Home » Archived » Eclipse Communications Framework (ECF) » Skype connection wizard hangs
Skype connection wizard hangs [message #622637] |
Tue, 18 March 2008 23:29 |
Originally posted by: dickyjohan.gmail.com
Got another issue. I tried to open the Skype Connection Wizard on the
latest build, and it just hangs the whole Eclipse. I have to "end task"
to kill off the eclipse.
It does not seem to take up much CPU though, but it just hangs the whole
workspace. Have anyone seen this issue?
Here is my configuration:
*** Date: Tuesday, March 18, 2008 4:27:26 PM PT
*** Platform Details:
*** System properties:
awt.toolkit=sun.awt.windows.WToolkit
eclipse.buildId=M20080221-1800
eclipse.commands=-os
win32
-ws
win32
-arch
x86
-showsplash
C:\eclipse33\\plugins\org.eclipse.platform_3.3.3.r33x_r20080 129\splash.bmp
-launcher
C:\eclipse33\eclipse.exe
-name
Eclipse
--launcher.library
C:\eclipse33\plugins\org.eclipse.equinox.launcher.win32.win3 2.x86_1.0.3.R33x_v20080118\eclipse_1023.dll
-startup
C:\eclipse33\plugins\org.eclipse.equinox.launcher_1.0.1.R33x _v20080118.jar
-vm
C:\Program Files\Java\jre1.5.0_14\bin\client\jvm.dll
eclipse.ee.install.verify=false
eclipse.product=org.eclipse.sdk.ide
eclipse.startTime=1205882373921
eclipse.vm=C:\Program Files\Java\jre1.5.0_14\bin\client\jvm.dll
eclipse.vmargs=-Xms40m
-Xmx256m
-XX:MaxPermSize=256m
-Djava.class.path=C:\eclipse33\plugins\org.eclipse.equinox.l auncher_1.0.1.R33x_v20080118.jar
eof=eof
file.encoding=Cp1252
file.encoding.pkg=sun.io
file.separator=\
java.awt.graphicsenv=sun.awt.Win32GraphicsEnvironment
java.awt.printerjob=sun.awt.windows.WPrinterJob
java.class.path=C:\eclipse33\plugins\org.eclipse.equinox.lau ncher_1.0.1.R33x_v20080118.jar
java.class.version=49.0
java.endorsed.dirs=C:\Program Files\Java\jre1.5.0_14\lib\endorsed
java.ext.dirs=C:\Program Files\Java\jre1.5.0_14\lib\ext
java.home=C:\Program Files\Java\jre1.5.0_14
java.io.tmpdir=C:\DOCUME~1\dickyj\LOCALS~1\Temp\
java.library.path=C:\eclipse33;.;C:\WINDOWS\system32;C:\WIND OWS;C:\Program
Files\PC Connectivity
Solution\;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32 \Wbem;C:\Program
Files\NTRU Cryptosystems\NTRU TCG Software Stack\bin\;C:\Program
Files\Wave Systems Corp\Gemalto\Access Client\v5\;C:\Program
Files\Gemplus\GemSafe Libraries\BIN;C:\Program Files\Common Files\Roxio
Shared\DLLShared\;C:\Program Files\QuickTime\QTSystem\
java.runtime.name=Java(TM) 2 Runtime Environment, Standard Edition
java.runtime.version=1.5.0_14-b03
java.specification.name=Java Platform API Specification
java.specification.vendor=Sun Microsystems Inc.
java.specification.version=1.5
java.vendor.url=http://java.sun.com/
java.vendor.url.bug=http://java.sun.com/cgi-bin/bugreport.cgi
java.version=1.5.0_14
java.vm.info=mixed mode, sharing
java.vm.name=Java HotSpot(TM) Client VM
java.vm.specification.name=Java Virtual Machine Specification
java.vm.specification.vendor=Sun Microsystems Inc.
java.vm.specification.version=1.0
java.vm.vendor=Sun Microsystems Inc.
java.vm.version=1.5.0_14-b03
line.separator=
org.eclipse.equinox.launcher.splash.location=C:\eclipse33\\p lugins\org.eclipse.platform_3.3.3.r33x_r20080129\splash.bmp
org.eclipse.update.resolution_url=
org.osgi.framework.executionenvironment=OSGi/Minimum-1.0,OSG i/Minimum-1.1,JRE-1.1,J2SE-1.2,J2SE-1.3,J2SE-1.4,J2SE-1.5
org.osgi.framework.language=en
org.osgi.framework.os.name=WindowsXP
org.osgi.framework.os.version=5.1
org.osgi.framework.processor=x86
org.osgi.framework.system.packages=javax.accessibility,javax .activity,javax.crypto,javax.crypto.interfaces,javax.crypto. spec,javax.imageio,javax.imageio.event,javax.imageio.metadat a,javax.imageio.plugins.bmp,javax.imageio.plugins.jpeg,javax .imageio.spi,javax.imageio.stream,javax.management,javax.man agement.loading,javax.management.modelmbean,javax.management .monitor,javax.management.openmbean,javax.management.relatio n,javax.management.remote,javax.management.remote.rmi,javax. management.timer,javax.naming,javax.naming.directory,javax.n aming.event,javax.naming.ldap,javax.naming.spi,javax.net,jav ax.net.ssl,javax.print,javax.print.attribute,javax.print.att ribute.standard,javax.print.event,javax.rmi,javax.rmi.CORBA, javax.rmi.ssl,javax.security.auth,javax.security.auth.callba ck,javax.security.auth.kerberos,javax.security.auth.login,ja vax.security.auth.spi,javax.security.auth.x500,javax.securit y.cert,javax.security.sasl,javax.sound.midi,javax.sound.midi .spi,javax.sound.sampled,java
