Re: [ATL] Error injecting KM3 with Ant [message #62245 is a reply to message #62220] |
Sat, 22 September 2007 22:48 |
Lorenzo Dalla Vecchia Messages: 58 Registered: July 2009 |
Member |
You were right, I totally forgot to load the KM3 metamodel itself.
However there is still a problem with the following new code:
<target name="inject">
<am3.loadModel modelHandler="EMF" name="KM3"
nsUri="http://www.eclipse.org/gmt/2005/KM3"
metamodel="MOF" />
<am3.loadModel modelHandler="EMF" name="${model}"
path="${model}.km3" metamodel="KM3">
<injector name="ebnf">
<param name="name" value="KM3" />
</injector>
</am3.loadModel>
<am3.saveModel model="${model}" path="${model}.ecore" />
</target>
Unlike Ecore files produced by the Eclipse plugin, the resulting Ecore file
does not use the namespace http://www.eclipse.org/emf/2002/Ecore and
elements like eClass, eAttribute but the KM3 namespace
(http://www.eclipse.org/gmt/2005/KM3) and different elements like Metamodel
and Contents, thus making it incompatible with other EMF tools.
I'm sure that there is a simple way of fixing this problem, maybe adding
another injector parameter... Sorry, I'm a bit newbie with these tools.
Regards.
Lorenzo
"Frédéric Jouault" <frederic.jouault@univ-nantes.fr> ha scritto nel
messaggio news:fd3ari$g9f$1@build.eclipse.org...
> Hello,
> Did you load the KM3 metamodel in Ecore format (e.g., KM3.ecore, or
> better, nsURI="http://www.eclipse.org/gmt/2005/KM3") before loading the
> KM3 model?
> Regards,
> Frédéric Jouault
> Lorenzo Dalla Vecchia wrote:
>> Hello again.
>> To automate the build process of my project I created an Ant script to
>> inject a KM3 meta-model into the corrensponding EMF (Ecore) meta-model,
>> and ran it from Eclipse.
>> I'm using the following Ant target, almost cut-n-pasted from the wiki:
>> <!-- MODEL INJECTION -->
>> <am3.loadModel name="${model}" path="${model}.km3"
>> metamodel="KM3" modelHandler="EMF">
>> </injector>
>> </am3.loadModel>
>> </target>
>> ${model} is a Ant property set to the model name without extension (the
>> .km3 file is correctly found).
>> When running the Ant task I get the following:
>> inject:
>> [am3.loadModel] GRAVE: no type named 'Metamodel' in metamodel 'ModelName'
>> [am3.loadModel] java.lang.NullPointerException
>> [am3.loadModel] at
>> org.eclipse.m2m.atl.drivers.emf4atl.ASMEMFModel.newModelElem ent(ASMEMFModel.java:185)
>> [am3.loadModel] at
>> org.eclipse.m2m.atl.engine.vm.nativelib.ASMModel.newModelEle ment(ASMModel.java:76)
>> [am3.loadModel] at
>> org.eclipse.m2m.atl.engine.vm.nativelib.ASMModel.newModelEle ment(ASMModel.java:62)
>> [am3.loadModel] at
>> org.atl.engine.injectors.ebnf.ASMModelHandler.createElement( ASMModelHandler.java:89)
>> [am3.loadModel] at
>> org.atl.engine.injectors.ebnf.EBNFInjector2.create(EBNFInjec tor2.java:301)
>> [am3.loadModel] at
>> org.atl.engine.injectors.ebnf.KM3_ANTLR3Parser.metamodel(KM3 _ANTLR3Parser.java:318)
>> [am3.loadModel] at
>> org.atl.engine.injectors.ebnf.KM3_ANTLR3Parser.main(KM3_ANTL R3Parser.java:117)
>> [am3.loadModel] at sun.reflect.NativeMethodAccessorImpl.invoke0(Native
>> Method)
>> [am3.loadModel] at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown
>> Source)
>> [am3.loadModel] at
>> sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
>> [am3.loadModel] at java.lang.reflect.Method.invoke(Unknown Source)
>> [am3.loadModel] at
>> org.eclipse.gmt.tcs.wrappers.antlr3.ParserWrapper.parse(Pars erWrapper.java:69)
>> [am3.loadModel] at
>> org.atl.engine.injectors.ebnf.EBNFInjector2.performImportati on(EBNFInjector2.java:253)
>> [am3.loadModel] at
>> org.atl.engine.injectors.ebnf.EBNFInjector2.performImportati on(EBNFInjector2.java:213)
>> [am3.loadModel] at
>> org.atl.engine.injectors.ebnf.EBNFInjector2.performImportati on(EBNFInjector2.java:162)
>> [am3.loadModel] at
>> org.atl.engine.injectors.ebnf.EBNFInjector2.inject(EBNFInjec tor2.java:92)
>> [am3.loadModel] at
>> org.eclipse.gmt.am3.tools.ant.toolkit.AM3AntToolKit.ebnfInje ction(AM3AntToolKit.java:256)
>> [am3.loadModel] at
>> org.eclipse.gmt.am3.tools.ant.toolkit.AM3AntToolKit.ebnfInje ction(AM3AntToolKit.java:273)
>> [am3.loadModel] at
>> org.eclipse.gmt.am3.tools.ant.toolkit.AM3AntToolKit.inject(A M3AntToolKit.java:281)
>> [am3.loadModel] at
>> org.eclipse.gmt.am3.tools.ant.tasks.LoadModelTask.execute(Lo adModelTask.java:62)
