Re: I have problem starting the BPMN modeler [message #613901 is a reply to message #613899] |
Mon, 31 March 2008 11:24 |
Originally posted by: atoulme.intalio.com
thanks for your interest in the modeler.
It would be best if you could grab the code at this location:
http://dev.eclipse.org/svnroot/stp/org.eclipse.stp.bpmn/trun k/
since we have no idea how recent the koders version is.
Do you have anything in the log that looks like a stacktrace ?
Antoine
firas wrote:
> Hi ,
> I want to create a BPMN modeler with GMF .
> I downloaded the "org.stp.bpmn" open source solution from the "Koders
> web site", to try it(only the part of org.eclipse.stp.bpmn.*) .But
> when I run it as an eclipse plugin and I open the wizard of creating a
> new bpmn diagram I'm blocked in the first window and the wizard didn't
> display the list of folders in which I chose to create my new bpmn
> diagram so I can't either create a project.
> Thanks
Re: I have problem starting the BPMN modeler [message #613906 is a reply to message #613904] |
Tue, 01 April 2008 11:53 |
See https://bugs.eclipse.org/bugs/show_bug.cgi?id=219974 for this
problem. It should be fixed in the upcoming M6.
Antoine
firas wrote:
> Thank you Mr Antoine for your interest on my problem.
> I could skip the problem that I indicated .In fact I have to create a
> project before creating a bpmn_diagram to have the tree of projects
> displaying on my wizard.
> But I fall in an other problem which is the "java.lang.StackOverFlowerror".
> and I think that is due to the version of source code that I downloaded.
> I will try with the version that you indicate to me.
> Best regards. Thanks
Re: I have problem starting the BPMN modeler [message #613909 is a reply to message #613907] |
Wed, 02 April 2008 13:13 |
Is there anything in the log worth reading ? Otherwise it will be
difficult to track down your problem.
Antoine
firas wrote:
> Hello Mr Antoine ,
> I downloded the bpmn modeler project from
> http://dev.eclipse.org/svnroot/stp/org.eclipse.stp.bpmn/trun k/ as you
> indicated to me.
> But when I run the project as the following manner :
> 1) Run configuration
> 2) Run a product "org.eclipse.sdk.ide"
> 3) and I click "run"
> When the windows of eclipse appears I do:
> 1) file -> new -> other -> examples -> bpmn digram
> and then I have the wizard of diagram creation.when I specified where I
> would like to create it and I click "Finish". the bpmn files are created
> and there is an empty window that is created titeled "Bpmn Diagram
> Editor" but there is no palette or any thing that is displayed on this
> window.
> Do you have please any idea about the solution of that problem?
> Best regards.
Re: I have problem starting the BPMN modeler [message #613912 is a reply to message #613910] |
Wed, 02 April 2008 15:17 |
You are hitting this bug:
I'll fix this bug ASAP. Please add yourself in CC to get notified when
that happens.
In the mean time, please use the release 3.3.2 to build and use bpmn.
Antoine
firas wrote:
> Hello ,
> There are some lignes of my .log file:
> !ENTRY org.eclipse.stp.bpmn.diagram 4 0 2008-04-02 14:41:35.421
> !MESSAGE Problems encountered while setting project description.
