Home » Archived » Service Oriented Architecture Tools Platform (STP) » AnnValidator missing from Ganymede Update
Re: AnnValidator missing from Ganymede Update [message #620106 is a reply to message #620101] |
Wed, 08 October 2008 22:08 |
Brian Messages: 4 Registered: July 2009 |
I should be more specific. The error in my fist post occurred after I
removed the annValidator.jar from the plugins directory and restarted
eclipse. With the jar in the plugins directory, the log shows the
following at startup:
eclipse.buildId=M20080911-1700
java.version=1.6.0_06
Command-line arguments: -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.ui.workbench 2 0 2008-10-08 15:01:48.806
!MESSAGE A handler conflict occurred. This may disable some commands.
!SUBENTRY 1 org.eclipse.ui.workbench 2 0 2008-10-08 15:01:48.806
!MESSAGE Conflict for 'org.eclipse.gmf.ValidateAction':
HandlerActivation(commandId=org.eclipse.gmf.ValidateAction,
handler=ActionDelegateHandlerProxy(null,org.eclipse.stp.eid. datamodel.diagram.part.CimeroEditorValidateAction),
expression=WorkbenchWindowExpression(org.eclipse.ui.internal.WorkbenchWindow@107c615),sourcePriority=16384)
handler=ActionDelegateHandlerProxy(null,org.eclipse.stp.sca. diagram.part.SCADiagramValidateAction),
And then when I go to my JAX-WS project, right click on the annotated
class I wish to make a webservice from and then choose "JAX-WS
Tools">"Create Web Service" I see:
!ENTRY org.eclipse.osgi 2 0 2008-10-08 15:05:05.150
!MESSAGE The activator org.eclipse.stp.sc.sca.java.ScaJavaPlugin for
bundle org.eclipse.stp.sc.sca.java is invalid
!STACK 0
org.osgi.framework.BundleException: The activator
org.eclipse.stp.sc.sca.java.ScaJavaPlugin for bundle
at
org.eclipse.osgi.framework.internal.core.AbstractBundle.load BundleActivator(AbstractBundle.java:146)
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:980)
at
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:346)
at
org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:265)
at
org.eclipse.osgi.framework.util.SecureAction.start(SecureAct ion.java:400)
at
org.eclipse.osgi.framework.internal.core.BundleHost.loadClas s(BundleHost.java:234)
at
org.eclipse.osgi.framework.internal.core.AbstractBundle.load Class(AbstractBundle.java:1274)
at
org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .createExecutableExtension(RegistryStrategyOSGI.java:160)
at
org.eclipse.core.internal.registry.ExtensionRegistry.createE xecutableExtension(ExtensionRegistry.java:867)
at
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:243)
at
org.eclipse.core.internal.registry.ConfigurationElementHandl e.createExecutableExtension(ConfigurationElementHandle.java: 51)
at
org.eclipse.stp.sc.common.annotations.ext.AnnotationSupportP roxy.loadAnnotationResolver(AnnotationSupportProxy.java:91)
at
org.eclipse.stp.sc.common.annotations.ext.AnnotationSupportP roxy. <clinit>(AnnotationSupportProxy.java:58)
at
org.eclipse.stp.sc.common.annotations.ScAnnotationSupportUti ls.getAnnotationClassesForJavaElement(ScAnnotationSupportUti ls.java:188)
at
org.eclipse.stp.sc.common.annotations.ScAnnotationSupportUti ls.getAvailableAnnotationsForClass(ScAnnotationSupportUtils. java:54)
at
org.eclipse.stp.sc.common.annotations.ScAnnotationSupportUti ls.getAvailableAnnotationsForType(ScAnnotationSupportUtils.j ava:87)
at
org.eclipse.stp.sc.common.annotations.ScAnnotationSupportUti ls.isAnnotationValidForMember(ScAnnotationSupportUtils.java: 175)
at
org.eclipse.stp.sc.common.annotations.ScAnnotationSupportUti ls.getDefaultedAnnotationNode(ScAnnotationSupportUtils.java: 146)
at
org.eclipse.stp.sc.jaxws.wizards.annotations.AnnotationAttri butePage.initializeFromDefault(AnnotationAttributePage.java: 211)
at
org.eclipse.stp.sc.jaxws.wizards.annotations.AnnotationAttri butePage.createAttributeGroup(AnnotationAttributePage.java:1 82)
at
org.eclipse.stp.sc.jaxws.wizards.annotations.AnnotationAttri butePage.createControl(AnnotationAttributePage.java:126)
at org.eclipse.jface.wizard.Wizard.createPageControls(Wizard.ja va:170)
at
org.eclipse.jface.wizard.WizardDialog.createPageControls(Wiz ardDialog.java:669)
at
org.eclipse.jface.wizard.WizardDialog.createContents(WizardD ialog.java:543)
at
org.eclipse.stp.sc.jaxws.wizards.ScWizardDialog.createConten ts(ScWizardDialog.java:43)
at org.eclipse.jface.window.Window.create(Window.java:431)
at org.eclipse.jface.dialogs.Dialog.create(Dialog.java:1089)
at org.eclipse.jface.window.Window.open(Window.java:790)
at
org.eclipse.stp.sc.jaxws.actions.CreateWebServiceAction.run( CreateWebServiceAction.java:63)
at
org.eclipse.ui.internal.PluginAction.runWithEvent(PluginActi on.java:251)
at
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:583)
at
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:500)
at
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:411)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1003)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3823)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3422)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2382)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2346)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:21 98)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:493)
