Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Virtual SWT tables behaving very slowly on linux platforms
Virtual SWT tables behaving very slowly on linux platforms [message #628498] |
Thu, 23 September 2010 13:02 |
Quentin D. Messages: 1 Registered: September 2010 |
We have to display a really big number of events in a table. We thus decided to use virtual tables (SWT.VIRTUAL).
On Windows (Win XP), it works very well, even with 10 million items.
But we need to create a portable application. So we tested our virtual table on RedHat Enterprise Linux 3 and 4, and we are facing serious execution time issues.
Our test class is an Eclipse view containing a virtual table.
For 2 million items : the table takes 20 seconds to display, and navigation with the scrollbar is very slow.
For 1 million items : 10 seconds to display, and navigation almost acceptable.
Whereas, on Windows, all works perfectly, even for 10 million items.
How could we explain this difference? Is there a known solution for this issue?
We tested the virtual table on GTK-2-2.2.4-4.0, GTK-2-2.2.4-19, and GTK2-2.4.13-22.
Thanks a lot.
Best regards.
public class ViewPart1 extends ViewPart {
public ViewPart1() {
// TODO Auto-generated constructor stub
public void createPartControl(final Composite parent) {
// Define a vertical layout
FillLayout fillLayout = new FillLayout();
fillLayout.type = SWT.VERTICAL;
parent.setLayout(fillLayout);
// Create and fill an array containing the text of the lines we
// insert in the table
int COUNT = 10000000;
// Create the table and the label
final Table table = new Table(parent, SWT.MULTI | SWT.BORDER | SWT.FULL_SELECTION | SWT.VIRTUAL);
table.setLinesVisible (true);
table.setHeaderVisible (true);
GridData data = new GridData(SWT.FILL, SWT.FILL, true, true);
data.heightHint = 200;
table.setLayoutData(data);
String[] titles = {"C1", "C2", "C3", "C4", "C5", "C6"};
for (int i=0; i<titles.length; i++) {
TableColumn column = new TableColumn (table, SWT.NONE);
column.setText (titles [i]);
column.setWidth(200);
final Label info = new Label(parent,SWT.NONE);
final Button button = new Button(parent, SWT.NONE);
button.setText("table.clearAll();");
// Define a listener to fill the required new lines of the table
table.addListener(SWT.SetData, new Listener() {
int nbLoaded = 0;
public void handleEvent(Event event) {
TableItem item = (TableItem)event.item;
int index = event.index;
// Get the text from the itemStrings[] array
nbLoaded++;
item.setText(0,"item " + index);
item.setText(1,"item " + index);
item.setText(2,"item " + index);
item.setText(3,"item " + index);
item.setText(4,"item " + index);
item.setText(5,"item " + index);
info.setText("Item " + index + " loaded from array \"itemStrings[]\" (total " + nbLoaded + ")");
table.setItemCount(COUNT);
Listener listener = new Listener() {
table.clearAll();
button.addListener(SWT.Selection,listener);
public void setFocus() {
// TODO Auto-generated method stub
Re: Virtual SWT tables behaving very slowly on linux platforms [message #629874 is a reply to message #628789] |
Wed, 29 September 2010 19:48 |
Michal Niewrzal Messages: 50 Registered: July 2009 |
Member |
I have also problem with VIRTUAL viewer. I have created virtual tree with columns. On windows scroll works smooth but on linux and gtk is very slow. To show my problem i have modify Snippet047VirtualLazyTreeViewer snippet. Unmodified example works fine but when I have added columns everything starts to work very slow.
