Please confirm allowable link_to path structures using PLUGINS_ROOT [message #623356] |
Tue, 26 May 2009 15:37 |
Lee Anne Kowalski Messages: 54 Registered: July 2009 |
Member |
Would someone on the Eclipse UA team please confirm which of the
following are supposed to work when specified in the link_to attribute?
And which one you would consider is a "best practice"?
Given a doc plug-in with:
pluginID = edition1_1
toc file = edition1_1.xml
anchorID in edition1_1.xml = comps
Trying to anchor into that anchorID using link_to, I see the following
behaviors:
link_to="/../edition1_1/edition1_1.xml#comps Works in Eclipse 3.4.1
link_to="/edition1_1/edition1_1.xml#comps Works
link_to="../edition1_1/edition1_1.xml#comps Works (this is also
in the help doc example in ua_help_content_nested.htm topic)
link_to="PLUGINS_ROOT/edition1_1/edition1_1.xml#comps Works
link_to="/PLUGINS_ROOT/edition1_1/edition1_1.xml#comps Does Not work
Now, the help topic on Content Extensions
( http://help.eclipse.org/ganymede/index.jsp?topic=/org.eclips e.platform.doc.isv/guide/ua_dynamic_extensions.htm)
says that the format of the 'path" attribute is:
/pluginID/path/file.xml#elementID
So, is it a bug that link_to="/PLUGINS_ROOT/<pluginID>/<tocfile>#anchorID"
does not work?
Or is PLUGINS_ROOT not useful for contributing into an anchor?
Is the best practice to use the path attribute format? For example:
link_to="/pluginID/path/file.xml#anchorID"
Thanks in advance!
--Lee Anne
FUDForum. Page generated in 0.02860 seconds
