Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » teneo - two different hibernate databases in one ResourceSet
Re: teneo - two different hibernate databases in one ResourceSet [message #62779 is a reply to message #62757] |
Sun, 26 November 2006 22:17 |
Hi Andre,
To accomplish this you can initialize two different HbDataStores and use their names in the uri (as
value of the dsname parameter).
gr. Martin
Andre Pareis wrote:
> Hi (Martin),
> I would like to create a ResourceSet in my editor having two connections
> to two different datasources. Basically I have two databases, one for
> static low volume and another one for dynamic, high volume data. The
> objects in the static resource should do queries in the other resource
> and create temporary associations (transient).
> As far as I understand, it should be easy to use two different
> datasources using a dsName=... in the resource URL, but I wonder how do
> I tell teneo or the hibernate layer which connection URLs to use in each
> of the different datasources? How is such a scenario initialized? Any
> quick suggestions?
> Regards
> Andre
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: teneo - two different hibernate databases in one ResourceSet [message #62812 is a reply to message #62779] |
Mon, 27 November 2006 01:13 |
Andre Pareis Messages: 113 Registered: July 2009 |
Hi Martin,
that's the part which is more or less clear to me.
However, the HbDataStore initializes its hibernate session factory using a
hibernate.properties file found in the classpath. There can be only one
hibernate.properties, and it does also tell the SF exactly one URL for
connecting to a DB, but I need two different URLs.
I know that there is the option to intercept the creation of HbDataStoreS using
a factory, but what to set there? Is the hibernate.properties loaded by
hibernate or by teneo? How can I pass in a different JDBC URL for each HbDataStore?
Andre
Martin Taal wrote:
> Hi Andre,
> their names in the uri (as value of the dsname parameter).
> gr. Martin
> Andre Pareis wrote:
>> Hi (Martin),
>> connections to two different datasources. Basically I have two
>> databases, one for static low volume and another one for dynamic, high
>> volume data. The objects in the static resource should do queries in
>> the other resource and create temporary associations (transient).
>> do I tell teneo or the hibernate layer which connection URLs to use in
>> each of the different datasources? How is such a scenario initialized?
>> Any quick suggestions?
>> Regards
>> Andre
Re: teneo - two different hibernate databases in one ResourceSet [message #62828 is a reply to message #62812] |
Mon, 27 November 2006 04:32 |
Hi Andre,
The hibernate.properties file is read by Hibernate. For your case the easiest would be to set the
properties directly in the hbDataStore by calling setHibernateProperties(Properties hibernateProperties)
(and remove the hibernate.properties file in the root of the classpath).
then you can decide yourselve where to read the (jdbc) properties from and have different properties
for different datastores.
gr. Martin
Andre Pareis wrote:
> Hi Martin,
> a hibernate.properties file found in the classpath. There can be only
> one hibernate.properties, and it does also tell the SF exactly one URL
> for connecting to a DB, but I need two different URLs.
> HbDataStoreS using a factory, but what to set there? Is the
> hibernate.properties loaded by hibernate or by teneo? How can I pass in
> Thanks
> Andre
> Martin Taal wrote:
>> Hi Andre,
>> use their names in the uri (as value of the dsname parameter).
>> gr. Martin
>> Andre Pareis wrote:
>>> Hi (Martin),
>>> high volume data. The objects in the static resource should do
>>> queries in the other resource and create temporary associations
>>> (transient).
>>> in each of the different datasources? How is such a scenario
>>> initialized? Any quick suggestions?
>>> Regards
>>> Andre
The Netherlands
Re: teneo - two different hibernate databases in one ResourceSet [message #62884 is a reply to message #62828] |
Tue, 28 November 2006 19:22 |
Hi Martin,
cool, that sounds doable ;)
Andre
Martin Taal wrote:
> Hi Andre,
> easiest would be to set the properties directly in the hbDataStore by
> and have different properties for different datastores.
> gr. Martin
> Andre Pareis wrote:
>> Hi Martin,
>> using a hibernate.properties file found in the classpath. There can be
>> only one hibernate.properties, and it does also tell the SF exactly
>> one URL for connecting to a DB, but I need two different URLs.
>> Thanks
>> Andre
>> Martin Taal wrote:
>>> Hi Andre,
>>> gr. Martin
>>> Andre Pareis wrote:
>>>> Hi (Martin),
>>>> (transient).
>>>> Regards
>>>> Andre
Re: teneo - two different hibernate databases in one ResourceSet [message #596173 is a reply to message #62757] |
Hi Andre,
gr. Martin
Andre Pareis wrote:
> Hi (Martin),
> quick suggestions?
> Regards
> Andre
The Netherlands
Re: teneo - two different hibernate databases in one ResourceSet [message #596198 is a reply to message #62779] |
Hi Martin,
Andre
Martin Taal wrote:
> Hi Andre,
> gr. Martin
> Andre Pareis wrote:
>> Hi (Martin),
>> Regards
>> Andre
Re: teneo - two different hibernate databases in one ResourceSet [message #596203 is a reply to message #62812] |
Hi Andre,
gr. Martin
Andre Pareis wrote:
> Hi Martin,
> Thanks
> Andre
> Martin Taal wrote:
>> Hi Andre,
>> gr. Martin
>> Andre Pareis wrote:
>>> Hi (Martin),
>>> (transient).
>>> Regards
>>> Andre
The Netherlands
Re: teneo - two different hibernate databases in one ResourceSet [message #596271 is a reply to message #62828] |
Hi Martin,
Andre
Martin Taal wrote:
> Hi Andre,
> gr. Martin
> Andre Pareis wrote:
>> Hi Martin,
>> Thanks
>> Andre
>> Martin Taal wrote:
>>> Hi Andre,
>>> gr. Martin
>>> Andre Pareis wrote:
>>>> Hi (Martin),
>>>> (transient).
>>>> Regards
>>>> Andre
Current Time: Tue Apr 23 13:42:49 GMT 2024
Powered by FUDForum. Page generated in 0.03260 seconds
