Home » Archived » Visual Editor (VE) » VE 1.4 and Eclipse 3.6
VE 1.4 and Eclipse 3.6 [message #618403] Sat, 26 June 2010 16:23 Go to next message
Hi!
I have some problems installing VE 1.4 on a fresh Eclipse 3.6 IDE for Java EE Developers installation, because i get some dependency errors (see below). There are some infos in different threads and in this bugreport:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=301766
for VE 1.4 and Eclipse 3.5. I have tried to installed only the VE SDK but still get the dependency error. Are there any chances to install VE 1.4 on Eclipse 3.6 or do we need a new VE version?
Thanks in advance for a reply.
Chris
Dependency error:
> Cannot complete the install because of a conflicting dependency.
> Software being installed: Visual Editor SDK 1.4.0.v20090826-1446-57F-9xKEUXK5__GAVDlmFRiymDdO (org.eclipse.ve.sdk.feature.group 1.4.0.v20090826-1446-57F-9xKEUXK5__GAVDlmFRiymDdO)
> Software currently installed: Eclipse IDE for Java EE Developers 1.3.0.20100617-0521 (epp.package.jee 1.3.0.20100617-0521)
> Only one of the following can be installed at once:
> International Components for Unicode for Java (ICU4J) 4.2.1.v20100412 (com.ibm.icu 4.2.1.v20100412)
> International Components for Unicode for Java (ICU4J) 4.0.1.v20090822 (com.ibm.icu 4.0.1.v20090822)
> Cannot satisfy dependency:
> From: Eclipse IDE for Java EE Developers 1.3.0.20100617-0521 (epp.package.jee 1.3.0.20100617-0521)
> To: org.eclipse.epp.package.jee.feature.feature.group [1.3.0.20100617-0521]
> From: Java EE IDE Feature 1.3.0.20100617-0521 (org.eclipse.epp.package.jee.feature.feature.group 1.3.0.20100617-0521)
> To: org.eclipse.platform.feature.group [3.6.0.v20100602-9gF78GpqFt6trOGhL60z0oEx3fz-JKNwxPY]
> From: Eclipse Platform 3.6.0.v20100602-9gF78GpqFt6trOGhL60z0oEx3fz-JKNwxPY (org.eclipse.platform.feature.group 3.6.0.v20100602-9gF78GpqFt6trOGhL60z0oEx3fz-JKNwxPY)
> To: org.eclipse.rcp.feature.group [3.6.0.v20100519-9OArFKvFtsd7WLUKh-DcYTS]
> From: Eclipse RCP 3.6.0.v20100519-9OArFKvFtsd7WLUKh-DcYTS (org.eclipse.rcp.feature.group 3.6.0.v20100519-9OArFKvFtsd7WLUKh-DcYTS)
> To: com.ibm.icu [4.2.1.v20100412]
> From: Visual Editor 1.4.0.v20090826-1446-777N-CcNBC0BwNk5HZZk (org.eclipse.ve.feature.group 1.4.0.v20090826-1446-777N-CcNBC0BwNk5HZZk)
> To: org.eclipse.ve.java.core [1.3.0,2.0.0)
> From: Visual Editor Java Core 1.4.0.v20090826-1446 (org.eclipse.ve.java.core 1.4.0.v20090826-1446)
> To: bundle com.ibm.icu [3.4.4.1,4.1.0)
> From: Visual Editor SDK 1.4.0.v20090826-1446-57F-9xKEUXK5__GAVDlmFRiymDdO (org.eclipse.ve.sdk.feature.group 1.4.0.v20090826-1446-57F-9xKEUXK5__GAVDlmFRiymDdO)
> To: org.eclipse.ve.feature.group [1.4.0.v20090826-1446-777N-CcNBC0BwNk5HZZk]
Re: VE 1.4 and Eclipse 3.6 [message #618404 is a reply to message #618403] Wed, 30 June 2010 02:03 Go to previous messageGo to next message
I have same problem. On Eclipse 3.5 no problem, on 3.6 same error as Chris. :(
I use this online install site:
http://download.eclipse.org/tools/ve/updates/1.4/
Re: VE 1.4 and Eclipse 3.6 [message #618405 is a reply to message #618404] Wed, 30 June 2010 06:52 Go to previous messageGo to next message
Troubles installing VE 1.4 ( Visual Editor ) on Eclipse 3.6 Helios
I've used this update site:
and I tried to install Visual Editor on different Eclipse distros:
- Eclipse RCP and RAP
- Eclipse Modeling (with incubating components)
- Eclipse Reporting.
In any case i get this error:
Cannot complete the install because one or more required items could not be found.