x.sound.sampled.spi,javax.sql,javax.sql.rowset,javax.sql.row set.serial,javax.sql.rowset.spi,javax.swing,javax.swing.bord er,javax.swing.colorchooser,javax.swing.event,javax.swing.fi lechooser,javax.swing.plaf,javax.swing.plaf.basic,javax.swin g.plaf.metal,javax.swing.plaf.multi,javax.swing.plaf.synth,j avax.swing.table,javax.swing.text,javax.swing.text.html,java x.swing.text.html.parser,javax.swing.text.rtf,javax.swing.tr ee,javax.swing.undo,javax.transaction,javax.transaction.xa,j avax.xml,javax.xml.datatype,javax.xml.namespace,javax.xml.pa rsers,javax.xml.transform,javax.xml.transform.dom,javax.xml. transform.sax,javax.xml.transform.stream,javax.xml.validatio n,javax.xml.xpath,org.ietf.jgss,org.omg.CORBA,org.omg.CORBA_ 2_3,org.omg.CORBA_2_3.portable,org.omg.CORBA.DynAnyPackage,o rg.omg.CORBA.ORBPackage,org.omg.CORBA.portable,org.omg.CORBA .TypeCodePackage,org.omg.CosNaming,org.omg.CosNaming.NamingC ontextExtPackage,org.omg.CosNaming.NamingContextPackage,org. omg.Dynamic,org.omg.DynamicAny
,org.omg.DynamicAny.DynAnyFactoryPackage,org.omg.DynamicAny. DynAnyPackage,org.omg.IOP,org.omg.IOP.CodecFactoryPackage,or g.omg.IOP.CodecPackage,org.omg.Messaging,org.omg.PortableInt erceptor,org.omg.PortableInterceptor.ORBInitInfoPackage,org. omg.PortableServer,org.omg.PortableServer.CurrentPackage,org .omg.PortableServer.POAManagerPackage,org.omg.PortableServer .POAPackage,org.omg.PortableServer.portable,org.omg.Portable Server.ServantLocatorPackage,org.omg.SendingContext,org.omg. stub.java.rmi,org.w3c.dom,org.w3c.dom.bootstrap,org.w3c.dom. css,org.w3c.dom.events,org.w3c.dom.html,org.w3c.dom.ls,org.w 3c.dom.ranges,org.w3c.dom.stylesheets,org.w3c.dom.traversal, org.w3c.dom.views
,org.xml.sax,org.xml.sax.ext,org.xml.sax.helpers
org.osgi.framework.vendor=Eclipse
org.osgi.framework.version=1.4.0
org.osgi.supports.framework.extension=true
org.osgi.supports.framework.fragment=true
org.osgi.supports.framework.requirebundle=true
os.arch=x86
os.name=Windows XP
os.version=5.1
osgi.arch=x86
osgi.bundles=org.eclipse.equinox.common@2:start,
org.eclipse.update.configurator@3:start, org.eclipse.core.runtime@start
osgi.bundlestore=C:\eclipse33\configuration\org.eclipse.osgi \bundles
osgi.compatibility.bootdelegation=true
osgi.configuration.area=file:/C:/eclipse33/configuration/
osgi.framework=file:/c:/eclipse33/plugins/org.eclipse.osgi_3 .3.2.R33x_v20080105.jar
osgi.framework.beginningstartlevel=1
osgi.framework.shape=jar
osgi.framework.version=3.3.2.R33x_v20080105
osgi.install.area=file:/C:/eclipse33/
osgi.instance.area=file:/C:/eclipse33/workspace/
osgi.instance.area.default=file:/C:/Documents and Settings/dickyj/workspace/
osgi.logfile=C:\eclipse33\workspace\.metadata\.log
osgi.manifest.cache=C:\eclipse33\configuration\org.eclipse.o sgi\manifests
osgi.nl=en_US
osgi.os=win32
osgi.splashLocation=C:\eclipse33\\plugins\org.eclipse.platfo rm_3.3.3.r33x_r20080129\splash.bmp
osgi.splashPath=platform:/base/plugins/org.eclipse.platform
osgi.syspath=c:\eclipse33\plugins
osgi.ws=win32
path.separator=;
sun.arch.data.model=32
sun.boot.class.path=C:\Program
Files\Java\jre1.5.0_14\lib\rt.jar;C:\Program
Files\Java\jre1.5.0_14\lib\i18n.jar;C:\Program
Files\Java\jre1.5.0_14\lib\sunrsasign.jar;C:\Program
Files\Java\jre1.5.0_14\lib\jsse.jar;C:\Program
Files\Java\jre1.5.0_14\lib\jce.jar;C:\Program
Files\Java\jre1.5.0_14\lib\charsets.jar;C:\Program
Files\Java\jre1.5.0_14\classes
sun.boot.library.path=C:\Program Files\Java\jre1.5.0_14\bin
sun.cpu.endian=little
sun.cpu.isalist=pentium_pro+mmx pentium_pro pentium+mmx pentium i486
i386 i86
sun.desktop=windows
sun.io.unicode.encoding=UnicodeLittle
sun.jnu.encoding=Cp1252
sun.management.compiler=HotSpot Client Compiler
sun.os.patch.level=Service Pack 2
user.country=US
user.dir=C:\eclipse33
user.home=C:\Documents and Settings\dickyj
user.language=en
user.name=dickyj
user.timezone=America/Los_Angeles