at
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:288)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:488)
at
org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
at
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:193)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:386)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 549)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:504)
at org.eclipse.equinox.launcher.Main.run(Main.java:1236)
Caused by: java.lang.ClassNotFoundException:
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl assInternal(BundleLoader.java:481)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:397)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:385)
at
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:87)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.loadCl ass(BundleLoader.java:313)
at
org.eclipse.osgi.framework.internal.core.BundleHost.loadClas s(BundleHost.java:227)
at
org.eclipse.osgi.framework.internal.core.AbstractBundle.load BundleActivator(AbstractBundle.java:139)
... 56 more
Root exception:
java.lang.ClassNotFoundException: org.eclipse.stp.sc.sca.java.ScaJavaPlugin
at
And when I right click on the root of my JAX-WS project and go to "JAX-WS
Tools">"Generate WSDL" I see:
!ENTRY org.eclipse.osgi 2 0 2008-10-08 15:07:39.556
!MESSAGE The activator org.eclipse.stp.sc.annvalidator.AnnValidatorPlugin
for bundle org.eclipse.stp.sc.annvalidator is invalid
!STACK 0
org.eclipse.stp.sc.annvalidator.AnnValidatorPlugin for bundle
at
at
at
at
at
at
at
at
at
at
at
at
org.eclipse.core.internal.events.BuildManager.instantiateBui lder(BuildManager.java:788)
at
org.eclipse.core.internal.events.BuildManager.initializeBuil der(BuildManager.java:741)
at
org.eclipse.core.internal.events.BuildManager.getBuilder(Bui ldManager.java:480)
at
org.eclipse.core.internal.events.BuildManager.basicBuild(Bui ldManager.java:199)
at
org.eclipse.core.internal.events.BuildManager$1.run(BuildMan ager.java:253)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
at
org.eclipse.core.internal.events.BuildManager.basicBuild(Bui ldManager.java:256)
at
org.eclipse.core.internal.events.BuildManager.basicBuild(Bui ldManager.java:218)
at
org.eclipse.core.internal.events.BuildManager.build(BuildMan ager.java:360)
at
org.eclipse.core.internal.resources.Project.internalBuild(Pr oject.java:516)
at org.eclipse.core.internal.resources.Project.build(Project.ja va:94)
at
org.eclipse.stp.sc.jaxws.actions.AssignedJava2WsdlAction.run (AssignedJava2WsdlAction.java:41)
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
... 50 more
Root exception:
So what I am doing so wrong that I am missing all these classes?
Thanks!
Re: AnnValidator missing from Ganymede Update [message #620108 is a reply to message #620106] |
Thu, 09 October 2008 12:10 |
Originally posted by: atoulme.intalio.com
Brian, please open a bug with those stacktraces, a reference to this
newsgroup thread, and the version numbers of the STP plugins in your
workspace.
Crossposting to SCA Tools newgroup as one of the exceptions is about the
SCA plugins.
Antoine
> BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at org.eclipse.ui.internal.PluginAction.runWithEvent(PluginActi on.java:251)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at java.lang.ClassLoader.loadClass(Unknown Source)
> at
> at
> at
> ... 56 more
> Root exception:
> at
> "JAX-WS Tools">"Generate WSDL" I see:
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 50 more
> Root exception:
> Thanks!
Re: AnnValidator missing from Ganymede Update [message #620109 is a reply to message #620108] |
Thu, 09 October 2008 12:47 |
Stephane Drapeau Messages: 199 Registered: July 2009 |
Hi Antoine, Brian,
Sorry, I don't think that SCA Tools is involved in your problem.
> org.osgi.framework.BundleException: The activator org.eclipse.stp.sc.sca.java.ScaJavaPlugin for bundle org.eclipse.stp.sc.sca.java is invalid
This error is coming from the Service Creation component (stp.sc).
This component contains (old) tools for SCA developpers but it doesn't
form part of the SCA Tools project.
However, you discovered a conflict between the Cimero Editor and the SCA
Composite Designer. This message is just a warning and is not related
with the before-mentioned exception.
Thanks ;)
Stéphane Drapeau
Obeo
Re: AnnValidator missing from Ganymede Update [message #620110 is a reply to message #620109] |
Thu, 09 October 2008 14:51 |
Stephane Drapeau wrote:
> Hi Antoine, Brian,
OK.
> Thanks ;)
Aha! I did something useful today. What a nice feeling!
> Regards,
> Stéphane Drapeau
> Obeo
Re: AnnValidator missing from Ganymede Update [message #620111 is a reply to message #620110] |
Thu, 09 October 2008 15:00 |
>> Hi Antoine, Brian,
> OK.
Brian, you should file a bug against stp.sc. If you want it fixed
quickly, please consider providing a patch.
Antoine
Current Time: Tue Apr 23 07:41:35 GMT 2024
Powered by FUDForum. Page generated in 0.04119 seconds
