pdt debugger object inspection [message #62257] |
Fri, 07 December 2007 00:38 |
Originally posted by: mat.mad.id.au
Hi.
Just stumbled across PDT. Thanks guys! Nice work!
Look I just wanted to mention something obvious which you have probably
heard already. How about being able to inspect an object in the debugger?
ie. drill down into the properties of the object. Right now all you get in
the variables window in the debugger for an object is the object type.
I'm using xdebug with apache in windows.
Re: pdt debugger object inspection [message #62305 is a reply to message #62257] |
Fri, 07 December 2007 08:47 |
Originally posted by: eclipse-news.mark-kirchner.de
> debugger? ie. drill down into the properties of the object. Right now
> all you get in the variables window in the debugger for an object is the
> object type.
Hm, no. At least in my installation in the variables- and the
expressions-view there is this little "+"-icon on the left side of the
variable-name (for objects, arrays and stuff like that). Clicking on it
expands it and shows object-properties / contents of the array.
HTH,
Mark
Re: pdt debugger object inspection [message #62353 is a reply to message #62305] |
Fri, 07 December 2007 13:06 |
Thanks! You're right - I can inspect for example a HttpRequest. Strangely,
I'm not able to inspect any of the DOM* classes (DOMXPath, DOMDocument,
DOMNodeList).
FUDForum. Page generated in 0.03237 seconds