user.variant=
*** Features:
org.eclipse.cvs (1.0.2.r33x_r20080129-7C79_B_GLJwq3I9ZCD8L_) "Eclipse
CVS Client"
org.eclipse.cvs.source (1.0.2.r33x_r20080129-7C79_B_GLJwq3I9ZCD8L_)
"Eclipse CVS Client SDK"
org.eclipse.ecf.core (2.0.0.v20080315-2247) "Eclipse Communication
Framework (ECF)"
org.eclipse.ecf.examples (2.0.0.v20080315-2247) "ECF Collaboration Examples"
org.eclipse.jdt (3.3.2.r33x_r20080129-7o7jE7_EDhYDiyVEnjb1pFd7ZGD7)
"Eclipse Java Development Tools"
org.eclipse.jdt.source
(3.3.2.r33x_r20080129-7o7jE7_EDhYDiyVEnjb1pFd7ZGD7) "Eclipse Java
Development Tools SDK"
org.eclipse.pde (3.3.3.r33x_r20080129-7N7M5DQVIA_6oJsEFkEL) "Eclipse
Plug-in Development Environment"
org.eclipse.pde.source (3.3.3.r33x_r20080129-7N7M5DQVIA_6oJsEFkEL)
"Eclipse Plug-in Development Environment Developer Resources"
org.eclipse.platform (3.3.3.r33x_r20080129-_19UEl7Ezk_gXF1kouft)
"Eclipse Platform"
org.eclipse.platform.source (3.3.3.r33x_r20080129-_19UEl7Ezk_gXF1kouft)
"Eclipse Platform Plug-in Developer Resources"
org.eclipse.rcp (3.3.3.r33x_r20080129-8y8eE9UEUWI6qujeED0xT7bc) "Eclipse
RCP"
org.eclipse.rcp.source (3.3.3.r33x_r20080129-8y8eE9UEUWI6qujeED0xT7bc)
"Eclipse RCP Plug-in Developer Resources"
org.eclipse.sdk (3.3.3.r33x_r20080129-7M7J7LB-u3aphGW6o3_VmiVfGXWO)
"Eclipse Project SDK"
*** Plug-in Registry:
ch.ethz.iks.slp (1.0.0.RC2_v200802052042) "jSLP" [Resolved]
com.ibm.icu (3.6.1.v20070906) "International Components for Unicode for
Java (ICU4J)" [Active]
com.ibm.icu.source (3.6.1.v20070906) "International Components for
Unicode for Java (ICU4J) source plug-in" [Resolved]
com.jcraft.jsch (0.1.31) "JSch" [Resolved]
com.skype (0.3.0.v20080315-2247) "Skype4Java API" [Starting]
com.skype.linux.x86 (0.2.0.v20080315-2247) "ECF Skype Linux X86
Fragment" [Installed]
com.skype.linux.x86_64 (0.1.0.v20080315-2247) "ECF Skype Linux x86_64
com.skype.win32.win32.x86 (0.1.0.v20080315-2247) "Skype4Java API" [Resolved]
javax.servlet (2.4.0.v200706111738) "Servlet API Bundle" [Resolved]
javax.servlet.jsp (2.0.0.v200706191603) "Java Server Pages API Bundle"
[Resolved]
javax.servlet.jsp.source (2.0.0.v200706191603) "Java Server Pages API
Source Bundle" [Resolved]
javax.servlet.source (2.4.0.v200706111738) "Servlet API Source Bundle"
[Resolved]
org.apache.ant (1.7.0.v200706080842) "Apache Ant" [Resolved]
org.apache.ant.source (1.7.0.v200706080842) "Apache Ant Source" [Resolved]
org.apache.commons.codec (1.2.0.v200711021015) "Apache Commons Codec
Plug-in" [Resolved]
org.apache.commons.el (1.0.0.v200706111724) "Apache Commons JSP 2.0
Expression Language Interpreter" [Resolved]
org.apache.commons.el.source (1.0.0.v200706111724) "Apache Commons JSP
2.0 Expression Language Interpreter Source" [Resolved]
org.apache.commons.httpclient (3.1.0.v200712051435) "Apache Commons
Httpclient Plug-in" [Resolved]
org.apache.commons.logging (1.0.4.v200706111724) "Apache Commons Logging
Plug-in" [Resolved]
org.apache.commons.logging (1.0.4.v200711021015) "Apache Commons Logging
Plug-in" [Resolved]
org.apache.commons.logging.source (1.0.4.v200706111724) "Apache Commons
Logging Plug-in Source" [Resolved]
org.apache.jasper (5.5.17.v200706111724) "Apache Jasper 2 Plug-in"
[Resolved]
org.apache.jasper.source (5.5.17.v200706111724) "Apache Jasper 2 Source
Plug-in" [Resolved]
org.apache.lucene (1.9.1.v200706111724) "Apache Lucene" [Resolved]
org.apache.lucene.analysis (1.9.1.v200706181610) "Apache Lucene
Analysis" [Resolved]
org.apache.lucene.analysis.source (1.9.1.v200706181610) "Apache Lucene
Analysis Source" [Resolved]
org.apache.lucene.source (1.9.1.v200706111724) "Apache Lucene Source"
[Resolved]
org.eclipse.ant.core (3.1.200.v20070522) "Ant Build Tool Core" [Starting]
org.eclipse.ant.ui (3.2.200.v20070825_r331) "Ant UI" [Starting]
org.eclipse.bittorrent (0.3.0) "pluginName" [Resolved]
org.eclipse.compare (3.3.2.r33x_20080128) "Compare Support" [Active]
org.eclipse.core.boot (3.1.100.v20060603) "Core Boot" [Starting]
org.eclipse.core.commands (3.3.0.I20070605-0010) "Commands" [Resolved]
org.eclipse.core.contenttype (3.2.100.v20070319) "Eclipse Content
Mechanism" [Active]
org.eclipse.core.databinding (1.0.1.M20070822-0800) "JFace Data Binding"
