Profiles and stereotype properties [message #621782] |
Tue, 29 July 2008 23:37 |
Alexandre Torres Messages: 139 Registered: July 2009 |
I'm a Papyrus user for some time... We have a profile with stereotypes and
classes in the same profile model. The first thing I noticied when I tried
to port it to uml2tools is that the profile model does not seems to accept
classes. Is that true ?
It would be cool to see classes used by the stereotypes in the profile
model.
On the class model, after applying the profile, we can add stereotypes to
the classes (it's a new feature I think). Is there any way to add
properties too ? is there any plan to support that in the fututre?
and how about user defined types ? I think it's the main problem to any
uml 2 model designer... a stereotype property may be an instance of class
(by composite relationship) with several properties, and each property may
be another instance of a class, and so on... Do you have any plans on
attacking this problem ?
If not, maybe we can extend the tools :)
Thanks, the project is improving...I did the test with version 0.8 and
eclipse 3.4
Alexandre
FUDForum. Page generated in 0.02896 seconds
