VE and JBoss [message #616964] |
Mon, 11 February 2008 15:32 |
Originally posted by: potmypayola.hotmail.com
i have used VE to develop a stand-alone application and now want to add J2EE functionalities.
The problem is that after installing the JBoss Tools and WST as required VE stops working!!!, configuration looks ok, everything enable, but none the workbench can be restored nor the editor descriptor can be found.
My knowledge of Eclipse is very limited but i really need to sort this out but have no clue how to so, if someone can point me out to any solution or how to find out more about this problem i will truly appreciate it.
Thank you.
Here are the log entries:
!SESSION 2008-02-11 15:16:44.996 -----------------------------------------------
eclipse.buildId=I20070625-1500
java.version=1.6.0
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_GB
Command-line arguments: -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.ui 4 0 2008-02-11 15:17:09.105
!MESSAGE Unable to create editor ID org.eclipse.ve.internal.java.codegen.editorpart.Ja vaVisualEditor: No editor descriptor for id org.eclipse.ve.internal.java.codegen.editorpart.Ja vaVisualEditor
!STACK 1
org.eclipse.ui.PartInitException: No editor descriptor for id org.eclipse.ve.internal.java.codegen.editorpart.Ja vaVisualEditor
at org.eclipse.ui.internal.EditorReference.createPart Helper(EditorReference.java:598)
at org.eclipse.ui.internal.EditorReference.createPart (EditorReference.java:426)
at org.eclipse.ui.internal.WorkbenchPartReference.get Part(WorkbenchPartReference.java:592)
at org.eclipse.ui.internal.EditorReference.getEditor( EditorReference.java:263)
at org.eclipse.ui.internal.EditorManager.findEditor(E ditorManager.java:398)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEdit orBatched(WorkbenchPage.java:2670)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEdit or(WorkbenchPage.java:2633)
at org.eclipse.ui.internal.WorkbenchPage.access$12(Wo rkbenchPage.java:2625)
at org.eclipse.ui.internal.WorkbenchPage$10.run(Workb enchPage.java:2577)
at org.eclipse.swt.custom.BusyIndicator.showWhile(Bus yIndicator.java:67)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(W orkbenchPage.java:2572)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(W orkbenchPage.java:2556)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(W orkbenchPage.java:2547)
at org.eclipse.jdt.internal.ui.javaeditor.EditorUtili ty.openInEditor(EditorUtility.java:298)
at org.eclipse.jdt.internal.ui.javaeditor.EditorUtili ty.openInEditor(EditorUtility.java:172)
at org.eclipse.jdt.ui.actions.OpenAction.run(OpenActi on.java:194)
at org.eclipse.jdt.ui.actions.OpenAction.run(OpenActi on.java:175)
at org.eclipse.jdt.ui.actions.SelectionDispatchAction .dispatchRun(SelectionDispatchAction.java:268)
at org.eclipse.jdt.ui.actions.SelectionDispatchAction .run(SelectionDispatchAction.java:244)
at org.eclipse.jdt.internal.ui.packageview.PackageExp lorerActionGroup.handleOpen(PackageExplorerActionG roup.java:316)
at org.eclipse.jdt.internal.ui.packageview.PackageExp lorerPart$5.open(PackageExplorerPart.java:613)
at org.eclipse.jface.viewers.StructuredViewer$2.run(S tructuredViewer.java:820)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner .java:37)
at org.eclipse.core.runtime.Platform.run(Platform.jav a:857)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil. java:46)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnab le.java:193)
at org.eclipse.jface.viewers.StructuredViewer.fireOpe n(StructuredViewer.java:818)
at org.eclipse.jface.viewers.StructuredViewer.handleO pen(StructuredViewer.java:1079)
at org.eclipse.jface.viewers.StructuredViewer$6.handl eOpen(StructuredViewer.java:1183)
at org.eclipse.jface.util.OpenStrategy.fireOpenEvent( OpenStrategy.java:263)
at org.eclipse.jface.util.OpenStrategy.access$2(OpenS trategy.java:257)
at org.eclipse.jface.util.OpenStrategy$1.handleEvent( OpenStrategy.java:297)
at org.eclipse.swt.widgets.EventTable.sendEvent(Event Table.java:66)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.ja va:938)
at org.eclipse.swt.widgets.Display.runDeferredEvents( Display.java:3682)
at org.eclipse.swt.widgets.Display.readAndDispatch(Di splay.java:3293)
at org.eclipse.ui.internal.Workbench.runEventLoop(Wor kbench.java:2389)
at org.eclipse.ui.internal.Workbench.runUI(Workbench. java:2353)
at org.eclipse.ui.internal.Workbench.access$4(Workben ch.java:2219)
at org.eclipse.ui.internal.Workbench$4.run(Workbench. java:466)
at org.eclipse.core.databinding.observable.Realm.runW ithDefault(Realm.java:289)
at org.eclipse.ui.internal.Workbench.createAndRunWork bench(Workbench.java:461)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(Pl atformUI.java:149)
at org.eclipse.ui.internal.ide.application.IDEApplica tion.start(IDEApplication.java:106)
at org.eclipse.equinox.internal.app.EclipseAppHandle. run(EclipseAppHandle.java:153)
at org.eclipse.core.runtime.internal.adaptor.EclipseA ppLauncher.runApplication(EclipseAppLauncher.java: 106)
at org.eclipse.core.runtime.internal.adaptor.EclipseA ppLauncher.start(EclipseAppLauncher.java:76)
at org.eclipse.core.runtime.adaptor.EclipseStarter.ru n(EclipseStarter.java:363)
at org.eclipse.core.runtime.adaptor.EclipseStarter.ru n(EclipseStarter.java:176)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Nativ e Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Native MethodAccessorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(De legatingMethodAccessorImpl.java:25)
at org.eclipse.equinox.launcher.Main.invokeFramework( Main.java:504)
at org.eclipse.equinox.launcher.Main.basicRun(Main.ja va:443)
at org.eclipse.equinox.launcher.Main.run(Main.java:11 69)
!SUBENTRY 1 org.eclipse.ui 4 0 2008-02-11 15:17:09.121
!MESSAGE No editor descriptor for id org.eclipse.ve.internal.java.codegen.editorpart.Ja vaVisualEditor
!ENTRY org.eclipse.jface 4 2 2008-02-11 15:17:09.136
!MESSAGE Problems occurred when invoking code from plug-in: "org.eclipse.jface".
!STACK 0
org.eclipse.core.runtime.AssertionFailedException: null argument:
at org.eclipse.core.runtime.Assert.isNotNull(Assert.j ava:84)
at org.eclipse.core.runtime.Assert.isNotNull(Assert.j ava:72)
at org.eclipse.ui.internal.EditorSite.<init>(EditorSi te.java:46)
at org.eclipse.ui.internal.EditorReference.createPart (EditorReference.java:463)
FUDForum. Page generated in 0.03697 seconds