[Resolved]
org.eclipse.core.databinding.beans (1.0.1.M20070910-0800b) "JFace Data
Binding for JavaBeans" [Resolved]
org.eclipse.core.expressions (3.3.0.v20070606-0010) "Expression
Language" [Active]
org.eclipse.core.filebuffers (3.3.1.r331_v20070829) "File Buffers" [Active]
org.eclipse.core.filesystem (1.1.0.v20070606) "Core File Systems" [Active]
org.eclipse.core.filesystem.win32.x86 (1.1.0.v20070510) "Core File
System for Windows" [Resolved]
org.eclipse.core.jobs (3.3.1.R33x_v20070709) "Eclipse Jobs Mechanism"
[Active]
org.eclipse.core.net (1.0.1.r33x_20070709) "Internet Connection
Management" [Active]
org.eclipse.core.resources (3.3.1.R33x_v20080205) "Core Resource
org.eclipse.core.resources.compatibility (3.2.100.v20070502) "Core
Resource Management Compatibility Fragment" [Resolved]
org.eclipse.core.resources.win32 (3.3.0.v20070226) "Core Resource
Management Win32 Fragment" [Resolved]
org.eclipse.core.runtime (3.3.100.v20070530) "Core Runtime" [Active]
org.eclipse.core.runtime.compatibility (3.1.200.v20070502) "Core Runtime
Plug-in Compatibility" [Active]
org.eclipse.core.runtime.compatibility.auth (3.2.100.v20070502)
"Authorization Compatibility Plug-in" [Active]
org.eclipse.core.runtime.compatibility.registry (3.2.100.v20070316)
"Eclipse Registry Compatibility Fragment" [Resolved]
org.eclipse.core.variables (3.2.0.v20070426) "Core Variables" [Active]
org.eclipse.cvs (1.0.2.r33x_r20080129) "Eclipse CVS Client" [Starting]
"Eclipse CVS Client SDK" [Resolved]
org.eclipse.debug.core (3.3.2.v20080117_r332) "Debug Core" [Active]
org.eclipse.debug.ui (3.3.2.v20080117_r332) "Debug UI" [Active]
org.eclipse.ecf (1.4.0.v20080315-2247) "Eclipse Communication Framework
(ECF)" [Active]
org.eclipse.ecf.core.source (2.0.0.v20080315-2247) "ECF Core Source"
[Resolved]
org.eclipse.ecf.datashare (1.3.0.v20080315-2247) "ECF DataShare API"
[Resolved]
org.eclipse.ecf.discovery (2.0.0.v20080315-2247) "ECF Discovery API"
[Active]
org.eclipse.ecf.discovery.ui (2.0.0.v20080315-2247) "ECF Discovery UI"
[Starting]
org.eclipse.ecf.doc (1.3.0.v20080315-2247) "ECF Documentation" [Starting]
org.eclipse.ecf.docshare (2.0.0.v20080315-2247) "ECF DocShare Plugin"
[Active]
org.eclipse.ecf.example.clients (1.3.0.v20080315-2247) "ECF Clients
Example" [Resolved]
org.eclipse.ecf.example.collab (1.3.0.v20080315-2247) "ECF Collaboration
Examples" [Starting]
org.eclipse.ecf.example.collab.editor (1.0.200.v20080315-2247) "ECF
Shared Editor Example" [Starting]
org.eclipse.ecf.examples.remoteservices.client (1.0.100.v20080315-2247)
"ECF RemoteServices Example Client" [Starting]
org.eclipse.ecf.examples.remoteservices.common (1.0.100.v20080315-2247)
"ECF RemoteServices Example Common" [Starting]
org.eclipse.ecf.examples.remoteservices.server (1.0.100.v20080315-2247)
"ECF RemoteServices Example Server" [Starting]
org.eclipse.ecf.examples.source (2.0.0.v20080315-2247) "ECF Examples
Source" [Resolved]
org.eclipse.ecf.examples.updatesite.client (1.0.100.v20080315-2247) "ECF
Updatesite Example Client" [Starting]
org.eclipse.ecf.examples.updatesite.server (1.0.100.v20080315-2247) "ECF
Updatesite Example Server" [Installed]
org.eclipse.ecf.filetransfer (2.0.0.v20080315-2247) "ECF Filetransfer
API" [Active]
org.eclipse.ecf.filetransfer.ui (1.4.0.v20080315-2247) "ECF File
Transfer UI" [Installed]
org.eclipse.ecf.identity (1.3.0.v20080315-2247) "ECF Identity API" [Active]
org.eclipse.ecf.presence (1.3.0.v20080315-2247) "ECF Presence API" [Active]
org.eclipse.ecf.presence.bot (1.2.0.v20080315-2247) "ECF Presence Bot
API" [Starting]
org.eclipse.ecf.presence.collab.ui (1.2.0.v20080315-2247) "ECF Presence
Collaboration UI" [Active]
org.eclipse.ecf.presence.ui (1.2.0.v20080315-2247) "ECF Presence UI"
[Active]
org.eclipse.ecf.protocol.msn (1.2.0.v20080315-2247) "ECF MSN Protocol
Implementation" [Resolved]
org.eclipse.ecf.provider (1.3.0.v20080315-2247) "ECF Provider API" [Active]
org.eclipse.ecf.provider.bittorrent (0.3.0.v20080315-2247) "ECF
Bittorrent Provider" [Active]
org.eclipse.ecf.provider.bittorrent.ui (0.2.0.v20080315-2247) "ECF
Bitorrent Provider UI" [Installed]
org.eclipse.ecf.provider.datashare (1.3.0.v20080315-2247) "ECF Datashare
