missing control.layout() code after adding some widgets [message #613565] |
Fri, 21 July 2006 13:08 |
Originally posted by: nicolas.georgemel.laposte.net
i found an issue with 2 elements (maybe more) : after adding a group
widget or a section widget (forms toolkit) with VE. All is fine in VE
but at runtime some elements are missing :
- for section widget, the text is not visible
- for group widget, all child widget are not visible
to workaround theses issues i must hand coding layout() method at the
end of control creation code, so after, at runtime, all is fine.
i paste a snippet here for sample :
private void createSection1() {
section1 = getFormToolkit().createSection(compositeInvoiceForm,
ExpandableComposite.TWISTIE | Section.DESCRIPTION |
ExpandableComposite.TITLE_BAR | ExpandableComposite.CLIENT_INDENT);
section1.setExpanded(true);
section1.setText("Dates");
createComposite1();
section1.setClient(composite1);
section1.setBounds(new Rectangle(60, 165, 886, 76));
section1.layout(); //here it's code added by hand
i guess VE would added this code automatically but perhaps this code, in
some case, is time or display consuming...i don't know...
Maybe a bug is open, if none please let me know and i'll open one.
My config :
Version: 3.2.0
Build id: M20060629-1905
Using calisto project
Win XP sp2
Nicolas Georgemel.
"Computers are like air conditioners. They don't work when you open
Windows."
FUDForum. Page generated in 0.05536 seconds
