Home » Eclipse Projects » Nebula » [Grid] cellSelection and rowSelection
[Grid] cellSelection and rowSelection [message #63172] Tue, 28 April 2009 20:03 Go to next message
Thomas  ichstädt-Engelen is currently offline Thomas ichstädt-EngelenFriend
Member
i'd like to have both:
1. the selected rows should be rendered how it is done when
cellSelectionEnabled is disabled (in my case blue background of the
selected row - macos)
2. the selected cell should be renderd as if cellSelectionEnabled is set
to true.
In other cases i used the FocusCellOwnerDrawHighlighter which couldn't not
be used here, right?
Could you please point me to the right direction?
Thomas E.-E.
Re: [Grid] cellSelection and rowSelection [message #63203 is a reply to message #63172] Wed, 29 April 2009 00:23 Go to previous messageGo to next message
Thomas Schindl is currently offline Thomas SchindlFriend
Thomas Eichstädt-Engelen schrieb:
> to true.
> not be used here, right?
yes this is right - this is special to SWT/JFace and won't (ever) work
in Grid/Nebula.
But I thought our special internal classes ensure that the cell
selection it restored as needed. I'm not 100% sure what you are aiming at.
Tom
Re: [Grid] cellSelection and rowSelection [message #63229 is a reply to message #63203] Wed, 29 April 2009 09:40 Go to previous messageGo to next message
Member
> in Grid/Nebula.
what a pitty ...
i am aiming at giving the user (visual) support which row (and ideally
which column - like crosslines) he is traversing/editing at the moment.
Hence our table is very broad and deep one could loose orientation very
quickly. Does this sound reasonable?
Thomas E.-E.
Re: [Grid] cellSelection and rowSelection [message #63253 is a reply to message #63229] Wed, 29 April 2009 10:20 Go to previous messageGo to next message
So why don't turn on cell-selection in the grid? JFace has to emulate
this concept whereas CellSelection is "natively" implemented in the Grid
simply by calling setCellSelectionEnabled(true) - or do I don't get your
use case?
Tom
>> in Grid/Nebula.
> what a pitty ...
>> at.
> Cheers,
> Thomas E.-E.
Re: [Grid] cellSelection and rowSelection [message #63301 is a reply to message #63253] Wed, 29 April 2009 16:04 Go to previous messageGo to next message
Member
> use case?
that's what i did. But when i switch setCellSelectionEnabled on, the
selected cell is marked as focused, which is fine. But what i miss in that
case is the marked row (blue background). Ideally i'd like to mark the
corresponding column as well (like crosslines).
I'd like to have "the best out of two worlds" ...
Thomas E.-E.
Re: [Grid] cellSelection and rowSelection [message #63328 is a reply to message #63301] Wed, 29 April 2009 16:40 Go to previous messageGo to next message
--------------000305030501060607070704
Content-Type: text/plain; charset=ISO-8859-15
Ok. You can simply solve this writing your own CellRenderer and setting
it on the Grid-Instance. Attached to this mail you find a modified
version of the default cell-renderer which draws the crosslines :-)
Tom
Thomas Eichst
Re: [Grid] cellSelection and rowSelection [message #490196 is a reply to message #63328] Wed, 07 October 2009 18:36 Go to previous messageGo to next message
Rohit  is currently offline Rohit Friend
Hi Tom,
Even i needed the feature where cell renderer draws the crosslines. I could not find the attachment from your last reply. Would you please attach the modified version of the default cell-renderer. thank you
Re: [Grid] cellSelection and rowSelection [message #490209 is a reply to message #490196] Wed, 07 October 2009 20:33 Go to previous messageGo to next message
In my Thunderbird the Java-File is shown attached to the answer.
Tom
Rohit schrieb:
> Hi Tom,
> thank you
Re: [Grid] cellSelection and rowSelection [message #490220 is a reply to message #63172] Wed, 07 October 2009 22:04 Go to previous messageGo to next message
Hi Tom,
Unfortunately the file does not show up in the forum posts. Although it says "This is a multi part message in MIME format " , the attachment is not visible. I tried searching in the forum post using the Safari and Firefox browser but the attachment is not visible.
thanks
Re: [Grid] cellSelection and rowSelection [message #490719 is a reply to message #490209] Fri, 09 October 2009 19:44 Go to previous messageGo to next message
Eugene  is currently offline Eugene Friend
Hi Tom,
I do not see any place to download the file you claim you can see through Thunderbird. If you can, would you mind explaining how to set up Thunderbird to work with this forum to allow us to download the file. Otherwise, please feel free to upload the document somewhere else; it would be greatly appreciated.
Thanks!
this is what we see: http://www.sfplayers.com/screenShot.jpg
Re: [Grid] cellSelection and rowSelection [message #490754 is a reply to message #490719] Sat, 10 October 2009 07:39 Go to previous message
I sent you a mail to turkov@gmail.com
Tom
Eugene schrieb:
> Hi Tom,
> Thanks!
Re: [Grid] cellSelection and rowSelection [message #594620 is a reply to message #63172] Wed, 29 April 2009 00:23 Go to previous message
> to true.
in Grid/Nebula.
Tom
Re: [Grid] cellSelection and rowSelection [message #594630 is a reply to message #63203] Wed, 29 April 2009 09:40 Go to previous message
Member
> in Grid/Nebula.
what a pitty ...
Thomas E.-E.
Re: [Grid] cellSelection and rowSelection [message #594640 is a reply to message #63229] Wed, 29 April 2009 10:20 Go to previous message
use case?
Tom
>> in Grid/Nebula.
> what a pitty ...
>> at.
> Cheers,
> Thomas E.-E.
Re: [Grid] cellSelection and rowSelection [message #594657 is a reply to message #63253] Wed, 29 April 2009 16:04 Go to previous message
Member
> use case?
Thomas E.-E.
Re: [Grid] cellSelection and rowSelection [message #594666 is a reply to message #63301] Wed, 29 April 2009 16:40 Go to previous message
Tom
Thomas Eichst
Re: [Grid] cellSelection and rowSelection [message #598358 is a reply to message #63328] Wed, 07 October 2009 18:36 Go to previous message
Hi Tom,
Re: [Grid] cellSelection and rowSelection [message #598362 is a reply to message #490196] Wed, 07 October 2009 20:33 Go to previous message
Tom
Rohit schrieb:
> Hi Tom,
> thank you
Re: [Grid] cellSelection and rowSelection [message #598367 is a reply to message #63172] Wed, 07 October 2009 22:04 Go to previous message
Hi Tom,
thanks
Re: [Grid] cellSelection and rowSelection [message #598393 is a reply to message #490209] Fri, 09 October 2009 19:44 Go to previous message
Hi Tom,
Thanks!
Re: [Grid] cellSelection and rowSelection [message #598399 is a reply to message #598393] Sat, 10 October 2009 07:39 Go to previous message
Tom
Eugene schrieb:
> Hi Tom,
> Thanks!
Previous Topic:PShelf patch for font color in hovered mode
Next Topic:Nebula grid - get selected values
Current Time: Sat Sep 26 07:48:37 GMT 2020
Powered by FUDForum. Page generated in 0.03343 seconds
