Home » Eclipse Projects » Dali » IllegalStateException thrown by Dali
IllegalStateException thrown by Dali [message #617627] Fri, 16 October 2009 17:19 Go to next message
Dan  is currently offline Dan Friend
Using Dali, I created entities from the database tables and renamed most of the fields from a "database" name to a "java" name. Everything worked fine without issues.
However, the DBA added several tables and removed several others. The next time I ran the 'entities from tables' wizard again, I get the exception below and the wizard doesn't move past the first page.
I'm guessing that it's because the entitygen cache file (in .settings) has references to tables to that do not exist anymore. Is there any way I can hack on the file to remove the references?
Dan
EXCEPTION:
java.lang.IllegalStateException
at java.util.AbstractList$Itr.remove(AbstractList.java:356)
at org.eclipse.jpt.gen.internal2.ORMGenCustomizer.addForeignKey Associations(ORMGenCustomizer.java:693)
at org.eclipse.jpt.gen.internal2.ORMGenCustomizer.addForeignKey Associations(ORMGenCustomizer.java:643)
at org.eclipse.jpt.gen.internal2.ORMGenCustomizer.getAssociatio ns(ORMGenCustomizer.java:619)
at org.eclipse.jpt.gen.internal2.ORMGenCustomizer.getAssociatio ns(ORMGenCustomizer.java:419)
at org.eclipse.jpt.ui.internal.wizards.gen.TableAssociationsWiz ardPage.updateAssociationsListPanel(TableAssociationsWizardP age.java:562)
at org.eclipse.jpt.ui.internal.wizards.gen.TableAssociationsWiz ardPage.setVisible(TableAssociationsWizardPage.java:290)
at org.eclipse.jface.wizard.WizardDialog.updateForPage(WizardDi alog.java:1171)
at org.eclipse.jface.wizard.WizardDialog.access$2(WizardDialog. java:1149)
at org.eclipse.jface.wizard.WizardDialog$5.run(WizardDialog.jav a:1138)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:70)
at org.eclipse.jface.wizard.WizardDialog.showPage(WizardDialog. java:1136)
at org.eclipse.jface.wizard.WizardDialog.nextPressed(WizardDial og.java:830)
at org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDi alog.java:369)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.jav a:624)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:228)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1176)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3493)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3112)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:825 )
at org.eclipse.jface.window.Window.open(Window.java:801)
at org.eclipse.jpt.ui.internal.platform.base.EntitiesGenerator2 .generate(EntitiesGenerator2.java:64)
at org.eclipse.jpt.ui.internal.platform.base.EntitiesGenerator2 .generate(EntitiesGenerator2.java:39)
at org.eclipse.jpt.ui.internal.platform.base.BaseJpaPlatformUi. generateEntities(BaseJpaPlatformUi.java:288)
at org.eclipse.jpt.ui.internal.actions.GenerateEntitiesAction.e xecute(GenerateEntitiesAction.java:24)
at org.eclipse.jpt.ui.internal.actions.ProjectAction.execute(Pr ojectAction.java:87)
at org.eclipse.jpt.ui.internal.actions.ProjectAction.execute(Pr ojectAction.java:63)
at org.eclipse.jpt.ui.internal.actions.ProjectAction.run(Projec tAction.java:55)
at org.eclipse.ui.internal.PluginAction.runWithEvent(PluginActi on.java:251)
at org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:584)
at org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:501)
at org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:411)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2405)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2369)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 21)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:500)
at org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:493)
at org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:194)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:368)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 559)
at org.eclipse.equinox.launcher.Main.main(Main.java:1287)
Re: IllegalStateException thrown by Dali [message #617631 is a reply to message #617627] Tue, 20 October 2009 15:02 Go to previous messageGo to next message
Created bug https://bugs.eclipse.org/bugs/show_bug.cgi?id=292773 It's a really easy fix - add a break after line 693 in ORMGenCustomizer.
Re: IllegalStateException thrown by Dali [message #617635 is a reply to message #617631] Tue, 20 October 2009 15:23 Go to previous message
Karen Butzke is currently offline Karen ButzkeFriend
Thanks for entering the bug, sorry for the delayed reply.
Karen
Previous Topic:Is it possible to configure Dali
Next Topic:Validating OneToMany references to composite key components
Current Time: Wed Apr 08 09:42:25 GMT 2020
Powered by FUDForum. Page generated in 0.01927 seconds