Provider" [Active]
org.eclipse.ecf.provider.discovery (2.0.0.v20080315-2247) "ECF Discovery
Provider" [Active]
org.eclipse.ecf.provider.filetransfer (1.6.0.v20080315-2247) "ECF
Filetransfer Provider" [Active]
org.eclipse.ecf.provider.filetransfer.efs (1.5.0.v20080315-2247) "ECF
EFS Provider" [Active]
org.eclipse.ecf.provider.filetransfer.httpclient (1.5.0.v20080315-2247)
"ECF HttpClient Filetransfer Provider" [Active]
org.eclipse.ecf.provider.filetransfer.scp (1.2.0.v20080315-2247) "ECF
SCP Filetransfer Provider" [Active]
org.eclipse.ecf.provider.irc (1.3.0.v20080315-2247) "ECF IRC Provider"
[Active]
org.eclipse.ecf.provider.irc.ui (1.3.0.v20080315-2247) "ECF IRC UI"
[Starting]
org.eclipse.ecf.provider.jgroups (1.3.0.v20080315-2247) "ECF JGroups
Provider" [Active]
org.eclipse.ecf.provider.jgroups.ui (1.3.0.v20080315-2247) "ECF JGroups
Provider UI" [Starting]
org.eclipse.ecf.provider.jmdns (2.0.0.v20080315-2247) "ECF Discovery
Provider" [Active]
org.eclipse.ecf.provider.jms (1.3.0.v20080315-2247) "ECF JMS Provider"
[Active]
org.eclipse.ecf.provider.jms.activemq (1.3.0.v20080315-2247) "ECF
ActiveMQ Provider" [Active]
org.eclipse.ecf.provider.jms.activemq.ui (1.3.0.v20080315-2247) "ECF
ActiveMQ Provider UI" [Starting]
org.eclipse.ecf.provider.jms.weblogic (1.3.0.v20080315-2247) "ECF BEA
WebLogic Provider" [Active]
org.eclipse.ecf.provider.jms.weblogic.ui (1.3.0.v20080315-2247) "ECF JMS
Weblogic Provider UI" [Starting]
org.eclipse.ecf.provider.jslp (2.0.0.v20080315-2247) "ECF SLP Discovery
Provider" [Active]
org.eclipse.ecf.provider.msn (1.2.0.v20080315-2247) "ECF MSN Provider"
[Active]
org.eclipse.ecf.provider.msn.ui (1.2.0.v20080315-2247) "ECF MSN Provider
UI" [Starting]
org.eclipse.ecf.provider.remoteservice (1.3.0.v20080315-2247) "ECF
Remoteservice Provider" [Starting]
org.eclipse.ecf.provider.skype (1.4.0.v20080315-2247) "ECF Skype
Provider" [Active]
org.eclipse.ecf.provider.skype.ui (1.3.0.v20080315-2247) "ECF Skype
org.eclipse.ecf.provider.ui (1.3.0.v20080315-2247) "ECF Provider UI"
[Starting]
org.eclipse.ecf.provider.xmpp (1.3.0.v20080315-2247) "ECF XMPP Provider"
[Active]
org.eclipse.ecf.provider.xmpp.ui (1.3.0.v20080315-2247) "ECF XMPP
Provider UI" [Active]
org.eclipse.ecf.provider.yahoo (1.2.0.v20080315-2247) "ECF YahooIM
Provider" [Active]
org.eclipse.ecf.provider.yahoo.ui (1.2.0.v20080315-2247) "ECF Yahoo UI"
[Starting]
org.eclipse.ecf.remoteservice (1.3.0.v20080315-2247) "ECF Remoteservice
API" [Starting]
org.eclipse.ecf.remoteservice.ui (1.0.0.v20080315-2247) "ECF Remote
Services UI" [Starting]
org.eclipse.ecf.server (1.3.0.v20080315-2247) "ECF Server API" [Starting]
org.eclipse.ecf.server.generic (1.2.0.v20080315-2247) "ECF Generic
Server" [Starting]
org.eclipse.ecf.server.jgroups (1.2.0.v20080315-2247) "ECF JGroups
Manager" [Starting]
org.eclipse.ecf.sharedobject (1.3.0.v20080315-2247) "ECF Sharedobject
API" [Active]
org.eclipse.ecf.telephony.call (1.2.0.v20080315-2247) "ECF Telephony
Call API" [Starting]
org.eclipse.ecf.telephony.call.ui (1.2.0.v20080315-2247) "ECF Call UI"
[Starting]
org.eclipse.ecf.ui (1.3.0.v20080315-2247) "ECF UI" [Active]
org.eclipse.equinox.app (1.0.1.R33x_v20070828) "Equinox Application
Container" [Active]
org.eclipse.equinox.common (3.3.0.v20070426) "Common Eclipse Runtime"
[Active]
org.eclipse.equinox.http.jetty (1.0.1.R33x_v20070816) "Jetty Http
Service" [Starting]
org.eclipse.equinox.http.registry (1.0.1.R33x_v20071231) "Http Service
Registry Extensions" [Resolved]
org.eclipse.equinox.http.servlet (1.0.1.R33x_v20070816) "Http Services
Servlet" [Starting]
org.eclipse.equinox.jsp.jasper (1.0.1.R33x_v20070816) "Jasper Jsp
Support Bundle" [Starting]
org.eclipse.equinox.jsp.jasper.registry (1.0.0.v20070607) "Jasper Jsp
Registry Support Plug-in" [Starting]
org.eclipse.equinox.launcher (1.0.1.R33x_v20080118) "Equinox Launcher"
[Resolved]
org.eclipse.equinox.launcher.win32.win32.x86 (1.0.3.R33x_v20080118)
"Equinox Launcher Win32 X86 Fragment" [Resolved]
org.eclipse.equinox.preferences (3.2.101.R33x_v20080117) "Eclipse
Preferences Mechanism" [Active]
org.eclipse.equinox.registry (3.3.1.R33x_v20070802) "Extension Registry
Support" [Active]
