Error installing VE with Update Manager [message #618367] |
Sat, 20 February 2010 09:20  |
I have just installed Eclipse in Ubuntu 9.10 using "apt-get install eclipse".
When I try to install VE through the Update Manager with the URL
http://download.eclipse.org/tools/ve/updates/1.4/
and selecting all the features of the build I get the following error:
Cannot complete the install because one or more required items could not be found.
Software being installed: Java EMF Model 1.4.0.v20090826-1446-7H-FPbAcggQleH8hJifHfUd (org.eclipse.jem.feature.group 1.4.0.v20090826-1446-7H-FPbAcggQleH8hJifHfUd)
Missing requirement: Java EMF Model 1.4.0.v20090826-1446-7H-FPbAcggQleH8hJifHfUd (org.eclipse.jem.feature.group 1.4.0.v20090826-1446-7H-FPbAcggQleH8hJifHfUd) requires 'org.eclipse.emf.ecore.xmi [2.4.0,3.0.0)' but it could not be found
Does anybody know how to fix this?
Re: Error installing VE with Update Manager [message #618368 is a reply to message #618367] |
Sat, 20 February 2010 17:48  |
You need to get org.eclipse.emf. That's a separate set of features than
VE. Have you hit the "Select required" button in the update manager?
That should look through all of your update sites to find EMF. Typically
it is the update site labeled Ganyemede, or Callisto, or whatever the
one that is current for your installation version of Eclipse. When in
the update manager select both this update site I just mentioned and the
VE update site, then go on. When you then select the VE feature that
want installed and you get this error hit the "Select required" button
and it should look in the other site to find the EMF features it needs.
Krige wrote:
> Hello,
> eclipse".
> be found.
Rich Kulp
FUDForum. Page generated in 0.07034 seconds
