Home » Modeling » UML2 » EMF.edit commands
EMF.edit commands [message #622843] Fri, 06 July 2007 02:48
Bogdan Pistol is currently offline Bogdan PistolFriend
I have a few things not very clear about the edit commands.
I'm using an AdapterFactoryEditingDomain with commands in a
BasicCommandStack. I tested successfully the ChangeCommand (it modifies the
model and undo/redo works).
Is there a reason I should use SetCommand, or AddCommand or other commands?
I could make the same "set" and "add" with model changes inside a ChangeCommand.
What is the difference between the two approaches?
Bogdan Pistol,
Previous Topic:EMF.edit commands usage
Next Topic:Problem with navigable owned end
Current Time: Fri Jun 05 20:00:57 GMT 2020
Powered by FUDForum. Page generated in 0.01885 seconds
