Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » Better way to initialize object with sub-objects?
Better way to initialize object with sub-objects? [message #622045] Mon, 25 January 2010 02:01 Go to next message
Christoph Wienands is currently offline Christoph WienandsFriend
Member
Hello all,
I have just implemented the following functionality in a GMF editor: When a
user creates an object of type A in a diagram, the DSL automatically creates
two contained sub-objects of type B in object of type A. This is because
type A mandates that there are always two contained objects of type B and it
makes the language more usable because the user does not manually have to
create those two objects.
Currently, I modified some generated code in the GMF-generated .diagram
plug-in to add the two B objects. However, this is kind of nasty and I think
there must be a better way. And here is the reason why I am posting this in
the EMF NG...
The GMF code retrieves an object of 'IElementType' that represents the A
class. The 'IElementType' objects are provided by EMF's
'ElementTypeRegistry'. So on this IElementType object, GMF calls the
'getEditCommand' function, which returns an object of type 'ICommand' (named
'configureCommand' in GMF). When debugging, the call returns NULL. However,
I believe that I somehow could register my own configure command so that GMF
automatically executes it. But that's where I lost the trail.
My question is, is this EMF functionality the right place/mechanism for
custom object initialization code? And what is the proper way/place in the
lifecycle/place to hook to register my own edit command?
Thanks a lot,
Christoph
Re: Better way to initialize object with sub-objects? [message #622046 is a reply to message #622045] Mon, 25 January 2010 10:13 Go to previous message
Christoph,
Comments below.
Christoph Wienands wrote:
> Hello all,
> the EMF NG...
Using news://new.eclipse.org/eclipse.tools.emf would be better.
That's definitely a GMF question.
In a basic generated EMF editor the place to do this would be in the
creation of the child descriptors, i.e., collectNewChildDescriptors, but
GMF doesn't reuse that so I'm not sure what to suggest.
> Thanks a lot,
> Christoph
Ed Merks
Previous Topic:Better way to initialize object with sub-objects?
Next Topic:Subversive intent to MTF
Current Time: Mon Aug 15 18:59:49 GMT 2022
Powered by FUDForum. Page generated in 0.02332 seconds