Software being installed: Java EMF Model 1.4.0.v20090826-1446-7H-FPbAcggQleH8hJifHfUd (org.eclipse.jem.feature.group 1.4.0.v20090826-1446-7H-FPbAcggQleH8hJifHfUd)
Missing requirement: Java EMF Model Utilities 2.0.200.R3_1_maintenance (org.eclipse.jem.util 2.0.200.R3_1_maintenance) requires 'bundle com.ibm.icu [3.8.1.1,4.1.0)' but it could not be found
From: Java EMF Model 1.4.0.v20090826-1446-7H-FPbAcggQleH8hJifHfUd (org.eclipse.jem.feature.group 1.4.0.v20090826-1446-7H-FPbAcggQleH8hJifHfUd)
To: org.eclipse.jem.util [2.0.200.R3_1_maintenance]
Anyone can help me ?
Re: VE 1.4 and Eclipse 3.6 [message #618407 is a reply to message #618403] Thu, 01 July 2010 07:46 Go to previous messageGo to next message
Hi, same problem here. Eclipse Helios for Java Dev.
Software being installed: Visual Editor 1.4.0.v20090826-1446-777N-CcNBC0BwNk5HZZk (org.eclipse.ve.feature.group 1.4.0.v20090826-1446-777N-CcNBC0BwNk5HZZk)
Missing requirement: Visual Editor Common Data Editor 1.4.0.v20090826-1446 (org.eclipse.ve.cde 1.4.0.v20090826-1446) requires 'bundle com.ibm.icu [3.4.4.1,4.1.0)' but it could not be found
To: org.eclipse.ve.cde [1.3.0,2.0.0)
My Plugins:
Mobile Tools
PDT
Pydev
Android Plugin for Eclipse.
A quick updaty by the plugin dev would be great.
Thanks!
Pascal
Re: VE 1.4 and Eclipse 3.6 [message #618408 is a reply to message #618403] Thu, 01 July 2010 21:41 Go to previous messageGo to next message
I'm having the same issue using Helios EE. Build id: 20100617-1415
> Missing requirement: Visual Editor Java Core 1.4.0.v20090826-1446 (org.eclipse.ve.java.core 1.4.0.v20090826-1446) requires 'bundle com.ibm.icu [3.4.4.1,4.1.0)' but it could not be found
> To: org.eclipse.ve.java.core [1.4.0.v20090826-1446]
I really don't want to write this GUI by hand. Please help!
Re: VE 1.4 and Eclipse 3.6 [message #618409 is a reply to message #618408] Mon, 05 July 2010 02:07 Go to previous messageGo to next message
Same problem here. Trying to install VE 1.4 in Eclipse 3.6 Helios Build id: 20100617-1415 (a fresh install of Eclipse IDE for Java Developers, not EE version).
Like others, I have followed the steps outlined in the VE Wiki to the letter, but have the same problem.
I have had similar problems with 3.5 Galileo. I was advised at the time to just install VE SDK and none of the other options, but that never worked for me either.
As mentioned in other posts / forums, there seems to be a dependency around Java EMF. What conflict actually exists? Did
EMF break backwards compatibility? Why does it seem that a specific EMF version is required rather than a more generic >= N ?
Re: VE 1.4 and Eclipse 3.6 [message #618410 is a reply to message #618403] Mon, 05 July 2010 04:40 Go to previous messageGo to next message
i just downloaded the ve plug-in. copied it to my plugins-folder and the modified the MANIFEST.MF of each single plug-in, removing the version information of the required bundles.
Works fine for me now :)
greetings,
Ben
Re: VE 1.4 and Eclipse 3.6 [message #618412 is a reply to message #618403] Tue, 06 July 2010 07:55 Go to previous messageGo to next message
Hi kit,
jar files are in fact just normal .zip files.
I am using Total Commander for example with a plug-in that handles .jar files as zip files. So i open it, edit the MANIFEST.MF in it and pack it back in.
It's that simple :)
greetz,
Ben
Re: VE 1.4 and Eclipse 3.6 [message #618413 is a reply to message #618403] Thu, 08 July 2010 00:13 Go to previous messageGo to next message
The build for Helios is ongoing. It will be available soon.
Best regards
Yves YANG
"Chris" wrote in message
news:i05njj$ho2$1@build.eclipse.org...
> Hi!
> Chris
> Dependency error:
> Quote:
>> Only one of the following can be installed at once: International
>> 4.2.1.v20100412)
[Updated on: Mon, 19 November 2012 09:00] by Moderator
Re: VE 1.4 and Eclipse 3.6 [message #618420 is a reply to message #618403] Mon, 09 August 2010 04:18 Go to previous messageGo to next message
On this page
http://www.eclipse.org/projects/project-plan.php?projectid=t ools.ve
i see VE 1.5 was released on 06/28/2010.
