Re: How to publish remote services (r-osgi) automatically / discover peers ? [message #624039 is a reply to message #624038] |
Tue, 09 September 2008 19:55 |
Florian Georg Messages: 34 Registered: July 2009 |
Member |
Hi Scott, thanks for the answers, pls see below
Scott Lewis wrote:
> Hi Florian,
> We have a remote service property AUTOREGISTER_REMOTE_PROXY [1] that can
> be used to automatically register proxies in the local service registry.
> This property is specified when the IRemoteService is registered. Here
> [2] is some test/example code that does this.
Basically, I would like it the other way around .... services are
already locally instantiated/registered with declarative services
- I want to publish them additionally as remote services.
Currently I use a ServiceTracker to track my services and
register/unregister them on the RemoteServiceContainerAdapter... I
suppose there's no other "ECF standard" way of doing so, or is there?
> In our own tests (i.e. with the generic provider and xmpp provider) this
> allows either ServiceReference-based or ServiceTracker-based lookup of
> the proxy to succeed...e.g. test code in [3]. Frankly I haven't tried
> declarative services-based lookup, but it seems to me it should work as
> well.
> Please let me know if you would like more/other information...or
> encounter difficulties.
BTW: why is the JSLP discovery provider not started automatically like
the jmdns one? I managed to switch to the JSLP version but had big
performance issues during connect and service registration (timeouts),
so I went back to jmdns...
kind regards,
Florian
> Scott
> [1]
> http://www.eclipse.org/ecf/org.eclipse.ecf.docs/api/org/ecli pse/ecf/remoteservice/Constants.html
> [2]
> http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.ecf/tes ts/org.eclipse.ecf.tests.remoteservice/src/org/eclipse/ecf/t ests/remoteservice/generic/TransparentProxyTest.java?root=Te chnology_Project&view=markup
> [3]
> http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.ecf/tes ts/org.eclipse.ecf.tests.remoteservice/src/org/eclipse/ecf/t ests/remoteservice/generic/ServiceTrackerTest.java?root=Tech nology_Project&view=markup
> Florian Georg wrote:
>> Hi,
>> I have some "local" OSGi/Equinox application, making heavy use of
>> declarative services.
>> I now want ECF to "publish" (and consume) my services (possibly
>> filtered) automatically and transparent as R-OSGI remote services.
>> What I currently do is:
>> 1. Track my services
>> 2. Use the ServiceReference to get the actual service
>> 3. Iterate over the serviceObject.getClass().getInterfaces() and
>> register the object for each of the implemented interfaces on the
>> Is there a another/cleaner/better/smarter way of doing this?
>> Ideally, I would like all services to be published for remote access
>> based on some metadata ("publish.remote=true") automatically.
>> Service Trackers / Decarative Services should find both local services
>> and proxies to remote services transparently - and be able to decide
>> which one to use.
>> How can I then discover the available remote r-OSGI server instances
>> in my network and connect to them? Not sure I understand the discovery
>> mechanism completly....
>> thanks for any pointers / snippets.
>> cheers,
>> Florian
Re: How to publish remote services (r-osgi) automatically / discover peers ? [message #624040 is a reply to message #624039] |
Wed, 10 September 2008 05:05 |
Scott Lewis Messages: 1038 Registered: July 2009 |
Hi Florian,
> Scott Lewis wrote:
>> Hi Florian,
>> can be used to automatically register proxies in the local service
>> registry. This property is specified when the IRemoteService is
>> registered. Here [2] is some test/example code that does this.
Hmmm...no that's the 'standard' way...i.e. register them on the
It might make a nice utility class to use your ServiceTrackerCustomizer
so that it detected local registrations for a given interface (which is
I assume what you do), and then made them remote by registering them
with RemoteServiceContainerAdapter.registerRemoteService. Would you
consider contributing your code for doing this?
>> this allows either ServiceReference-based or ServiceTracker-based
>> lookup of the proxy to succeed...e.g. test code in [3]. Frankly I
>> haven't tried declarative services-based lookup, but it seems to me it
>> should work as well.
I'll have to refer you to Markus and Jan for more details about JSLP.
We're in the middle of some bug fixes there (e.g.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=238710). So I'll have to
defer to them about the startup sequence for jslp.
Scott
Re: How to publish remote services (r-osgi) automatically / discover peers ? [message #624062 is a reply to message #624040] |
Thu, 11 September 2008 14:52 |
Florian Georg Messages: 27 Registered: July 2009 |
Hi Scott,
thanks for your support... sure I'm willing to contribute - I will open
a bugzilla entry and attach my utility class if that's fine with you.
(as soon as I have done a bit refactoring/polish - I'm still a bit new
to ECF...)
regards,
Florian
Scott Lewis schrieb:
> Hi Florian,
>> Scott Lewis wrote:
>>> Hi Florian,
>>> it should work as well.
> Scott
FUDForum. Page generated in 0.04824 seconds
