Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » EMF: Generated classes - Copyright details
EMF: Generated classes - Copyright details [message #621868] Wed, 02 December 2009 14:43 Go to next message
Stancho  is currently offline Stancho Friend
Hi all,
I am using genmodel to generate Model Code.
I set Copyright text and it is generated correctly but I have $Id$ at the end of every copyright header.
How can I remove this $Id$?
Thanks in advance,
Stancho
Re: EMF: Generated classes - Copyright details [message #621870 is a reply to message #621868] Wed, 02 December 2009 14:57 Go to previous message
--------------000003080805010705010902
Stancho,
The Header.javajetinc template looks like this so if you've set the
copyright property property on the GenModel or include copyright
annotations in the Ecore model, those should end up being used.
<%{GenBase copyrightHolder = argument instanceof GenBase ?
(GenBase)argument : argument instanceof Object[] &&
((Object[])argument)[0] instanceof GenBase ?
(GenBase)((Object[])argument)[0] : null;%>
<%if (copyrightHolder != null && copyrightHolder.hasCopyright()) {%>
< %=copyrightHolder.getCopyright(copyrightHolder.getGenModel() .getIndentation(stringBuffer))% >
<%} else {%>
* <copyright>
* </copyright>
* <%="$"%>Id<%="$"%>
Which version of EMF are you using?
Stancho wrote:
> Hi all,
> Thanks in advance,
> Stancho
Content-Type: text/html; charset=UTF-8
<html>
<head>
<meta content="text/html;charset=UTF-8" http-equiv="Content-Type">
</head>
Stancho,<br>
<br>
annotations in the Ecore model, those should end up being used.<br>
<blockquote><small>/**<br>
&lt;%{GenBase copyrightHolder = argument instanceof GenBase ?
(GenBase)argument : argument instanceof Object[] &amp;&amp;
(GenBase)((Object[])argument)[0] : null;%&gt;<br>
&lt;%if (copyrightHolder != null &amp;&amp;
copyrightHolder.hasCopyright()) {%&gt;<br>
&lt;%=copyrightHolder.getCopyright(copyrightHolder.getGe nModel().getIndentation(stringBuffer))%&gt; <br>
&lt;%} else {%&gt;<br>
 * &lt;copyright&gt;<br>
 * &lt;/copyright&gt;<br>
 *<br>
 * &lt;%="$"%&gt;Id&lt;%="$"%&gt;<br>
&lt;%}}%&gt;<br>
 */</small><br>
</blockquote>
Which version of EMF are you using?<br>
<br>
<br>
Stancho wrote:
<blockquote cite="mid:hf5uee$vl5$1@build.eclipse.org" type="cite">Hi
all,
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Thanks in advance,
<br>
Stancho
<br>
</blockquote>
</body>
</html>
--------------000003080805010705010902--
Ed Merks
Previous Topic:EEF generated classes do not compile
Next Topic:EMF: Generated classes - Copyright details
Current Time: Sun Jul 25 23:30:26 GMT 2021
Powered by FUDForum. Page generated in 0.02026 seconds
