Home » Archived » Service Oriented Architecture Tools Platform (STP) » SVN access.
SVN access. [message #621223] Fri, 04 September 2009 11:26
Juan Pedro Silva is currently offline Juan Pedro SilvaFriend
--------------080305040008020804040105
Hello everybody. I'm trying to access the SVN to check out the
org.eclipse.stp.xef.test fragment for the policy editor, but cannot
access the repository.
In the STP web it says that you can access either, and I quote:
/*svn+ssh://dev.eclipse.org/svnroot/stp* Anonymous read-access is
enabled at http://dev.eclipse.org/svnroot/stp for those who want to view
to code, committers should log in to make changes./
I tried both with no luck. the svn+ssh doesn't take Anonymous/Anonymous,
Anonymous/"", or my bugzilla username/password.
The http(s) or svn (without ssh) repositories are not even found.
I see that now the repository is split, and in the viewcvs the new
address is
http://dev.eclipse.org/viewsvn/index.cgi/org.eclipse.stp.pol icy/trunk/?root=STP_POLICYEDITOR
but I couldn't access that repository either.
How should I currently acces the respository?.
Thank you very much.
Juan Pedro
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
</head>
access the repository.<br>
In the STP web it says that you can access either, and I quote:<br>
<br>
&nbsp;<i><b>svn+ssh://dev.eclipse.org/svnroot/stp</b> Anonymous read-access
is enabled at <a href="http://dev.eclipse.org/svnroot/stp">http://dev.eclipse.org/svnroot/stp</a>
for those who want to view to code, committers should log in to make
changes.</i> <br>
<br>
Anonymous/Anonymous, Anonymous/"", or my bugzilla username/password.<br>
The http(s) or svn (without ssh) repositories are not even found.<br>
<br>
address is
<a class="moz-txt-link-freetext" href=" http://dev.eclipse.org/viewsvn/index.cgi/org.eclipse.stp.pol icy/trunk/?root=STP_POLICYEDITOR"> http://dev.eclipse.org/viewsvn/index.cgi/org.eclipse.stp.pol icy/trunk/?root=STP_POLICYEDITOR</a><br>
but I couldn't access that repository either.<br>
<br>
How should I currently acces the respository?.<br>
Thank you very much.<br>
Regards,<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; Juan Pedro<br>
</body>
</html>
--------------080305040008020804040105--
Previous Topic:SOPERA Validation: XSD Validation: cvc-elt.1: Cannot find the declaration of element 'wsp:Policy'.
Next Topic:SVN access.
Current Time: Thu Dec 12 13:07:25 GMT 2024
Powered by FUDForum. Page generated in 0.03352 seconds