I work on Eclipse 3.6 and Linux Mint Xfce with GTK 2.20.1. I had this problem also on Fedora 12. My machine have Dual-Core 2x2.0 and 3GB DDR3 so this is not hardware problem
I look for solution for some time and I will be grateful for any tips
package pl.wywrzal.trial;
import org.eclipse.jface.viewers.ILazyTreeContentProvider;
import org.eclipse.jface.viewers.LabelProvider;
import org.eclipse.jface.viewers.TreeViewer;
import org.eclipse.jface.viewers.TreeViewerColumn;
import org.eclipse.jface.viewers.Viewer;
import org.eclipse.swt.SWT;
import org.eclipse.swt.layout.FillLayout;
import org.eclipse.swt.widgets.Shell;
* A simple TreeViewer to demonstrate usage of an ILazyContentProvider.
public class Snippet047VirtualLazyTreeViewer {
private class MyContentProvider implements ILazyTreeContentProvider {
private TreeViewer viewer;
private IntermediateNode[] elements;
public MyContentProvider(TreeViewer viewer) {
this.viewer = viewer;
public void dispose() {
public void inputChanged(Viewer viewer, Object oldInput, Object newInput) {
this.elements = (IntermediateNode[]) newInput;
* (non-Javadoc)
* @see
* org.eclipse.jface.viewers.ILazyTreeContentProvider#getParent(java
* .lang.Object)
public Object getParent(Object element) {
if (element instanceof LeafNode)
return ((LeafNode) element).parent;
return elements;
* (non-Javadoc)
* @see
* org.eclipse.jface.viewers.ILazyTreeContentProvider#updateChildCount
* (java.lang.Object, int)
public void updateChildCount(Object element, int currentChildCount) {
int length = 0;
if (element instanceof IntermediateNode) {
IntermediateNode node = (IntermediateNode) element;
length = node.children.length;
if (element == elements)
length = elements.length;
viewer.setChildCount(element, length);
* (non-Javadoc)
* @see
* org.eclipse.jface.viewers.ILazyTreeContentProvider#updateElement(
* java.lang.Object, int)
public void updateElement(Object parent, int index) {
Object element;
if (parent instanceof IntermediateNode)
element = ((IntermediateNode) parent).children[index];
else
element = elements[index];
viewer.replace(parent, index, element);
updateChildCount(element, -1);
public class LeafNode {
public int counter;
public IntermediateNode parent;
public LeafNode(int counter, IntermediateNode parent) {
this.counter = counter;
this.parent = parent;
public String toString() {
return "Leaf " + this.counter;
public class IntermediateNode {
public int counter;
public LeafNode[] children = new LeafNode[0];
public IntermediateNode(int counter) {
return "Node " + this.counter;
public void generateChildren(int i) {
children = new LeafNode[i];
for (int j = 0; j < i; j++) {
children[j] = new LeafNode(j, this);
public Snippet047VirtualLazyTreeViewer(Shell shell) {
final TreeViewer v = new TreeViewer(shell, SWT.VIRTUAL | SWT.BORDER);
v.getTree().setBackgroundMode(SWT.INHERIT_DEFAULT);
v.getTree().setHeaderVisible(true);
v.getTree().setLinesVisible(true);
for (int i = 0; i < 15; i++) {
TreeViewerColumn column = new TreeViewerColumn(v, SWT.NONE);
column.getColumn().setResizable(true);
column.getColumn().setWidth(80);
v.setLabelProvider(new LabelProvider());
v.setContentProvider(new MyContentProvider(v));
v.setUseHashlookup(true);
IntermediateNode[] model = createModel();
v.setInput(model);
v.getTree().setItemCount(model.length);
v.expandAll();
private IntermediateNode[] createModel() {
IntermediateNode[] elements = new IntermediateNode[10];
for (int i = 0; i < 10; i++) {
elements[i] = new IntermediateNode(i);
elements[i].generateChildren(1000);
return elements;
* @param args
Display display = new Display();
Shell shell = new Shell(display);
shell.setLayout(new FillLayout());
new Snippet047VirtualLazyTreeViewer(shell);
shell.open();
while (!shell.isDisposed()) {
if (!display.readAndDispatch())
display.sleep();
display.dispose();
Current Time: Fri Mar 29 09:12:11 GMT 2024
Powered by FUDForum. Page generated in 0.02063 seconds