> !STACK 1
> org.eclipse.core.runtime.CoreException: Problems encountered while
> at
> org.eclipse.core.internal.resources.Project.setDescription(P roject.java:1020)
> at
> org.eclipse.core.internal.resources.Project.setDescription(P roject.java:1046)
> at
> org.eclipse.stp.bpmn.diagram.part.BpmnCreationWizardPage.set upBpmnValidationBuildableNature(BpmnCreationWizardPage.java: 146)
> at
> org.eclipse.stp.bpmn.diagram.part.BpmnCreationWizardPage.set upBpmnValidationBuildableNature(BpmnCreationWizardPage.java: 101)
> at
> org.eclipse.stp.bpmn.diagram.part.BpmnCreationWizardPage.cre ateAndOpenDiagram(BpmnCreationWizardPage.java:55)
> at
> org.eclipse.gmf.runtime.diagram.ui.resources.editor.ide.wiza rds.EditorWizardPage.doFinish(EditorWizardPage.java:103)
> at
> org.eclipse.gmf.runtime.diagram.ui.resources.editor.ide.wiza rds.EditorWizardPage$1.execute(EditorWizardPage.java:164)
> at
> org.eclipse.ui.actions.WorkspaceModifyOperation$1.run(Worksp aceModifyOperation.java:104)
> at
> org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1800)
> at
> org.eclipse.ui.actions.WorkspaceModifyOperation.run(Workspac eModifyOperation.java:116)
> at
> org.eclipse.jface.operation.ModalContext.runInCurrentThread( ModalContext.java:407)
> at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:347)
> at org.eclipse.jface.wizard.WizardDialog.run(WizardDialog.java: 934)
> at
> org.eclipse.gmf.runtime.diagram.ui.resources.editor.ide.wiza rds.EditorWizardPage.finish(EditorWizardPage.java:169)
> at
> org.eclipse.gmf.runtime.diagram.ui.resources.editor.ide.wiza rds.EditorCreationWizard.performFinish(EditorCreationWizard. java:50)
> at
> org.eclipse.jface.wizard.WizardDialog.finishPressed(WizardDi alog.java:742)
> at
> org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDi alog.java:373)
> at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.jav a:623)
> at
> org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:227)
> at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
> at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:982)
> at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3760)
> at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3371)
> at org.eclipse.jface.window.Window.runEventLoop(Window.java:825 )
> at org.eclipse.jface.window.Window.open(Window.java:801)
> at
> org.eclipse.ui.internal.handlers.WizardHandler$New.executeHa ndler(WizardHandler.java:260)
> at
> org.eclipse.ui.internal.handlers.WizardHandler.execute(Wizar dHandler.java:280)
> at
> org.eclipse.ui.internal.handlers.HandlerProxy.execute(Handle rProxy.java:252)
> at
> org.eclipse.core.commands.Command.executeWithChecks(Command. java:475)
> at
> org.eclipse.core.commands.ParameterizedCommand.executeWithCh ecks(ParameterizedCommand.java:470)
> at
> org.eclipse.ui.internal.handlers.HandlerService.executeComma nd(HandlerService.java:165)
> at
> org.eclipse.ui.internal.handlers.SlaveHandlerService.execute Command(SlaveHandlerService.java:247)
> at
> org.eclipse.ui.internal.actions.CommandAction.runWithEvent(C ommandAction.java:157)
> at
> org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:582)
> at
> org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:499)
> at
> org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:410)
> at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2392)
> at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2356)
> at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 22)
> at org.eclipse.ui.internal.Workbench$4.run(Workbench.java:474)
> at
> org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:288)
> at
> org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:469)
> at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:149)
> at
> org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:106)
> at
> org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:193)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:106)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:76)
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:362)
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:175)
> at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 564)
> at org.eclipse.equinox.launcher.Main.basicRun(Main.java:504)
> at org.eclipse.equinox.launcher.Main.run(Main.java:1251)
> at org.eclipse.equinox.launcher.Main.main(Main.java:1227)
> !SUBENTRY 1 org.eclipse.core.resources 2 568 2008-04-02 14:41:35.421
> !SUBENTRY 2 org.eclipse.core.resources 2 35 2008-04-02 14:41:35.421
> !MESSAGE Nature does not exist:
> org.eclipse.stp.bpmn.validation.BatchValidationBuildAbleNatu re.
