Home » Eclipse Projects » Platform - User Assistance (UA) » Running Minimal Standalone
Running Minimal Standalone [message #623984] Thu, 25 March 2010 19:31 Go to next message
I followed the instructions for running a minimal infocenter standalone.
Platform Plug-in Developer Guide > Programmer's Guide > User assistance support > Help > Configuration/setup > [Optional] Installing a minimal stand-alone help system
When I try to start the infocenter using the minimal plugins directory, I get the following exception:
java.lang.Exception: Plugins directory /home/ole/Documents/help/eclipse/plugins does not contain a valid startup jar. Pass a correct -eclipsehome option
at org.eclipse.help.internal.standalone.Eclipse.getStartupJar(E clipse.java:182)
at org.eclipse.help.internal.standalone.Eclipse.prepareJavaComm and(Eclipse.java:76)
at org.eclipse.help.internal.standalone.Eclipse.prepareCommand( Eclipse.java:48)
at org.eclipse.help.internal.standalone.Eclipse.run(Eclipse.jav a:87)
Is it possible to point the infocenter at a plugins directory that is different from the plugins directory contained in the eclipse folder? Something like -helpPluginDirectory /home/ole/help/onlyHelpPlugins
TIA,
- Ole
Re: Running Minimal Standalone [message #623997 is a reply to message #623984] Mon, 29 March 2010 15:27 Go to previous messageGo to next message
Standalone help uses the eclipse launcher and needs to know where to find that. You can specify the location using the eclipsehome parameter. Below is the documentation for this parameter
-eclipsehome eclipseInstallPath - specifies Eclipse installation directory. This directory is a parent to "plugins" directory and eclipse executable. The option must be provided, when current directory from which infocenter is launched, is not the same as Eclipse installation directory.
Re: Running Minimal Standalone [message #624139 is a reply to message #623984] Mon, 24 May 2010 06:49 Go to previous messageGo to next message
Hi, this is slightly related.
I need to run a minimal standalone without the need for start and stop scripts. In other words, I want users to be able to click the cross in the top-right of the browser and for it to close cleanly, including all processes, as if the stop script had been invoked. Does anyone have a suggestion for how to achieve this?
Richard
Re: Running Minimal Standalone [message #624141 is a reply to message #624139] Mon, 24 May 2010 10:19 Go to previous message
The help system is packaged as a WAR file now:
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/ua_help_war.htm
So you could deploy as described, and then just add the capabilities for starting and stopping. For an example see the Tomcat Manager Web App. It can start and stop deployed web apps per the manager page by clicking on start/stop links.
HTH,
- Ole
Previous Topic:Error on a Java class
Next Topic:Is the infocenter supported on Firefox 3.5?
Current Time: Tue Jun 17 12:08:46 EDT 2025
Powered by FUDForum. Page generated in 0.04201 seconds
