Re: problem with the activity painter [message #620085 is a reply to message #620082] |
Tue, 23 September 2008 12:45 |
Originally posted by: atoulme.intalio.com
Please check that the activity has an activity type.
Antoine
Dali wrote:
> Hi everybody ,
> i'm getting the following when i'm trying to open my file editor input .
> at
> org.eclipse.stp.bpmn.figures.activities.ActivityPainter$4.ge tToolTipText(ActivityPainter.java:1246)
> at
> org.eclipse.stp.bpmn.figures.WrapLabelWithToolTip.updateTool Tip(WrapLabelWithToolTip.java:91)
> at
> org.eclipse.stp.bpmn.figures.WrapLabelWithToolTip.getTruncat ionString(WrapLabelWithToolTip.java:79)
> at
> org.eclipse.stp.gmf.runtime.draw2d.ui.figures.WrappingLabel. getTruncationStringSize(WrappingLabel.java:998)
> at
> org.eclipse.stp.gmf.runtime.draw2d.ui.figures.WrappingLabel. getMinimumSize(WrappingLabel.java:921)
> at
> org.eclipse.draw2d.StackLayout.calculateMinimumSize(StackLay out.java:44)
> at
> org.eclipse.draw2d.AbstractHintLayout.getMinimumSize(Abstrac tHintLayout.java:68)
> at org.eclipse.draw2d.Figure.getMinimumSize(Figure.java:707)
> at
> at
> at org.eclipse.draw2d.Figure.getMinimumSize(Figure.java:697)
> at
> org.eclipse.gmf.runtime.diagram.ui.layout.FreeFormLayoutEx.l ayout(FreeFormLayoutEx.java:49)
> at org.eclipse.draw2d.Figure$LayoutNotifier.layout(Figure.java: 1808)
> at org.eclipse.draw2d.Figure.layout(Figure.java:1029)
> at org.eclipse.draw2d.Figure.validate(Figure.java:1735)
> at
> org.eclipse.gmf.runtime.diagram.ui.figures.BorderItemsAwareF reeFormLayer.validate(BorderItemsAwareFreeFormLayer.java:169 )
> at
> org.eclipse.draw2d.FreeformViewport$FreeformViewportLayout.c alculatePreferredSize(FreeformViewport.java:28)
> at
> org.eclipse.draw2d.AbstractLayout.getPreferredSize(AbstractL ayout.java:93)
> it seems like the getToolTip is not getting the objects created in the
> diagram.
> I checked the source code and i don't now why it throws this.
> Best Regards ,
> Dali
Re: problem with the activity painter [message #620088 is a reply to message #620085] |
Tue, 23 September 2008 12:47 |
Also check that the activity is not null. If it is null, you probably
have an issue during the generation.
Antoine
> Antoine
> Dali wrote:
>> Hi everybody ,
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> diagram.
>> Best Regards ,
>> Dali
FUDForum. Page generated in 0.03594 seconds
