Home » Eclipse Projects » Dali » Problem with generating entity from table
Problem with generating entity from table [message #617643] Mon, 02 November 2009 01:48 Go to next message
Ludovic  is currently offline Ludovic Friend
I am creating a project in galileo, with dali 2.2. I also use EclipseLink and Glassfish as a server. The project is jpa enabled, with a pesistence.xml file. I use the wizard to generate the entities from tables.
I may see the tables of my schema in the wizard. In fact everything goes fine up to the finish.
The only thing is that no code is generated and I can't find any message of why it failed.
Any help would be appreciated. If it's not the right place to ask, don't hesitate to tell me.
thanks
Ludovic
Re: Problem with generating entity from table [message #617668 is a reply to message #617643] Thu, 05 November 2009 17:25 Go to previous messageGo to next message
Neil Hauge is currently offline Neil HaugeFriend
Please open the Error Log view and report any errors that might have been logged on the Finish. I'm guessing that there is something being sent to the log that might help us diagnose the problem.
Neil
Re: Problem with generating entity from table [message #617672 is a reply to message #617668] Fri, 06 November 2009 03:50 Go to previous message
yes there is this exception:
> org.eclipse.core.runtime.CoreException: Unable to find JPA entities generation templates in pluginorg.eclipse.jpt.gen
> at org.eclipse.jpt.gen.internal2.PackageGenerator2.generateClas s(PackageGenerator2.java:202)
> at org.eclipse.jpt.gen.internal2.PackageGenerator2.generateInte rnal(PackageGenerator2.java:112)
> at org.eclipse.jpt.gen.internal2.PackageGenerator2.doGenerate(P ackageGenerator2.java:92)
> at org.eclipse.jpt.gen.internal2.PackageGenerator2.generate(Pac kageGenerator2.java:73)
> at org.eclipse.jpt.ui.internal.wizards.gen.GenerateEntitiesFrom SchemaWizard$GenerateEntitiesJob.runInWorkspace(GenerateEnti tiesFromSchemaWizard.java:254)
> at org.eclipse.core.internal.resources.InternalWorkspaceJob.run (InternalWorkspaceJob.java:38)
> at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
> Caused by: java.lang.NoSuchMethodError: org.apache.log4j.Logger.debug(Ljava/lang/Object;Ljava/lang/T hrowable;)V
> at org.apache.velocity.runtime.log.Log4JLogChute.log(Log4JLogCh ute.java:183)
> at org.apache.velocity.runtime.log.HoldingLogChute.transferTo(H oldingLogChute.java:115)
> at org.apache.velocity.runtime.log.LogManager.updateLog(LogMana ger.java:216)
> at org.apache.velocity.runtime.RuntimeInstance.initializeLog(Ru ntimeInstance.java:728)
> at org.apache.velocity.runtime.RuntimeInstance.init(RuntimeInst ance.java:240)
> at org.apache.velocity.runtime.RuntimeInstance.init(RuntimeInst ance.java:534)
> at org.apache.velocity.app.VelocityEngine.init(VelocityEngine.j ava:144)
> at org.eclipse.jpt.gen.internal2.PackageGenerator2.generateClas s(PackageGenerator2.java:188)
> ... 6 more
it seems that the log4j jar is missing. Is it at the plugin level?
thanks
Ludovic
Previous Topic:Validating OneToMany references to composite key components
Next Topic:Extensibility of GenerateEntityWizard and GenerateEntityFromShemaWizard
Current Time: Sun Mar 29 12:54:40 GMT 2020
Powered by FUDForum. Page generated in 0.02324 seconds
