource.UML_METAMODEL_NS_URI,
				EcoreUtil
					.getObjectByType(
						resourceSet
							.getResource(
								URI
									.createURI("platform:/plugin/org.eclipse.uml2.uml/model/UML21_2_UML.ecore2xml"), //$NON-NLS-1$
								true).getContents(),
						Ecore2XMLPackage.Literals.XML_MAP));
The following lines forces EMF to use a different Factory. And the exceptions disappears:
Why EMF couldn't load platform:/plugin/org.eclipse.uml2.uml/model/UML21_2_UML.ecore2xml?
I added a following line to initialize a EcorePlugin.getPlatformResourceMap():
org.eclipse.ocl.examples.domain.utilities.StandaloneProjectMap.getAdapter(rs);
The map contains the following entries. But the exception still exists.
org.eclipse.xtext : archive:file:/C:/Work/eclipse/plugins/org.eclipse.xtext_2.6.0.v201403111428.jar!/
org.eclipse.ocl.examples.pivot : archive:file:/C:/Work/eclipse/plugins/org.eclipse.ocl.examples.pivot_3.4.0.v20140310-1427.jar!/
org.apache.log4j : archive:file:/C:/Work/eclipse/plugins/org.apache.log4j_1.2.15.v201012070815.jar!/
org.eclipse.emf.ecore.xmi : archive:file:/C:/Work/eclipse/plugins/org.eclipse.emf.ecore.xmi_2.10.0.v20140303-1023.jar!/
org.eclipse.uml2.types : archive:file:/C:/Work/eclipse/plugins/org.eclipse.uml2.types_2.0.0.v20140310-0733.jar!/
org.eclipse.ocl.examples.xtext.essentialocl : archive:file:/C:/Work/eclipse/plugins/org.eclipse.ocl.examples.xtext.essentialocl_3.4.0.v20140208-1141.jar!/
org.apache.commons.cli : archive:file:/C:/Work/eclipse/plugins/org.apache.commons.cli_1.2.0.v201105210650.jar!/
org.eclipse.ocl.examples.xtext.oclinecore : archive:file:/C:/Work/eclipse/plugins/org.eclipse.ocl.examples.xtext.oclinecore_3.4.0.v20140208-1154.jar!/
org.eclipse.ocl.examples.xtext.base : archive:file:/C:/Work/eclipse/plugins/org.eclipse.ocl.examples.xtext.base_3.4.0.v20140303-1414.jar!/
org.eclipse.uml2.common : archive:file:/C:/Work/eclipse/plugins/org.eclipse.uml2.common_2.0.0.v20140310-0733.jar!/
org.eclipse.emf.mapping.ecore2xml : archive:file:/C:/Work/eclipse/plugins/org.eclipse.emf.mapping.ecore2xml_2.7.0.v20140310-0546.jar!/
org.eclipse.ocl : archive:file:/C:/Work/eclipse/plugins/org.eclipse.ocl_3.4.0.v20130903-1625.jar!/
org.eclipse.emf.mwe.utils : archive:file:/C:/Work/eclipse/plugins/org.eclipse.emf.mwe.utils_1.3.2.v201403111231.jar!/
org.eclipse.emf.ecore : archive:file:/C:/Work/eclipse/plugins/org.eclipse.emf.ecore_2.10.0.v20140303-1023.jar!/
org.eclipse.jdt.annotation : archive:file:/C:/Work/eclipse/plugins/org.eclipse.jdt.annotation_1.1.0.v20130513-1648.jar!/
org.eclipse.xtext.util : archive:file:/C:/Work/eclipse/plugins/org.eclipse.xtext.util_2.6.0.v201403111428.jar!/
XMILoadTest : file:/C:/Work/workspace/XMILoadTest/
org.eclipse.emf.edit : archive:file:/C:/Work/eclipse/plugins/org.eclipse.emf.edit_2.10.0.v20140310-0546.jar!/
com.google.guava : archive:file:/C:/Work/eclipse/plugins/com.google.guava_15.0.0.v201402241730.jar!/
org.antlr.runtime : archive:file:/C:/Work/eclipse/plugins/org.antlr.runtime_3.2.0.v201101311130.jar!/
org.eclipse.ocl.examples.xtext.completeocl : archive:file:/C:/Work/eclipse/plugins/org.eclipse.ocl.examples.xtext.completeocl_3.4.0.v20140208-1141.jar!/
org.eclipse.xtext.common.types : archive:file:/C:/Work/eclipse/plugins/org.eclipse.xtext.common.types_2.6.0.v201403111428.jar!/
org.eclipse.emf.ecore.change : archive:file:/C:/Work/eclipse/plugins/org.eclipse.emf.ecore.change_2.9.0.v20140303-1023.jar!/
org.eclipse.ocl.common : archive:file:/C:/Work/eclipse/plugins/org.eclipse.ocl.common_1.1.100.v20140121-1437.jar!/
org.eclipse.emf.mwe2.runtime : archive:file:/C:/Work/eclipse/plugins/org.eclipse.emf.mwe2.runtime_2.6.0.v201403111231.jar!/
org.eclipse.ocl.examples.domain : archive:file:/C:/Work/eclipse/plugins/org.eclipse.ocl.examples.domain_3.4.0.v20140310-1503.jar!/
org.eclipse.emf.mwe.core : archive:file:/C:/Work/eclipse/plugins/org.eclipse.emf.mwe.core_1.3.1.v201403111231.jar!/
org.eclipse.ocl.examples.xtext.oclstdlib : archive:file:/C:/Work/eclipse/plugins/org.eclipse.ocl.examples.xtext.oclstdlib_3.4.0.v20140208-1141.jar!/
org.eclipse.ocl.examples.common : archive:file:/C:/Work/eclipse/plugins/org.eclipse.ocl.examples.common_3.3.0.v20140310-1047.jar!/
org.eclipse.ocl.examples.library : archive:file:/C:/Work/eclipse/plugins/org.eclipse.ocl.examples.library_3.4.0.v20140308-1252.jar!/
org.eclipse.uml2.uml.profile.standard : archive:file:/C:/Work/eclipse/plugins/org.eclipse.uml2.uml.profile.standard_1.0.0.v20140310-0733.jar!/
lpg.runtime.java : archive:file:/C:/Work/eclipse/plugins/lpg.runtime.java_2.0.17.v201004271640.jar!/
org.eclipse.emf.common : archive:file:/C:/Work/eclipse/plugins/org.eclipse.emf.common_2.10.0.v20140303-1023.jar!/
org.eclipse.uml2.uml.resources : archive:file:/C:/Work/eclipse/plugins/org.eclipse.uml2.uml.resources_5.0.0.v20140310-0733.jar!/
org.eclipse.uml2.uml : archive:file:/C:/Work/eclipse/plugins/org.eclipse.uml2.uml_5.0.0.v20140310-0733.jar!/
javax.inject : archive:file:/C:/Work/eclipse/plugins/javax.inject_1.0.0.v20091030.jar!/
com.google.inject : archive:file:/C:/Work/eclipse/plugins/com.google.inject_3.0.0.v201312141243.jar!/
Why EMF couldn't load platform:/plugin/org.eclipse.uml2.uml/model/UML21_2_UML.ecore2xml in standalone application?
An updated test project is here: https://github.com/AresEkb/XMILoadTest
Previous Topic:stereotypes not found on model reload
Next Topic:how to make instance model from ecore file
Current Time: Tue Aug 09 05:54:28 GMT 2022
Powered by FUDForum. Page generated in 0.02942 seconds