>> [am3.loadModel] at
>> org.apache.tools.ant.UnknownElement.execute(UnknownElement.j ava:275)
>> [am3.loadModel] at org.apache.tools.ant.Task.perform(Task.java:364)
>> [am3.loadModel] at org.apache.tools.ant.Target.execute(Target.java:341)
>> [am3.loadModel] at
>> org.apache.tools.ant.Target.performTasks(Target.java:369)
>> [am3.loadModel] at
>> org.apache.tools.ant.Project.executeSortedTargets(Project.ja va:1216)
>> [am3.loadModel] at
>> org.apache.tools.ant.Project.executeTarget(Project.java:1185 )
>> [am3.loadModel] at
>> org.apache.tools.ant.helper.DefaultExecutor.executeTargets(D efaultExecutor.java:40)
>> [am3.loadModel] at
>> org.eclipse.ant.internal.core.ant.EclipseDefaultExecutor.exe cuteTargets(EclipseDefaultExecutor.java:32)
>> [am3.loadModel] at
>> org.apache.tools.ant.Project.executeTargets(Project.java:106 8)
>> [am3.loadModel] at
>> org.eclipse.ant.internal.core.ant.InternalAntRunner.run(Inte rnalAntRunner.java:706)
>> [am3.loadModel] at
>> org.eclipse.ant.internal.core.ant.InternalAntRunner.run(Inte rnalAntRunner.java:457)
>> Method)
>> Source)
>> [am3.loadModel] at
>> [am3.loadModel] at
>> org.eclipse.ant.core.AntRunner.run(AntRunner.java:356)
>> [am3.loadModel] at
>> org.eclipse.ant.internal.ui.launchConfigurations.AntLaunchDe legate$1.run(AntLaunchDelegate.java:230)
>> [am3.loadModel] at java.lang.Thread.run(Unknown Source)
>> [am3.saveModel] INFO: Saving model WebML
>> BUILD SUCCESSFUL
>> Total time: 163 milliseconds
>> Although it says "build successful", the resulting Ecore file is empty
>> and therefore not valid.
>> What does "no type named 'Metamodel' in metamodel 'ModelName'" mean? I'm
>> sure the KM3 file is syntax-correct and I can inject it successfully
>> using the context-menu command provided by the ATL Eclipse plugin.
>> Thank you in advance.
>> Lorenzo
Re: [ATL] Error injecting KM3 with Ant [message #62268 is a reply to message #62245] |
Sun, 23 September 2007 16:17 |
Originally posted by: mikael.barbero.gmail.com
Hi Lorenzo,
After the injection of your .km3 file, you get a KM3 model (M1 level),
conforming to the KM3 metamodel (M2 level), itself conforming to Ecore
(M3 level). If you want to get a metamodel from the KM3 model, you have
to "promote" this model. You can do this with the transformation KM32Ecore.
Mikael
> metamodel="MOF" />
> </injector>
> </am3.loadModel>
> </target>
> file does not use the namespace http://www.eclipse.org/emf/2002/Ecore
> and elements like eClass, eAttribute but the KM3 namespace
> Metamodel and Contents, thus making it incompatible with other EMF tools.
> Regards.
> Lorenzo
>> Hello,
>> the KM3 model?
>> Regards,
>> Frédéric Jouault
>>> Hello again.
>>> to inject a KM3 meta-model into the corrensponding EMF (Ecore)
>>> meta-model, and ran it from Eclipse.
>>> </injector>
>>> </am3.loadModel>
>>> </target>
>>> (the .km3 file is correctly found).
>>> inject:
>>> 'ModelName'
>>> [am3.loadModel] at
>>> [am3.loadModel] at
>>> [am3.loadModel] at
>>> [am3.loadModel] at
>>> [am3.loadModel] at
>>> [am3.loadModel] at
>>> [am3.loadModel] at
>>> [am3.loadModel] at
>>> sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>>> [am3.loadModel] at
>>> sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
>>> [am3.loadModel] at
>>> [am3.loadModel] at
>>> [am3.loadModel] at
>>> [am3.loadModel] at
>>> [am3.loadModel] at
>>> [am3.loadModel] at
>>> [am3.loadModel] at
>>> [am3.loadModel] at
>>> [am3.loadModel] at
>>> [am3.loadModel] at
>>> [am3.loadModel] at
>>> [am3.loadModel] at
>>> [am3.loadModel] at
>>> [am3.loadModel] at
>>> [am3.loadModel] at
>>> [am3.loadModel] at
>>> [am3.loadModel] at
>>> [am3.loadModel] at
>>> [am3.loadModel] at
>>> [am3.loadModel] at
>>> [am3.loadModel] at
>>> [am3.loadModel] at
>>> [am3.loadModel] at
>>> [am3.loadModel] at
>>> BUILD SUCCESSFUL
>>> empty and therefore not valid.
>>> I'm sure the KM3 file is syntax-correct and I can inject it
>>> successfully using the context-menu command provided by the ATL
>>> Eclipse plugin.
>>> Lorenzo
Mikaël Barbero - PhD Candidate
ATLAS Group (INRIA & LINA) - University of Nantes
2, rue de la Houssinière
44322 Nantes Cedex 3 - France
tel. +33 2 51 12 58 08 /\ cell.+33 6 07 63 19 00
email: Mikael.Barbero@{gmail.com, univ-nantes.fr}
http://www.sciences.univ-nantes.fr/lina/atl/
FUDForum. Page generated in 0.03448 seconds