org.eclipse.help (3.3.2.v20071126_33x) "Help System Core" [Active]
org.eclipse.help.appserver (3.1.200.v20070510) "Help Application Server"
[Starting]
org.eclipse.help.base (3.3.1.v20070813_33x) "Help System Base" [Starting]
org.eclipse.help.ui (3.3.2.v20071126_33x) "Help System UI" [Starting]
org.eclipse.help.webapp (3.3.2.v20071102_33x) "Help System Webapp"
[Starting]
org.eclipse.jdt (3.3.1.r332_v20080131) "Eclipse Java Development Tools"
[Resolved]
org.eclipse.jdt.apt.core (3.3.1.R33x_v20071112-2330) "Java Annotation
Processing Core" [Active]
org.eclipse.jdt.apt.pluggable.core (1.0.1.R33x_v20071002-2100) "Java
Compiler Apt IDE" [Installed]
org.eclipse.jdt.apt.ui (3.3.1.R33x_v20071002-2100) "Java Annotation
Processing UI" [Starting]
org.eclipse.jdt.compiler.apt (1.0.1.R33x_v20071002-2100) "Java Compiler
Apt" [Installed]
org.eclipse.jdt.compiler.tool (1.0.1.v_793_R33x) "Java Compiler Tool
Support" [Installed]
org.eclipse.jdt.core (3.3.3.v_793_R33x) "Java Development Tools Core"
[Active]
org.eclipse.jdt.core.manipulation (1.1.0.v20070606-0010) "Java Code
Manipulation Functionality" [Active]
org.eclipse.jdt.debug (3.3.1.v20070719_r331) "JDI Debug Model" [Active]
org.eclipse.jdt.debug.ui (3.2.102.v20071002_r332) "JDI Debug UI" [Active]
org.eclipse.jdt.doc.isv (3.3.1.r331_v20070913) "Eclipse JDT Plug-in
Developer Guide" [Starting]
org.eclipse.jdt.doc.user (3.3.2.r332_20080116-0900) "Eclipse Java
Development User Guide" [Starting]
org.eclipse.jdt.junit (3.3.2.r332_20080109-0800) "Java Development Tools
JUnit support" [Starting]
org.eclipse.jdt.junit.runtime (3.3.0.v20070606-0010) "Java Development
Tools JUnit runtime support" [Resolved]
org.eclipse.jdt.junit4.runtime (1.0.100.v20070606-0010) "Java
Development Tools JUnit4 runtime support" [Resolved]
org.eclipse.jdt.launching (3.3.2.v20080115_r332) "Java Development Tools
Launching Support" [Active]
Development Tools SDK" [Resolved]
org.eclipse.jdt.ui (3.3.2.r332_20080128) "Java Development Tools UI"
[Active]
org.eclipse.jface (3.3.2.M20080207-0800) "JFace" [Active]
org.eclipse.jface.databinding (1.1.1.M20080207-0800) "JFace Data Binding
for SWT and JFace" [Resolved]
org.eclipse.jface.text (3.3.2.r332_20071017-0800) "JFace Text" [Resolved]
org.eclipse.jsch.core (1.0.0.I20070426) "JSch Core" [Active]
org.eclipse.jsch.ui (1.0.1.r33x_20070709) "JSch UI" [Starting]
org.eclipse.ltk.core.refactoring (3.3.1.r332_20080128) "Refactoring
Core" [Active]
org.eclipse.ltk.ui.refactoring (3.3.1.r332_20080128) "Refactoring UI"
[Active]
org.eclipse.osgi (3.3.2.R33x_v20080105) "OSGi System Bundle" [Active]
org.eclipse.osgi.services (3.1.200.v20070605) "OSGi Release 4.0.1
Services" [Resolved]
org.eclipse.osgi.util (3.1.200.v20070605) "OSGi Release 4.0.1 Utility
Classes" [Resolved]
org.eclipse.pde (3.3.1.r33x_r20080129) "Eclipse Plug-in Development
Environment" [Active]
org.eclipse.pde.build (3.3.2.v20071019) "Plug-in Development Environment
Build Support" [Active]
org.eclipse.pde.core (3.3.2.v20071121-0800) "Plug-in Development Core"
[Active]
org.eclipse.pde.doc.user (3.3.0.v20070614-0800) "Eclipse Plug-in
Development User Guide" [Resolved]
org.eclipse.pde.junit.runtime (3.3.0.v20070608-1300) "PDE JUnit Plug-in
Test" [Resolved]
org.eclipse.pde.runtime (3.3.0.v20070608-1300) "Plug-in Development
Environment Runtime" [Starting]
"Eclipse Plug-in Development Environment Developer Resources" [Resolved]
org.eclipse.pde.ui (3.3.1.v20070912-0800) "Plug-in Development UI" [Active]
org.eclipse.pde.ui.templates (3.3.0.v20070608-1300) "PDE Templates"
[Starting]
org.eclipse.platform (3.3.3.r33x_r20080129) "Eclipse Platform" [Starting]
org.eclipse.platform.doc.isv (3.3.1.r331_v20070913) "Eclipse Platform
Plug-in Developer Guide" [Starting]
org.eclipse.platform.doc.user (3.3.0.M20070913-1400) "Eclipse Workbench
"Eclipse Platform Plug-in Developer Resources" [Resolved]
org.eclipse.platform.source.win32.win32.x86
(3.3.3.r33x_r20080129-_19UEl7Ezk_gXF1kouft) "Eclipse Platform Plug-in
org.eclipse.rcp (3.2.1.r33x_r20080131) "Eclipse RCP" [Starting]
"Eclipse RCP Plug-in Developer Resources" [Resolved]
org.eclipse.rcp.source.win32.win32.x86
(3.3.3.r33x_r20080129-8y8eE9UEUWI6qujeED0xT7bc) "Eclipse RCP Plug-in
