UML generate with CDO support [message #627284] |
Tue, 16 December 2008 11:23 |
Oelerink Messages: 129 Registered: July 2009 |
i want to use the UML Editors with CDO. So i use the migrate function
from the cdo on UML.genmodel and generate the code again. But this leads
into many errors. Some methods are missing and so on. Exist an uml
implementation based on CDO or is the another implementation, which i
can regenerate without errors? I use emf 2.4.0 and CDO 1.0. I get the
same errors when i only regenerate the code without any changes on the
UML.genmodel.
The package i used is in the cvs under
org.eclipse.mdt->org.eclipse.uml2->plugins->org.eclipse.uml2.uml
Thanks in advance
Jörg
FUDForum. Page generated in 0.03338 seconds
