Home » Archived » Eclipse Communications Framework (ECF) » ECF setup and version
ECF setup and version [message #618306] Sun, 29 April 2007 06:26 Go to next message
Originally posted by: zhouziyu113.yahoo.com.cn
hello everyone
i am a newbie in ecf, i have installed eclipse sdk 3.3m6, and then i
install ecf dev build April 28, but they don't work, i don't found the
questiion, any one who can help me....
is the eclipse version or ecf version don't compatible or others...
thanks.
Re: ECF setup and version [message #618513 is a reply to message #618306] Sun, 29 April 2007 16:29 Go to previous messageGo to next message
Scott Lewis is currently offline Scott LewisFriend
Hi Given,
Perhaps it's installed and you aren't seeing it. Are you able to open
the "Communications" perspective? Also...when you choose Help->About
Eclipse SDK->Plugin Details do you see the plugin with name "ECF Core
API" listed in the list?
If you are seeing these, but things don't work are you seeing any
errors. If so, what?
Scott
given wrote:
> hello everyone i am a newbie in ecf, i have installed eclipse sdk
> 3.3m6, and then i install ecf dev build April 28, but they don't work, i
> don't found the questiion, any one who can help me....
> thanks.
Re: ECF setup and version [message #618515 is a reply to message #618513] Mon, 30 April 2007 01:35 Go to previous message
Hi Scoot:
thank you for you time looking at this question.
I have seen both the communication perspective and plugin deatails. in plugin details list,the item about ECF signed red folk, but under the communication perspective it works well.
thank you very much!
Previous Topic:ECF dev build 4.28.2007
Next Topic:ECF dev build 5.1.07
Current Time: Tue Apr 16 15:56:51 GMT 2024
Powered by FUDForum. Page generated in 0.08554 seconds