org.eclipse.sdk (3.3.3.r33x_r20080129) "Eclipse Project SDK" [Starting]
org.eclipse.search (3.3.1.r331_v20070831-0800) "Search Support" [Active]
org.eclipse.swt (3.3.2.v3349d) "Standard Widget Toolkit" [Resolved]
org.eclipse.swt.win32.win32.x86 (3.3.3.v3349) "Standard Widget Toolkit
org.eclipse.team.core (3.3.1.r33x_20080128) "Team Support Core" [Active]
org.eclipse.team.cvs.core (3.3.2.r33x_20080128) "CVS Team Provider Core"
[Active]
org.eclipse.team.cvs.ssh (3.2.100.I20061208) "CVS SSH Core" [Starting]
org.eclipse.team.cvs.ssh2 (3.2.100.I20070604) "CVS SSH2" [Active]
org.eclipse.team.cvs.ui (3.3.1.r33x_20070807) "CVS Team Provider UI"
[Active]
org.eclipse.team.ui (3.3.2.r33x_20080128) "Team Support UI" [Active]
org.eclipse.text (3.3.0.v20070606-0010) "Text" [Resolved]
org.eclipse.tomcat (4.1.230.v20070531) "Tomcat Wrapper" [Starting]
org.eclipse.ui (3.3.1.M20071128-0800) "Eclipse UI" [Active]
org.eclipse.ui.browser (3.2.100.v20070524A) "Browser Support" [Starting]
org.eclipse.ui.cheatsheets (3.3.1.v20080125_33x) "Cheat Sheets" [Starting]
org.eclipse.ui.console (3.2.2.v20071031_r332) "Console" [Active]
org.eclipse.ui.editors (3.3.2.r332_20080109-0800) "Default Text Editor"
[Active]
org.eclipse.ui.externaltools (3.1.200.v20070416) "External Tools" [Active]
org.eclipse.ui.forms (3.3.0.v20070511) "Eclipse Forms" [Active]
org.eclipse.ui.ide (3.3.2.M20080207-0800) "Eclipse IDE UI" [Active]
org.eclipse.ui.ide.application (1.0.0.I20070530-0100) "Eclipse IDE UI
Application" [Resolved]
org.eclipse.ui.intro (3.2.101.v20070827_33x) "Welcome Framework" [Starting]
org.eclipse.ui.intro.universal (3.2.100.v20070530A) "Universal Welcome"
[Starting]
org.eclipse.ui.navigator (3.3.2.M20080207-0800) "Common Navigator View"
[Starting]
org.eclipse.ui.navigator.resources (3.3.1.M20070831-2000) "Navigator
Workbench Components" [Starting]
org.eclipse.ui.net (1.0.0.I20070516) "Internet Connection Management UI"
[Active]
org.eclipse.ui.presentations.r21 (3.2.100.I20070605-0010) "R21
Presentation Plug-in" [Starting]
org.eclipse.ui.views (3.2.101.M20080207-0800) "Views" [Active]
org.eclipse.ui.views.properties.tabbed (3.3.1.M20070831-0800) "Tabbed
Properties View" [Starting]
org.eclipse.ui.win32 (3.2.100.I20070319-0010) "Eclipse UI Win32
Enhancements" [Resolved]
org.eclipse.ui.workbench (3.3.2.M20080207-0800) "Workbench" [Active]
org.eclipse.ui.workbench.compatibility (3.2.0.I20070319-0010) "Workbench
Compatibility" [Resolved]
org.eclipse.ui.workbench.texteditor (3.3.2.r332_20080109-0800) "Text
Editor Framework" [Active]
org.eclipse.update.configurator (3.2.101.R33x_v20070810) "Install/Update
Configurator" [Active]
org.eclipse.update.core (3.2.101.R33x_v20070911) "Install/Update Core"
[Active]
org.eclipse.update.core.win32 (3.2.100.v20070615) "Install/Update Core
org.eclipse.update.scheduler (3.2.100.v20070615) "Automatic Updates
Scheduler" [Active]
org.eclipse.update.ui (3.2.100.v20070615) "Install/Update UI" [Starting]
org.jivesoftware.smack (2.2.1) "Jive Software Smack API" [Resolved]
org.junit (3.8.2.v200706111738) "JUnit Testing Framework" [Resolved]
org.junit.source (3.8.2.v200706111738) "JUnit Testing Framework Source"
[Resolved]
org.junit4 (4.3.1) "JUnit Testing Framework Version 4" [Resolved]
org.mortbay.jetty (5.1.11.v200706111724) "Jetty WebServer" [Resolved]
org.mortbay.jetty.source (5.1.11.v200706111724) "Jetty WebServer Source"
[Resolved]
Re: Skype connection wizard hangs [message #622638 is a reply to message #622637] |
Wed, 19 March 2008 05:36 |
Scott Lewis Messages: 1038 Registered: July 2009 |
Hi Dicky,
Hmmm...I'm not having this problem at all with win32/Skype (v3.6.0.216).
and ECF latest build.
Some questions:
Do you have Skype (of recent version) running before/when you start the
Skype wizard?
Are you logged into Skype?
If the answer is 'yes' to both of these...
If you go into Skype, Tools->Options->Advanced Settings->
Other things you can do (bottom of page on right)
Click on "Manage other program's access to Skype"
Remove any relevant entries (java and/or Eclipse)
Please let us know if this fixes things or not. If not we file bug and
try to reproduce further.
