Re: Move tasks to Trac connector [message #62176 is a reply to message #62105] |
Tue, 25 November 2008 21:10 |
Originally posted by: rob.elves.eclipse.org
Unfortunately there is no bulk migration code available. One practice
is, on an as needed basis, right click on a task and select New > Clone
Task... cloning the task to your new Trac repository, then marking the
old local task as resolved or deleting it. Consider submitting a bug
report for a more automated solution:
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=Mylyn
As for xml-rpc requirement, I believe it is mentioned in the wiki but
you are welcome to improve its visibility (just need an eclipse bugzilla
account to edit the wiki):
http://wiki.eclipse.org/index.php/Mylyn/User_Guide#Trac_Conn ector
-Rob
Hendrik Maryns wrote:
> I have a bunch of local tasks. Recently, I set up a Trac system, even
> managed to connect to it (there should be an explanation somewhere that
> you have to install the xml-rpc plugin) and want to move the local tasks
> to Trac. Is there an easy way to do this?
> TIA, H.
FUDForum. Page generated in 0.02026 seconds