> !ENTRY org.eclipse.stp.bpmn.diagram 4 0 2008-04-02 14:41:39.796
> !STACK 1
> at
> at
> at
> at
> org.eclipse.stp.bpmn.diagram.part.BpmnDiagramEditor.setupBpm nValidationBuildAbleNature(BpmnDiagramEditor.java:86)
> at
> org.eclipse.stp.bpmn.diagram.part.BpmnDiagramEditor.setDocum entProvider(BpmnDiagramEditor.java:74)
> at
> org.eclipse.gmf.runtime.diagram.ui.resources.editor.parts.Di agramDocumentEditor.updateDocumentProvider(DiagramDocumentEd itor.java:359)
> at
> org.eclipse.gmf.runtime.diagram.ui.resources.editor.parts.Di agramDocumentEditor.doSetInput(DiagramDocumentEditor.java:41 4)
> at
> org.eclipse.gmf.runtime.diagram.ui.resources.editor.parts.Di agramDocumentEditor.setInput(DiagramDocumentEditor.java:389)
> at
> org.eclipse.gef.ui.parts.GraphicalEditor.init(GraphicalEdito r.java:318)
> at
> org.eclipse.gmf.runtime.diagram.ui.parts.DiagramEditor.init( DiagramEditor.java:643)
> at
> org.eclipse.gmf.runtime.diagram.ui.resources.editor.parts.Di agramDocumentEditor.init(DiagramDocumentEditor.java:116)
> at
> org.eclipse.ui.internal.EditorManager.createSite(EditorManag er.java:799)
> at
> org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.java:643)
> at
> org.eclipse.ui.internal.EditorReference.createPart(EditorRef erence.java:428)
> at
> org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:594)
> at org.eclipse.ui.internal.PartPane.setVisible(PartPane.java:30 0)
> at
> org.eclipse.ui.internal.presentations.PresentablePart.setVis ible(PresentablePart.java:180)
> at
> org.eclipse.ui.internal.presentations.util.PresentablePartFo lder.select(PresentablePartFolder.java:270)
> at
> org.eclipse.ui.internal.presentations.util.LeftToRightTabOrd er.select(LeftToRightTabOrder.java:65)
> at
> org.eclipse.ui.internal.presentations.util.TabbedStackPresen tation.selectPart(TabbedStackPresentation.java:473)
> at
> org.eclipse.ui.internal.PartStack.refreshPresentationSelecti on(PartStack.java:1256)
> at org.eclipse.ui.internal.PartStack.setSelection(PartStack.jav a:1209)
> at org.eclipse.ui.internal.PartStack.showPart(PartStack.java:16 08)
> at org.eclipse.ui.internal.PartStack.add(PartStack.java:499)
> at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:103 )
> at org.eclipse.ui.internal.PartStack.add(PartStack.java:485)
> at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:112 )
> at
> org.eclipse.ui.internal.EditorSashContainer.addEditor(Editor SashContainer.java:63)
> at
> org.eclipse.ui.internal.EditorAreaHelper.addToLayout(EditorA reaHelper.java:217)
> at
> org.eclipse.ui.internal.EditorAreaHelper.addEditor(EditorAre aHelper.java:207)
> at
> org.eclipse.ui.internal.EditorManager.createEditorTab(Editor Manager.java:779)
> at
> org.eclipse.ui.internal.EditorManager.openEditorFromDescript or(EditorManager.java:678)
> at
> org.eclipse.ui.internal.EditorManager.openEditor(EditorManag er.java:639)
> at
> org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched( WorkbenchPage.java:2719)
> at
> org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(Workben chPage.java:2633)
> at
> org.eclipse.ui.internal.WorkbenchPage.access$12(WorkbenchPag e.java:2625)
> at
> org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.j ava:2577)
> at
> org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:67)
> at
> org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2572)
> at
> org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2556)
> at
> org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2547)
> at org.eclipse.ui.ide.IDE.openEditor(IDE.java:644)
> at org.eclipse.ui.ide.IDE.openEditor(IDE.java:603)
> at
> org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.openInE ditor(EditorUtility.java:318)
> at
> org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.openInE ditor(EditorUtility.java:160)
> at org.eclipse.jdt.ui.actions.OpenAction.run(OpenAction.java:22 2)
> at org.eclipse.jdt.ui.actions.OpenAction.run(OpenAction.java:20 3)
> at
> org.eclipse.jdt.ui.actions.SelectionDispatchAction.dispatchR un(SelectionDispatchAction.java:268)
> at
> org.eclipse.jdt.ui.actions.SelectionDispatchAction.run(Selec tionDispatchAction.java:244)
