Home » Archived » Service Oriented Architecture Tools Platform (STP) » EContentAdapter behavior
EContentAdapter behavior [message #616697] Wed, 13 August 2008 13:31 Go to next message
Till Essers is currently offline Till EssersFriend
Member
Don't know if this behavior I'm discovering comes from emf or the
stp.bpmn modeler, so I'm posting in both newsgroups.
I'm using an EContentAdapter to get notified when objects are added or
removed from the bpmn diagram. It's working fine when adding objects.
case Notification.ADD:
Object obj = notification.getNotifier();
if(obj instanceof NodeImpl)
if(((NodeImpl)obj).getElement() instanceof Activity)
As you can see I'm just looking what kind of object has been added to
the diagram. In this case we have an Activity.
I'm doing the same on adding SequenceEdge.
But when it comes to removing objects, I'm pretty curios about those
objects passed around. When I'm removing a Connection for example, I get
2 remove notifications for the objects connected through this
SequenceEdge, but none for the SequenceEdge itself. Even though, when
deleting a flow object from the diagram, I'm not receiving a
notification for it.
Am I doing anything wrong? Or is the removed object not stored in the
element?
Sorry for asking, but I couldn't find any documentation about the
notifications passed around.
Thanks in advance
Till
Re: EContentAdapter behavior [message #616698 is a reply to message #616697] Wed, 13 August 2008 13:46 Go to previous messageGo to next message
Till,
Comments below.
Till Essers wrote:
> Hi
I don't imagine you should be using Impl classes in your instanceof
tests. Why aren't you using the "Node" API for testing?
> get 2 remove notifications for the objects connected through this
Note that when an object is removed from the tree, the adapter itself is
removed from that object and from all contained children of it. The
REMOVING_ADAPTER notification will occur for those.
> Even though, when deleting a flow object from the diagram, I'm not
> receiving a notification for it.
Note also that notifications about deletion generally happen for the
containment feature of the parent not directly on the deleted object
itself (though the adapter is removed so you can detect that).
I'm not sure. Hopefully you're calling super in your overrides so that
the normal processing happens as well...
> Or is the removed object not stored in the element?
I'm not sure what happens in this combination of diagram model and
domain model...
Generally a notification is fired by an EObject whenever the value of
one of it's features changes...
> Thanks in advance
> Till
Ed Merks
Re: EContentAdapter behavior [message #616699 is a reply to message #616698] Wed, 13 August 2008 14:38 Go to previous messageGo to next message
Member
Ed Merks schrieb:
> Till,
> Comments below.
Sure, changed this one ;)
Okay, that may change some things...
Which would explain why I got a notification telling me to delete the
task, note the connection.
Sure, the first call is the super call.
> domain model...
I'm absolutly unsure what happens... When the ADD notifier is called, I
get a Node containing the new object as the element.
When the REMOVING_ADAPTER notifier is called I get a Node containing
null as the element.
I don't know how I should know which object in the diagram is removed.
Is it possible, that the super call sets the element of the node to null?
Thanks so far
Till
Re: EContentAdapter behavior [message #616700 is a reply to message #616699] Wed, 13 August 2008 14:50 Go to previous messageGo to next message
Till,
Are you listening to just the diagram resource or also the resource
containing the model? I'm assuming they're in different resources, but
that might be a wrong assumption. It sounds like delete is cleaning up
the node, but I would have imagined you'd have seen a notification that
the node's element was being SET to null...
Till Essers wrote:
> Ed Merks schrieb:
>> Till,
>> Comments below.
>> is removed from that object and from all contained children of it.
>> The REMOVING_ADAPTER notification will occur for those.
>> that the normal processing happens as well...
>> domain model...
> I get a Node containing the new object as the element.
> Thanks so far
> Till
Ed Merks
Re: EContentAdapter behavior [message #616701 is a reply to message #616700] Wed, 13 August 2008 15:01 Go to previous messageGo to next message
Member
Don't know what I am listening to, I just called:
editor.getDiagram().eAdapters().add(adapter);
to add my EContentAdapter.
Ok, I think I've found out what I have to do:
I have to listen to the REMOVE notification,
then test on the old value, not the notifier. Doing this I can see the
element being removed from the node before the adapter is removed from
the node.
Hopefully it's just called when the element is removed... otherwise I
would run into trouble again :D
Tricky thing this EContentAdapter...
Ed Merks schrieb:
> Till,
Re: EContentAdapter behavior [message #616702 is a reply to message #616701] Wed, 13 August 2008 15:23 Go to previous message
Member
As I thought... I'm running into trouble again...
Removing an Activity from the diagram works the way mentioned before.
Removing a SquenceEdge doesn't work this way. I'm getting pretty mad
about this, there has to be a way doing it for all those BPMN objects
the same way.
Till
Till Essers schrieb:
> Hi
> the node.
> Thanks
> Ed Merks schrieb:
>> Till,
>> but that might be a wrong assumption. It sounds like delete is
>> cleaning up the node, but I would have imagined you'd have seen a
>> notification that the node's element was being SET to null...
Previous Topic:Creating a new Diagram
Next Topic:Re: EContentAdapter behavior
Current Time: Sun Jan 17 12:17:46 GMT 2021
Powered by FUDForum. Page generated in 0.02402 seconds