Scott
Dicky Johan wrote:
> win32
> -ws
> win32
> -arch
> x86
> -showsplash
> -launcher
> -name
> Eclipse
> --launcher.library
> -startup
> -vm
> -Xmx256m
> eof=eof
> file.separator=\
> line.separator=
va
> x.sound.sampled.spi,javax.sql,javax.sql.rowset,javax.sql.row set.serial,javax.sql.rowset.spi,javax.swing,javax.swing.bord er,javax.swing.colorchooser,javax.swing.event,javax.swing.fi lechooser,javax.swing.plaf,javax.swing.plaf.basic,javax.swin g.plaf.metal,javax.swing.plaf.multi,javax.swing.plaf.synth,j avax.swing.table,javax.swing.text,javax.swing.text..html,jav ax.swing.text.html.parser,javax.swing.text.rtf,javax.swing.t ree,javax.swing.undo,javax.transaction,javax.transaction.xa, javax.xml,javax.xml.datatype,javax.xml.namespace,javax.xml.p arsers,javax.xml.transform,javax.xml.transform.dom,javax.xml .transform.sax,javax.xml.transform.stream,javax.xml.validati on,javax.xml.xpath,org.ietf.jgss,org.omg.CORBA,org.omg.CORBA _2_3,org.omg.CORBA_2_3.portable,org.omg.CORBA.DynAnyPackage, org.omg.CORBA.ORBPackage,org.omg.CORBA.portable,org.omg.CORB A.TypeCodePackage,org.omg.CosNaming,org.omg.CosNaming.Naming ContextExtPackage,org.omg.CosNaming.NamingContextPackage,org .omg.Dynamic,org.omg.Dynamic
Any
> os.arch=x86
> os.name=Windows XP
> os.version=5.1
> osgi.arch=x86
> osgi.nl=en_US
> osgi.os=win32
> osgi.ws=win32
> path.separator=;
> i386 i86
> sun.desktop=windows
> user.country=US
> user.language=en
> user.name=dickyj
> user.variant=
> *** Features:
> CVS Client"
> Framework (ECF)"
> Examples"
> "Eclipse Platform"
> RCP"
> [Resolved]
> [Resolved]
> [Resolved]
> Plug-in" [Resolved]
> Plug-in" [Resolved]
> Plug-in" [Resolved]
> [Resolved]
> Plug-in" [Resolved]
> [Resolved]
> Mechanism" [Active]
> [Resolved]
> Language" [Active]
> [Active]
> (ECF)" [Active]
> [Resolved]
> [Resolved]
> [Active]
> [Starting]
> [Active]
> Example" [Resolved]
> Source" [Resolved]
> API" [Active]
> API" [Starting]
> [Active]
> Provider" [Active]
> Provider" [Active]
> [Active]
> [Starting]
> Provider" [Active]
> Provider" [Active]
> [Active]
> Provider" [Active]
> [Active]
> UI" [Starting]
> Provider" [Active]
> [Starting]
> [Active]
> Provider" [Active]
> [Starting]
> API" [Starting]
> Server" [Starting]
> Manager" [Starting]
> API" [Active]
> [Starting]
> Container" [Active]
> [Active]
> Service" [Starting]
> Servlet" [Starting]
> [Resolved]
> Support" [Active]
> [Starting]
> [Starting]
> [Resolved]
> Apt" [Installed]
> [Active]
> [Active]
> Core" [Active]
> [Active]
> Classes" [Resolved]
> [Active]
> Test" [Resolved]
> [Starting]
> [Active]
> [Active]
> [Active]
> [Starting]
> [Starting]
> [Active]
> [Active]
> Scheduler" [Active]
> [Resolved]
> [Resolved]
Re: Skype connection wizard hangs [message #622639 is a reply to message #622638] |
Wed, 19 March 2008 05:42 |
Ok, here's more details on the problem. When I click on the Skype
Connection Wizard, a dialog pops up on the bottom right corner of my
screen (from Skype I believe) that asks if I allow Eclipse to access
Skype, I click on the link, and then after that, it just hangs.
I am using Skype version 3.6.0.248 client.
Dicky
Re: Skype connection wizard hangs [message #622640 is a reply to message #622639] |
Wed, 19 March 2008 14:29 |
Hi Dicky,
In my own usage (and others AFAIK) if I allow the program to use Skype
(by selecting the radio button and clicking OK) it proceeds just fine.
Is it hanging for you when the dialog comes up (i.e. is the dialog
responsive?) or does the dialog respond, but it hang after you click OK?
Scott
> Dicky
Re: Skype connection wizard hangs [message #622641 is a reply to message #622640] |
Wed, 19 March 2008 14:42 |
Scott Lewis wrote:
> Hi Dicky,
> Scott
>> Thanks,
>> Dicky
Scott,
Basically I never see the Skype Connection Wizard dialog. Just clicking
on the Skype button hangs the workspace.
Hi, here is the interesting part, initially when I click on the advanced
dialog in Skype, there are no applications listed. When I click on the
Skype connection wizard, the Skype prompt for Eclipse show up, I click
that and it hangs. But after that, I notice that in the Advanced Dialog
in Skype, Eclipse application shows up as an item except that it has no
permissions. I restarted Eclipse and click on the Skype Connection
Wizard again, and it hangs...
Dicky
Re: Skype connection wizard hangs [message #622642 is a reply to message #622641] |
Thu, 20 March 2008 15:00 |
Just in case others are experiencing this...
Dicky and I met at EclipseCon and it turned out to be some stale
information in his Skype configuration. Please speak up here if you are
having a similar/same problem and cannot resolve it.
Scott
Dicky Johan wrote:
> Scott Lewis wrote:
>> Hi Dicky,
>> Thanks,
>> Scott
>>> Thanks,
>>> Dicky
> Scott,
> Dicky
Re: Skype connection wizard hangs [message #622644 is a reply to message #622642] |
Fri, 21 March 2008 07:15 |
Actually,
After more investigation into this issue, the problem may surface due to
the fact that the Skype prompt for allow access to Eclipse is behind the
Eclipse application. I think there is a Z-order issue.
If you ever see this problem, just try to tab thru your Windows until
you see the Skype prompt.
Dicky
Current Time: Tue Apr 23 09:26:54 GMT 2024
Powered by FUDForum. Page generated in 0.04327 seconds