> at
> org.eclipse.jdt.internal.ui.packageview.PackageExplorerActio nGroup.handleOpen(PackageExplorerActionGroup.java:343)
> at
> org.eclipse.jdt.internal.ui.packageview.PackageExplorerPart$ 5.open(PackageExplorerPart.java:607)
> at
> org.eclipse.jface.viewers.StructuredViewer$2.run(StructuredV iewer.java:820)
> at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
> at org.eclipse.core.runtime.Platform.run(Platform.java:857)
> at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:46)
> at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:19 9)
> at
> org.eclipse.jface.viewers.StructuredViewer.fireOpen(Structur edViewer.java:818)
> at
> org.eclipse.jface.viewers.StructuredViewer.handleOpen(Struct uredViewer.java:1079)
> at
> org.eclipse.jface.viewers.StructuredViewer$6.handleOpen(Stru cturedViewer.java:1183)
> at
> org.eclipse.jface.util.OpenStrategy.fireOpenEvent(OpenStrate gy.java:263)
> at org.eclipse.jface.util.OpenStrategy.access$2(OpenStrategy.ja va:257)
> at
> org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrate gy.java:297)
> at
> at
> at
> at
> at
> at
> at
> at
> !SUBENTRY 1 org.eclipse.core.resources 2 568 2008-04-02 14:41:39.796
> !SUBENTRY 2 org.eclipse.core.resources 2 35 2008-04-02 14:41:39.796
> !ENTRY org.eclipse.ui 4 0 2008-04-02 14:41:40.031
> !MESSAGE Unhandled event loop exception
> !STACK 0
> java.lang.StackOverflowError
> at
> org.eclipse.gmf.runtime.diagram.ui.editparts.TextCompartment EditPart.getFigure(TextCompartmentEditPart.java:175)
> at
> org.eclipse.gmf.runtime.diagram.ui.editparts.TextCompartment EditPart.getLabel(TextCompartmentEditPart.java:235)
> at
> org.eclipse.gmf.runtime.diagram.ui.editparts.TextCompartment EditPart.createLabelDelegate(TextCompartmentEditPart.java:15 5)
> at
> org.eclipse.gmf.runtime.diagram.ui.editparts.TextCompartment EditPart.getFigure(TextCompartmentEditPart.java:176)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Re: I have problem starting the BPMN modeler [message #613917 is a reply to message #613914] |
Thu, 03 April 2008 11:30 |
Did you google for SVN ?
How did you get the code ? If you downloaded it through a subversion
client in Eclipse, you shuld right click on the project, and select
Team>Update.
Antoine
firas wrote:
> Hi Mr Antoine,
> I don't know the terms SVN and snapshots.
> In deed I don't know where I can update my current checkout of the code .
> Firas
Re: I have problem starting the BPMN modeler [message #614195 is a reply to message #614190] |
Mon, 07 April 2008 08:54 |
Firas,
you can look for these in the Advanced Tab.
Antoine
firas wrote:
> Hello Mr Antoine ,
> Thank you very much for disponobility and for time to help me .
> Finally I could run the project.In fact the source of the bug I had
> wasn't your code, it's a problem in GMF version I used. When I changed
> it, I will be able to run the program.
> But I still have some details that are not yet clear to me.
> In fact, when I want to visualise the details of an item in the diagram
> by doing ( Show Properties View ) , I dont have the EMF details
> (documentation ,name ,...).Only the View property appears to me.
> Could you please indicate to me what doing, to display it .
> Best regards.
> Firas
Re: I have problem starting the BPMN modeler [message #614209 is a reply to message #614198] |
Mon, 07 April 2008 10:07 |
As I replied already, please look at the values in the advanced tab,
while selecting an activity. Under the EMF node in the tree, you should
have all those fields.
Antoine
firas wrote:
> Hello Mr Antoine ,
> I want to thank you for your time and your disponibility to help me.
> Finally ,I could run the BPMN modeler.It's not a problem from your source,
> it's due to the GMF version I was using.
> But I still have a problem with the "View properties" which not
> displays the EMF properties (documentation,name )of diagram shapes and
> only the other view properties are shown.
> Could you please indicate to me how to do to solve this problem?
> Best regards.
> Firas
FUDForum. Page generated in 0.02839 seconds