Under "Release Deliverables" i see "..Project runtime binary features on eclipse.org update site (install via Eclipse update manager)..."
I think this is not true, because there is NO url with new VE 1.5.
So where can i download released VE 1.5??
Re: VE 1.4 and Eclipse 3.6 [message #618426 is a reply to message #618412] Thu, 19 August 2010 10:33 Go to previous messageGo to next message
Hi!
Thanks for Ben, I was able to install VE1.4 on Helios.
And it seems to be working fine for me too.
If there is a person who want to try the plugins that I modified, please look at http://sourceforge.jp/projects/tmdmaker/wiki/VisualEditor1.4 .0ForHelios
By the way,
".jar.pack.gz" can extract $JAVA_HOME/bin/unpack200 .
Thank you for your time.
Re: VE 1.4 and Eclipse 3.6 [message #618427 is a reply to message #618403] Tue, 24 August 2010 13:18 Go to previous messageGo to next message
Hiya nakag,
I downloaded, installed and (quickly) tried your setup... and it seems to work!!!
Thanks for the good work
- Colargol
Re: VE 1.4 and Eclipse 3.6 [message #618428 is a reply to message #618427] Wed, 25 August 2010 07:50 Go to previous messageGo to next message
thanks,
it seem to run on
Eclipse Java EE IDE for Web Developers.
Version: Helios Release
Herman
Re: VE 1.4 and Eclipse 3.6 [message #618429 is a reply to message #618428] Fri, 27 August 2010 05:51 Go to previous messageGo to next message
hi,
winxp is o.k.,
but there are problems on linux (sidux,debian 64 bit):
with openjdk, the controls are missplaced
with sun jdk, there is a runtime-error opening forms
but this problems are the same on eclipse 3.5.x since a few month ago
hermann
Re: VE 1.4 and Eclipse 3.6 [message #618430 is a reply to message #618429] Fri, 27 August 2010 19:48 Go to previous messageGo to next message
The environment i modified VE1.4 is winxp.
For other platform, you might have to modified VE1.4 for yourself, following procedures. (written in japanese is http://d.hatena.ne.jp/nakaG/20100819#1282225964)
1. Install VE1.4 to eclipse galileo from updatesite.
2. Take VE1.4's features and plugins out of the installation features and plugins folder.
3. Extract plugin jar files.
4. Remove '; bundle-version = "[3.8.1.1, 4.1.0)"' from com.ibm.icu written in Require-Bundle of MANIFEST.MF.
5. Remove eclipse.inf, ECLIPSEF.RSA, ECLIPSEF.SF from META-INF folder.
6. Compress it again. (You can use jar command or zip archiver.)
7. Drop it on dropins folder.
You will have to modify the following files.
org.eclipse.jem.util_2.0.200.R3_1_maintenance.jar
org.eclipse.ve.cde_1.4.0.v20090826-1446.jar
org.eclipse.ve.java.core_1.4.0.v20090826-1446.jar
org.eclipse.ve.jfc_1.4.0.v20090826-1446.jar
org.eclipse.ve.propertysheet_1.4.0.v20090826-1446.jar
org.eclipse.ve.swt_1.4.0.v20090826-1446.jar
If you fail to install VE1.4 to galileo, i have no idea...
Thanks for reading my poor English.
Re: VE 1.4 and Eclipse 3.6 [message #630198 is a reply to message #618430] Fri, 01 October 2010 00:26 Go to previous messageGo to next message
On linux (Fedora 13) same problem here, can't get Visual Editor 1.4 to work with these versions of Eclipse :
eclipse-3.5.2-galileo-java
eclipse-3.6.1-helios-cpp
eclipse-3.6.1-helios-java_ee
eclipse-3.5.2-galileo-java_ee
eclipse-3.6-helios-classic_SDK
icon14.gif  Re: VE 1.4 and Eclipse 3.6 [message #631821 is a reply to message #618426] Fri, 08 October 2010 17:57 Go to previous messageGo to next message
I installed this following the instructions on your web page and it works perfectly. Thank you for taking the time to make this available.
Re: VE 1.4 and Eclipse 3.6 [message #631826 is a reply to message #630198] Fri, 08 October 2010 19:20 Go to previous message
Hello.
If VE1.4 installed onto galileo from updatesite didn't work,
it may not work well even if you modify VE1.4 by yourself only the same way that I did.
It seems that it is a problem of VE1.4.
Then, I think that you should try VE1.4 on this page,
if you have not done yet.
It might have to be modified by yourself the same way I did.
[Updated on: Fri, 08 October 2010 19:38] by Moderator
Previous Topic:Installing VE
Next Topic:problem with an unavailable file
Current Time: Fri Nov 07 12:00:43 EST 2025
Powered by FUDForum. Page generated in 0.05887 seconds
