Home » Eclipse Projects » Platform - User Assistance (UA) » Discovering cheatsheet command serialization parameters
Discovering cheatsheet command serialization parameters [message #623819] Wed, 23 December 2009 18:21 Go to next message
A really basic question here, but I can't figure out how or even if I can specify additional parameters for a given particular command or how even to inspect the command underlying it. Or is it always the case that a command only takes the parameters that show up in the cheat sheet browse dialog?
For example, I'd think that org.eclipse.team.cvs.ui.addLocation would take a parameter to specify the location, but it doesn't, and I'd like to see how it's implemented.
As a related question (and another way to solve the same issue) I couldn't find a command to enter arbitrary text into the focussed widget. Is there such a thing?
thanks again,
Miles
Re: Discovering cheatsheet command serialization parameters [message #623820 is a reply to message #623819] Thu, 24 December 2009 13:38 Go to previous messageGo to next message
The cheat sheet editor can handle the command serialization for you.
If you are using the Eclipse SDK File/New/Other/User Assistance/ Cheat Sheet will take you into the editor or you can just open a cheat sheet by double clicking on it.
Then select an item and click the Browse button in the "Command" section in the bottom right of the editor.
Re: Discovering cheatsheet command serialization parameters [message #623821 is a reply to message #623820] Thu, 24 December 2009 15:15 Go to previous messageGo to next message
thanks, Chris.
Yep, I was just wondering if there is a path to getting documentation about what the parameters are for a particular command, where it is implemented and so on similar to the extension points references. I guess I was remembering wrong but I thought that some of these commands could take additional parameters in some cases.
Any ideas on how to enter text for help content using the command framework?
Re: Discovering cheatsheet command serialization parameters [message #623827 is a reply to message #623821] Mon, 28 December 2009 08:35 Go to previous message
Miles Parker wrote on Thu, 24 December 2009 15:15
The only way I know how to create help content which uses commands is to cut and paste an existing command link and change the parameters.
Previous Topic:Referencing Cheat Sheets from Eclipse Docs
Next Topic:Standalone help - how to find the .toc files
Current Time: Sun Jul 13 08:06:50 EDT 2025
Powered by FUDForum. Page generated in 0.05815 seconds
